11 Oct 2025 23:40
fixing "raspi firmware" errors on the official amd64 ISO
Category: Installing LinuxCNC
@Rob,
as long as you are chrooted into the ISO, you can do everything you can on a normally running system, so yes, easy to remove at any point in time while preparing and before building the final ISO.
  • Twitchy88
  • Twitchy88
11 Oct 2025 23:26
INI and HAL files was created by Twitchy88
INI and HAL files
Hello
Can someone give me a quick run down of the INI and HAL files.  I successfully got an axis on my Fadal mill moving today with mesa 7i96s and DMM Dyn4 servos using axis. I used PNCCONF and it still wouldn't work, then I realised the files needed to be put somewhere but for the life of me I couldn't figure out what files needed to go where. After watching a video I saw the button to "create desktop launcher to start linux with this configuration".
I would like to learn how to modify the files manually and put them where they need to go. If I were to start from scratch without PNCCONF what files need to be modified and put where?
11 Oct 2025 23:22
@Andy,
sorry i was not aware anyone except Rod is involved into it.
  • Twitchy88
  • Twitchy88
11 Oct 2025 22:53
Replied by Twitchy88 on topic User interface
User interface
Thanks everyone, I have taken rodw advice and starting out with Axis.
  • Fastfred
  • Fastfred
11 Oct 2025 22:49
Replied by Fastfred on topic Gmoccapy tool setter install "errors"
Category: Gmoccapy
Forgot to say I got the error after asking for tool change in the GUI.
  • Fastfred
  • Fastfred
11 Oct 2025 22:46
Category: Gmoccapy
Not Getting errors on start up, but a pop up saying file ended with no percent sign (%) or program end (M2)
File Name: change.ngc
File Size:2 KB
File Name: gmoccapy_p...0-11.hal
File Size:1 KB
File Name: custom_pos...0-11.hal
File Size:1 KB
File Name: CNC_2025-10-11.ini
File Size:6 KB
File Name: CNC.hal
File Size:13 KB
  • unknown
  • unknown
11 Oct 2025 21:45
Replied by unknown on topic LinuxCNC on Raspberry Pi 5
First of all I really want to say thanks for all the work you've put into your projects, you really deserve a couple of beers, if that's your poison ;) or a least a good coffee, damn mate whatever you like to drink. Honestly thanks.
Haven't had a chance to use it or try it out but it looks great. One of the things that has been missing for the RPi IMHO, would be great to see in the mainline Linuxcnc tree.
Would be great if you could add this to the RPi "mega thread" and I'll add a link in the index.
Now a request for an extra feature, any chance for ADC support. Would be great for things that a user wants or needs an analogue input.
  • unknown
  • unknown
11 Oct 2025 21:28
Just a thought, if this still persists with the installer is there a way to check for the existence of the firmware and remove it if found during the stage when the installer on the ISO removed packages ?
I guess this would have to be a custom script, and a band aid type of fix. You know in case this beast raises its head again.
  • unknown
  • unknown
11 Oct 2025 21:23
Replied by unknown on topic Strugling with installation
Sorry just to clarify, when running the installer from the ISO image the raspi-firmware is being installed.
Can confirm upon first login to the newly installed system tuning apt purge removes the offending files. This has been confirmed by running find to look for any files that contain the string raspi prior to running apt purge then after running apt purge.
  • Fastfred
  • Fastfred
11 Oct 2025 20:07
Category: Gmoccapy
Ok I got it , Guess I didn't pay attention just copied and paste Gmoccapy config to get it working not reading if I needed everything.
11 Oct 2025 20:01
11 Oct 2025 19:59
Replied by tommylight on topic Strugling with installation
The installer is definitely installing the raspi-firmware.
Do you mean the Debian installer or LinuxCNC ISO installer?
  • andypugh
  • andypugh's Avatar
11 Oct 2025 19:06 - 11 Oct 2025 19:07
bugs.debian.org/cgi-bin/bugreport.cgi?bug=1065640
It looks to have been recently fixed upstream.
(I am still not clear if you are blaming me, Rod or Roland Clobus)
11 Oct 2025 19:04
Oh cr@p !!!
Thank you for looking into it.
Displaying 12451 - 12465 out of 13404 results.
Time to create page: 0.840 seconds
