  • Beovoxo
  • Beovoxo
18 Nov 2025 22:25 - 18 Nov 2025 22:26
Replied by Beovoxo on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
Tried first reinstall 2.9.4, that did not help. then i installed "linuxcnc_2.9.3-amd64.hybrid" same problems as before+ expkey signature not valid due to age, but that's ok ish.. . I think there are a "update" being loaded on install or right after that bugs it. .
one thing i don't get also is when i installed 2.9.7 first time it showed Debian 13 with "red theme" ??
...... :) i think i will put the install on pause for some days because i am going insane lol .. :) thx for helping :)
  • cajbr
  • cajbr
18 Nov 2025 22:02
Replied by cajbr on topic Schaublin 125-CNC retrofit.
Category: Turning
I'd be tempted to try setting C007 to 14, but it will spin the motor opposite.
  • Muftijaja
  • Muftijaja
18 Nov 2025 21:48
problems with Y-Axis, elliptic deviations after several changes -Probe Basic V.5
Category: QtPyVCP
Hello community!
I have a Mesa 7i76e running, the wiring is correct except for the alarm loop. Using a Lenovo ThinkCentre M910q with i7 4-core, 256/GB NVMe SSD, i7 16GB RAM WLAN Intel Core i7-6700T 4x 2.80 - 3.60GHz with Linuxcnc 2.9.4, Probe Basic V.5 on Debian 12. No latency problems.
Once again, I'm here with a big problem. My DIY milling machine (1000x500x220 with aluminum profile frame, 20mm HGR, 1605 ball screws, 3 axes, 2x OMC Stpperonline 400W integrated servo, 1x JMC CL Stepper 3.5Nm, set 2000 steps/rev) is now mechanically finally assembled. I also got a lot of help from this forum in setting up LinuxCNC, eliminating latency problems and spindle control problems, but now I have a milling problem that I can't solve.
I have milled several test parts with drill holes, 2 circular pockets, and a rectangular outer contour, and have noticed that my circular pockets are becoming elliptical. The deviations in Y are approximately +0.35 mm at 45° and approximately -0.38 mm at 135°. The X values for the rectangular contour are perfect to within 0.01 mm in X and 0.09 mm in Y, X I consider to be acceptable, but Y is over tolerance. However, the circular movements contain deviations I cannot tolerate. I will show you a photo of the last test piece. After each individual test part, I made changes to rule out certain things.
The first change was to replace a simple Chinese C7 ball screw with a ground C5 spindle with double nuts. This reduced the originally even higher values by almost half. However, the deviations described above remained. After the next test part, I replaced the 400 W servo with a 3.5 Nm JMC CL stepper motor. The results remained almost the same. As a final attempt, a few days ago I replaced the spindle's fixed bearing with a new one, with 7002AC angular contact bearings in an O-arrangement with a 1 mm spacer ring between the outer rings. I inspected the previous fixed bearing and found no faults. There was a 1mm spacer also and the O arrangement was the same.  I had also taken measurements at the spindle end earlier and actually and found no backlash.
Yesterday, moving away from mechanical faults, I noticed a difference in the motor definitions for the X and Y axes in the .ini file. The Ferror and min_Ferror points differed by one decimal place. X was set to 0.1 and 0.01, while the Y axis was set to 1.0 and 0.1. After I corrected this difference, the motor on the Y axis went into alarm mode after a few position changes.
What could be the reason for this? How can it be that one motor runs perfectly with much lower tolerance values, while the other quickly goes into alarm mode with less load? The motor in question has the same power supply and is certainly less demanding in terms of starting currents than the servo on the X-axis. With the higher tolerance values, the Y motor runs without alarm, but has these deviations. Are these tolerance values in the .ini file responsible for these deviations?
The mechanics of the Y and Z axes are flawless, as checked with a dial gauge, and the repeat accuracy is also very good, less than one hundredth.
Do you have any ideas about this? Where can I look further?
Thanks for your time and hints
File Name: Hanno_Nr5_...1-18.hal
File Size:12 KB
File Name: Hanno_Nr5_...1-18.ini
File Size:6 KB
  • RotarySMP
  • RotarySMP's Avatar
18 Nov 2025 21:29
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
I tried
C07 --> 2. The VFD no longer started the motor.
C07 --> 1. Same behavior as CO7 - 0.
  • RotarySMP
18 Nov 2025 21:19 - 18 Nov 2025 21:20
Category: Turning
Terminal E3 and E2 are unpopulated, but always have been. In the video link above, it was ramping down when I first tested it, and I am pretty sure I found a way to turn that off.
C007 is assigned option 0.
  • cajbr
  • cajbr
18 Nov 2025 21:07
Category: Turning
Sorry, meant C007. QSB is not selected by default. Default is DC braking. Page 7-78.
  • RotarySMP
18 Nov 2025 20:21 - 18 Nov 2025 20:22
Category: Turning
Thanks for taking a look. And yeah, that manual sucks :)
I have no C107. It jumps from C106 to C108.
C105, I have tried different values, like 5Sec or 1.5Sec. It makes no difference. The drive is not ramping down, it got straight to 0A, and OFF as soon as it is commanded off.
