- Thank you received: 167
I'll look into the dark-touch theme to see what I need to fix that.Yeah that looks much nicer than the tabwidget when it's run....
The frames on the list and plain text editor aren't visible in the dark-touch theme. For now I'm just sticking them on frame widgets because they blend in with the background otherwise.
One more question......
On the stacked widget, designer seems to save the "current index" as the default, so if you happen to be editing a page and save it, running it from LinuxCNC will always start on that page. Is there any way to create a "default index"?
I have like 3 stacked widgets on top of each other so I have to make sure I set them all to the desired first page before I save it
