05 Oct 2025 23:48
Replied by tommylight on topic Hypertherm hsd130 interface
Category: Plasma & Laser
Yes, those are the "very very dangerous - you will most certainly die if you touch them while powered on and someone fires the torch" parts :)
Except, you do not necessarily have to touch them, even 1-3cm away can irrevocably cause death, depending on ambient moisture.
Again for clarity, do not wire anything on this side.
  • Ayden25
  • Ayden25
05 Oct 2025 22:02
Replied by Ayden25 on topic 7i76eu connection issues
Ah there we are thanks man! I had been doing everything through pncconf and was exiting out and saving changes without realizing it wasent actually writing the file. After modifying the file manually shure as shit were up and rolling.
Cnc machinist by trade lmao but super green on linux cnc and its showing lmao!
  • Cooped-Up
  • Cooped-Up
05 Oct 2025 21:54
Replied by Cooped-Up on topic 5i25t firmware screwup
Category: Driver Boards
I downloaded the one today from the store website, I'll look for that info when I get home later. When I use the reload the firmware works. It's only when I move the jumper it breaks it again.
  • PCW
  • PCW's Avatar
05 Oct 2025 21:44
Replied by PCW on topic 5i25t firmware screwup
Where was it downloaded from?
What are the date and md5sum of the.bin file?
  • PCW
  • PCW's Avatar
05 Oct 2025 21:42
Replied by PCW on topic 7i76eu connection issues
Your mesaflash version is too old to support the 7I76EU  but it found the card.
LinuxCNC 2.9.4 does support the 7I76EU
Are you sure the IP address in the hal file is 10.10.10.10?
  • Ayden25
  • Ayden25
05 Oct 2025 21:32
Strange message from that
"Unsupported ethernet device 7I76eu at 10.10.10.10
No ETHERNET board found"
I am running linux cnc 2.9.4 and as far as I know the eu is supported
  • Cooped-Up
  • Cooped-Up
05 Oct 2025 21:22
I just redownloaded from the website that I was trying today. I am not sure where the last one was pulled. I think I found it on a forum
  • PCW
  • PCW's Avatar
05 Oct 2025 21:15
What does
mesaflash --device ethernet --addr 10.10.10.10 --readhmid
report?
  • PCW
  • PCW's Avatar
05 Oct 2025 21:13 - 05 Oct 2025 21:30
There was a firmware error in 5I25T firmware that was fixed toward the end of last year.
What is your .bin file date and md5 checksum?
The current version is
MD5 (5i25t_7i77_7i74d.bin) = 90c674c34dfdbb3d597f0886768fb830
Nov 22  2024
  • Cooped-Up
  • Cooped-Up
05 Oct 2025 20:41
5i25t firmware screwup was created by Cooped-Up
Awhile ago I had been trying to set up my mesa electronics for a conversion I would like to do. I needed to flash the proper firmware for a 7i77 and a 7i74d and I found the firmware and flashed it. But then it was no longer recognized by the readhmid command or the computer. I have done the fallback jumper thing and am able to flash the firmware and do the reload command and I see it has changed the pins but then when I power cycle and move the jumper it is not recognized again on boot up. What am I doing wrong?
  • bentiggin
  • bentiggin
05 Oct 2025 20:41
Replied by bentiggin on topic Hypertherm hsd130 interface
I believe the high frequency parts are on the other side of the wall to the left. Pic attached of what i think is the high frequency parts.
The torch- and work+ have been identified so that shouldn't be a problem.
  • MatthiasCNC
  • MatthiasCNC
05 Oct 2025 19:19
Replied by MatthiasCNC on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
 When I remove that, the following error occurs.
File Name: linuxcnc.txt
File Size:6 KB
File Name: sudodmesg.txt
File Size:57 KB
If I understand correctly, he has a problem with 6040, which would be the control word.
Unfortunately, I don't understand what the problem is with it. It is present in both files.
  • Aciera
  • Aciera's Avatar
05 Oct 2025 19:01
toggle2nist hangs when pressing an other button at the same time
Category: HAL
To toggle program run/stop you would need to use :
loadrt toggle2nist names=tog2nist0
addf tog2nist0 servo-thread
net net-mist.is-on tog2nist0.is-on <= halui.program.is-running
net net-mist-off tog2nist0.off  => halui.program.stop
net net-mist-on tog2nist0.on  => halui.program.run
05 Oct 2025 18:30 - 05 Oct 2025 18:32
Replied by tommylight on topic Retrofitting HURCO BMC30
Category: Milling Machines
forum.linuxcnc.org/30-cnc-machines/33529...20p-retrofit?start=0
There should be some configs attached there for BMC20, might help you get an idea but i do not think neither use Carousel component.
Edit,
this one uses gray code for 8 tools i think, was way to long ago.
forum.linuxcnc.org/30-cnc-machines/31792...-sbz-130-01-retrofit
  • Aciera
  • Aciera's Avatar
05 Oct 2025 18:13 - 05 Oct 2025 18:50
Category: HAL
The problem is that stopping a program will also switch off coolants (mist and flood). This is inbuilt behavior so by connecting 'halui.program.stop' in your hal example you are clearing 'tog2nist0.is-on' which upsets the logic.
When 'tog2nist0.in' goes true and 'tog2nist0.is-on' is false it sets 'tog2nist0.on' to true until 'tog2nist0.is-on' goes true. It then sets 'tog2nist0.on' to false. (So it basically produces a pulse on 'tog2nist0.on').
See the logic diagram in the manpage:
github.com/LinuxCNC/linuxcnc/blob/0bc97e...nts/toggle2nist.comp
In your case:
When 'tog2nist0.in' goes true it sets 'tog2nist0.on' to true which causes a program stop which forces 'tog2nist0.is-on' FALSE so the component waits forever with 'tog2nist0.on' True.
One way around this would be to change the component to have a maximum waiting time for 'tog2nist0.is-on' to change state.
[edit]
Attached is a modified component.
As an example set '.pulse_length' to 1000. Mind you it will only fix the lockup state not the flawed logic behind the hal construct.
File Name: toggle2nist.comp
File Size:4 KB
Displaying 12811 - 12825 out of 13402 results.
Time to create page: 1.015 seconds