  • unknown
  • unknown
18 Nov 2025 20:15
Replied by unknown on topic Probe basic launch issue
I guess you're installing on Trixie.
Install
sudo apt install python3-zombie-imp
Then if you try to run you'll get another error which is related to libqt5quickwidgets5
sudo apt install libqt5quickwidgets5
  • cajbr
  • cajbr
18 Nov 2025 20:14
Category: Turning
Are your input terminals configured for QSP? C107
Also check C105 which is QSP decel time.
That manual is awful.
BR
  • unknown
  • unknown
18 Nov 2025 20:10
Replied by unknown on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
I just created this from a known good download. Just remove the .txt bit of the download to check.
File Name: linuxcnc_2....md5.txt
File Size:0 KB
Make sure to download from here:
www.linuxcnc.org/iso/
As this is the official site and the safest option.
  • Aciera
  • Aciera's Avatar
18 Nov 2025 19:09 - 18 Nov 2025 19:24
lemontart - a call for help with s curve, ui's, and all the cool toys
If you have more time than money I have complete build-yourself-a-drive plans and software, 4 drives on a pcb.
is there a link for that?
Disregard, I think I just found it:
github.com/MetalMusings/MyOwnEtherCATDevice
  • RotarySMP
18 Nov 2025 18:55 - 27 Nov 2025 17:02
Category: Turning
I (finally) installed a Lenze EMB9351-E brake module in my Schaublin, after a couple of years of annoying 15 sec waits for the spindle to coast down to a stop.
Back when I did the original installation, I was getting over-current warnings when I tried to ramp down in less time.
I somehow set the Lenze 8214 VFD to not control the motor down, but rather to just let it coast down.
So per the manual, I have the following control commands: Pin 7 / Pin 8 (Analog in) connected to a Mesa analog output, and jumpered for 0-10V. This is the main control. The VFD doesn't get on/ off commands, it gets speed commands. Pin 9 (Power for a control poti) Unused. Pin 62 (Analog out) Unused Pin 20 (power out for digital inputs) Unused. Pin 28. (Activate VFD) Controlled by Mesa digital output.Pin E4 (Change direction) Controlled by a Mesa digital output.
Pin E3 DC (DC braking) unused.
Pin E2 (Jog at frequency 2) Unused.Pin E1 (Jog at frequency 1) Unused.
Pin 39 (Gnd) Connected. Output Relay
K11 (NO Out) Connected to Mesa inK12 (Common) Connected to Mesa in.
assets.euautomation.com/uploads/parts/pdf/338201e.pdf
I have spent two evening going through both EN and DE user guides, reading out every single parameter, and adjusting everything which looks like it is involved with ramps, and I can't work out how to remove the coasting, and restore the C13 deceleration.
I even used parameter C02 --> 1 to restore all the default factory parameters, and went back in and set the motor current, slip and CosPhi. It is still ignoring the C13 decelerate ramp value and just free wheeling to a stop. The C12 acceleration is functional.
This is embarasing,, but I can't for the life of me remember what I did to set this VFD into coast down mode. Does anyone have experience with Lenze VFD's who can give me a tip please?
Cheers,
Mark
  • RaspII
  • RaspII
18 Nov 2025 18:52
Replied by RaspII on topic ISEL CNC/IMC4 programming language
Hello,
is there still sombody available who knows whether there was a solution for this topic?
I own an ISEL CMP3020 with IMC4 Interface and have similar questions.
I don't own the old DOS software from ISEL so I don't can say whether the machine is running well.
Neverthless I have a free trial for the "KAY" software available and this software is at least able to do some movements.
Nevertheless its not working 100% (has some issues with finding origin...) so I want to use linuxcnc if possible.
I alread wrote a short c# application (thanks to chatGPT) and can also control the machine via this application (some basis only).
So I can see that the motors are moving as they should do and also the end switches are working well, including movement to origin!)
I'm also very interested to get some PC software which can communicate to the IMC4 or a code converter software which can provide the IMC4 code.
I understood that the DNC Code is needed to steer the IMC4 directly via serial port
I understood that I have to download a CNC Code to the IMC4's flash to enable the IMC4 controller to do the work without attached PC.
Nevertheless also the CNC-Code (CNC-Mode) is not compatible with G-Code, means a DNC- or CNC-Mode converter is needed anyway to steer the machine
  • Hakan
  • Hakan
18 Nov 2025 18:50
Lichuan CL57E-4A en.xlichuan.com/product-xq/202.html is a ethercat stepper motor driver for four motors.
Have only seen them sold in kit with four motors though.
  • PCW
  • PCW's Avatar
18 Nov 2025 18:39
Replied by PCW on topic Mesa 7i95t with pwm firmware
Category: Driver Boards
# Abilitazione PWM: attivo quando lo spindle è "on" (M3/M4)
net spindle-enable motion.spindle-on => hm2_[MESA](BOARD).0.pwmgen.00.enable
# Comando velocità in RPM dal planner
net spindle-speed-cmd-rpm motion.spindle-speed-out => hm2_[MESA](BOARD).0.pwmgen.00.value
I would in addition, check the above signals and pins to try and trace backwards
to find out  why  you don't have PWM enable and value set properly.
Displaying 11101 - 11115 out of 11531 results.
Time to create page: 0.661 seconds
