  • cdamm11
  • cdamm11
13 Dec 2025 11:51
6i25 and 7i77 config was created by cdamm11
Category: Driver Boards
Hello LinuxCNC experts!
I am having a hard time setting up my LinuxCNC configuration. I have a 6i25 and 7i77. I have confirmed 5V to the P1 connector and jumper is in right hand. I have 26V on TB2. All others connector i have removed from the 7i77.
I have installed: linuxcnc_2.9.4 amd64.hybrid iso file. My Jitter is good.
I did not buy the 6i25 and 7i77 as a kit. i tried to load the firmware this way;
sudo mesaflash --device 5i25 --write (my directory)/5i25_7i77x2.bit
sudo mesaflash --device 5i25 --reload
i used the files from mesa website. And it seems to flash without problems.
Than i tried to use pnconf. i setup the encoders XYZ and PWM XYZ and the correct scaling.
When i load the program my pc just reboots. I get no errors. I tried to alot of things from these forums but i cant get any sucess.
Best regards Christian
13 Dec 2025 11:40
Replied by tommylight on topic Clearpath HLFB amp.joint.delay
Category: HAL
Remove everything except timedelay and fault inputs.
I still have no idea what your issue is, i am replying to your queries as they come.
Such errors should not be triggered when drives are enabled, so that might well be drive issue.
  • rodw
  • rodw's Avatar
13 Dec 2025 10:07
7i92 cnc motion controller from aliexpress?
Thanks also from me  and to Rod for his AI free help  youtubes.
You are welcome!
I have sometimes used AI to research the topics but when AI starts quoting my forum posts I know I am on my own! :)
  • rodw
  • rodw's Avatar
13 Dec 2025 10:00
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
I wonder if you raised an issue for lcec if Scott might become motivated to enhance the hal driver?
Its odd its taken so long before the issue was raised......
  • SrLange61
  • SrLange61's Avatar
13 Dec 2025 08:35
Replied by SrLange61 on topic 7i92 cnc motion controller from aliexpress?
After 15 years of lunuxcnc software steping I now have a mesa. Every time I've looked into buying one the postage has been the killer. I'm still waiting for the other parts. After I add a wifi usb the old  config I guess can stay as I will only have to change the plug going into the  Geckodrive. VDF control uses VDFmod from the computer USB.Its had a bit of use this year cuting out about 20 foamboard RC planes. Thanks also from me  and to Rod for his AI free help  youtubes.
srl
  • NWE
  • NWE's Avatar
13 Dec 2025 04:50
Replied by NWE on topic VFD configuration help
Category: Turning
If you use a normally open start button and a normally closed stop button, it appears it could work to set parameter 28 = 2 to make its signal relay operate when the inverter starts. Then it should be possible to wire it similar to a contactor with an aux. contact.
  • Hakan
  • Hakan
13 Dec 2025 04:34
Category: EtherCAT
It's a general problem with EoE in the drive.
kworm has looked at it in some depth and submitted bugs/issues.
forum.linuxcnc.org/ethercat/53961-eoe-configuration
I think it would be good to have EoE working with lcec.
Short term it can be good to disable the eoe server parts,
long term it is good if it works.
  • Fastfred
  • Fastfred
13 Dec 2025 01:10
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Category: HAL
Thank You for that looks like the .hal file is correct now I am assuming I dont have correct settings in the motors thought it would fault if power/loss of com .
or am I missing a config for that?
13 Dec 2025 00:48
Category: HAL
and2.n should be ranged from 0, not from 3, so
and2.0
and2.1
and2.2
and2.3
  • Fastfred
  • Fastfred
13 Dec 2025 00:45
Category: HAL
made the changes but errors
Debug file information:
Note: Using POSIX realtime
HAL: ERROR: function 'and2.4' not found
./custom.hal:5: addf failed
18633
Stopping realtime threads
Unloading hal components
File Name: custom_202...12-2.hal
File Size:1 KB
  • rodw
  • rodw's Avatar
13 Dec 2025 00:12
Category: EtherCAT
I looked at that and unfortunately it is code sprinkled around everywhere.
So it will be a bit of surgery in the etherlab code I am afraid.
I don't think EoE is normally a problem, perhaps just for this drive. Now they know a bug is there it will get fixed but I doubt you'll see it for a while.
  • Ismacr63
  • Ismacr63
13 Dec 2025 00:02
Replied by Ismacr63 on topic VFD configuration help
Category: Turning
The buttons are momentary.
12 Dec 2025 23:57
Replied by tommylight on topic Mesa konfiguration Maho 500 W4
It would be much easier if you know how much IO you need, even a rough estimate will do.
12 Dec 2025 23:56
Replied by tommylight on topic VFD configuration help
Category: Turning
Buttons, are they momentary or on/off ?
Displaying 10006 - 10020 out of 11520 results.
Time to create page: 0.439 seconds
