- Thank you received: 599
I don't change the version for every addition, if I did it would be 1.1.125 LOL.
Your screen shot looks correct. I added multi state labels on the 20th, how are you updating?
JT
I'm downloading the deb release from the git page. It's still at 1.1.1 but is says it's been updated since then.
Looks like apt didn't update it right this time since it's still version 1.1.1, I used gdebi and now it works. I did get a wierd error about a different label already having that hal pin name but that wasn't the case. I'm not sure if that stems from the multi-state label having the same widget name as it's hal pin name or the hal pin name having underscores. I had other regular labels with a single hal pin with underscore in the name and it was fine. I just changed the underscores in the hal pin name to dashes and the error went away.
To change themes without restarting "might" work by using a custom python but I've never tried that.Hello guys! I want to thank JT very much for the work done! This is very cool! After reading the documentation, I want to try to make a graphical interface for a CNC lathe. I'm not good at programming, it's easier for me to sit with a soldering iron in my hands))). But I think something will work out))) Question: I want to implement a light and dark theme. Can I make a switch to change the theme (light/dark)? So as not to write this in the .ini file. So that I would have the opportunity to switch the topic from the program!
