  • tcbmetalworks
  • tcbmetalworks
19 Nov 2025 03:48
Replied by tcbmetalworks on topic Automatic band saw marvel v10a
Category: CNC Machines
Interesting I will give it a shot repairing the hydraulic system before abandoning it.
  • tcbmetalworks
  • tcbmetalworks
19 Nov 2025 03:37
Looking for a freelancer to assist in drawing schematics for cnc plasma table
Category: User Exchange
Here is a link to the thread of me documenting the process of building the table to get to where it is right now. Yes the motors are overkill but they are not really too big of a form factor and the gantry estimated weight is 400-800lbs. I have the machine geared to run 700ipm rapid if I remember correctly. Alot of force required to rapidly change directions at fast cut speeds on a gantry this large. And yes the list is long. Really I need help documenting and planning this project to speed things up. Draw a wiring diagram and point me in the right direction for parts. I want a diagram so its easy to fix for the next guy, and I can make sure then that everything is properly grounded/bonded and resistant to interfearence. The only thing I forgot on that list is a circuit for e stop maybe using a saftey relay and I may add in a lube pump to pump oil into the tracks and rollers.
  • unknown
  • unknown
19 Nov 2025 03:27
I would like to know how to connect GPIO to LinuxCNC’s E-Stop chain.
Category: Basic Configuration
Personally I would have the estop connected via Normally closed switch, and the estop is signaled via opening connection. This way if, for whatever reason, the estop wire is broken or falls off either connection the machine will go into an estop condition.
The way you have your schematic, you'll only know that something is wrong with the estop when you go to use it.
I'd rather a failing estop not let the machine run.
19 Nov 2025 03:10
Depends on what the machine has for an e-stop chain and that is wired, but for small machines that can not do much harm, a simple and single input and a single output are all that is needed:
# --- ESTOP-EXT ---
net estop-ext <= [HMOT](CARD0).7i84.0.2.input-14
net estop-ext => [HMOT](CARD0).7i84.1.1.output-08
That will just loop back the e-stop signal from the button to whatever is connected to the output pin. This works perfectly well on most machines (example is from my 3.5 ton Mazak lathe) as the output is wired to existing e-stop loop on the machine.
That will not allow the machine to come on when the button is pressed and will allow enabling the machine when button is reset.
E-stop latch should be used only when more logic is required by LinuxCNC, and/or more inputs and outputs.
  • mooser
  • mooser
19 Nov 2025 02:33
Replied by mooser on topic 7i84u Powering
7i84u Powering
Category: Driver Boards
That's what I originally thought (onboard looking after making VIN a safe value from VFIELDB) but the more I looked at it the more nervous I got.
Thanks for the verification
Moving ahead in glacier like strides, limit switches are next.
M
  • EdWorks
  • EdWorks's Avatar
19 Nov 2025 02:31
If I use the following code which has the one missing dash error that I corrected:
# estop
loadrt estop_latch
addf estop-latch.0 servo-thread
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset
net remote-estop estop-latch.0.fault-in <= parport.0.pin-in-10-not
The bug-a-boo for me is how do I tie the GPIO25 to the remote-estop. Do I change the last line to:
net remote-estop estop-latch.0.fault-in <= hal_gpio.GPIO25-in-10-not
  • PCW
  • PCW's Avatar
19 Nov 2025 02:27
Replied by PCW on topic 7i84u Powering
7i84u Powering
Most normal wiring would be:
FIELDA  +24V
FIELDB  +24V
VIN (unconnected)
W1 LEFT
  • Muftijaja
  • Muftijaja
19 Nov 2025 02:24
problems with Y-Axis, elliptic deviations after several changes -Probe Basic V.5
Category: QtPyVCP
Thanks for your answer! My tests are in aluminum EN-AW 5083. That is my target material.
Yes I know that a really stiff machine should be made of steel or cast, but I have bult what I could.
  • Muftijaja
  • Muftijaja
19 Nov 2025 02:16 - 19 Nov 2025 02:25
Category: QtPyVCP
Hakan, thanks for your reply! Yes the 500 were the result of another contribution and the servo thread setting at 2 million.
See forum.linuxcnc.org/42-deutsch/55139-moto...4-7-5-m-min?start=20
There are other hints for FF1 and FF2 in the motor settings, even though there is no real feedback loop. I don't understand this in depth, but I follow those experts as tommylight and PCW.
  • EdWorks
  • EdWorks's Avatar
19 Nov 2025 02:11
Ahh, no discernible action when I hit SUBMIT the first time. I can wait it out in the future.
  • unknown
  • unknown
19 Nov 2025 02:11
Come here first.
Too many times users have received info from chatgpt that make absolutely no sense.
Google searching for "linuxcnc estop latch" gives the link above as the 4th result.
Or you could use the search function of the forum.
  • EdWorks
  • EdWorks's Avatar
19 Nov 2025 02:06
Yes, I have a jaundiced view of ChatGPT but I try to exhaust my resources before coming here.
I will check the link.
If you would like to read the question as formatted, check here:
acrobat.adobe.com/id/urn:aaid:sc:VA6C2:0...f2-9441-faf83de82c31
Thanks.
  • unknown
  • unknown
19 Nov 2025 02:03
There were 2 new threads submitted by yourself with the same heading.
  • EdWorks
  • EdWorks's Avatar
Displaying 11071 - 11085 out of 11531 results.
Time to create page: 0.479 seconds
