  • Chock
  • Chock
17 Aug 2025 23:02
getting started , latency and breakout board questions
i must be doing something pretty dumb,   i tried this on the ancient Dell D620  dual booted with windows XP and Ubuntu14? from about  years ago   and i got the same problem.    This is the known good computer to interact with the robot arm , but in windows XP with putty or the robot native software that i think was windows 95.    This native software is not perfect and won't compile a program, but it will run the arm from the terminal
So maybe it is not my current version of ubuntu12.
Please don't ask how i got the ubuntu 14.
  • Chock
  • Chock
17 Aug 2025 22:44
what about   something like this
" sudo apt-get install minicom # Install if not present
minicom -D /dev/ttyUSB0 -b 115200 # Connect to device at 115200 baud
but replace the usb0 with S0, and then fix the rest  baud R, and parity, etc
  • Silverback
  • Silverback
17 Aug 2025 22:33
Replied by Silverback on topic qt_auto_probe_tool with large tool offset
Category: Mill Library
I was able to resolve it.
Apparently a plain text editor is necessary. Once I copied into Notebook++ and then into the nc files directory, everything started working.
I appreciate your answer and willingness to help.
  • COFHAL
  • COFHAL
17 Aug 2025 22:29
Replied by COFHAL on topic AX58100
AX58100
Category: EtherCAT
I already understood how to do that conversion.
  • COFHAL
  • COFHAL
17 Aug 2025 22:18
AX58100
Category: EtherCAT
I don't understand how to convert steps to hex in the XML file. Could you explain?
200.0 = 43 48 00 00??
  • Chock
  • Chock
17 Aug 2025 22:17 - 17 Aug 2025 22:33
logout is just " exit " correct
and then the log in is automatic
i tried exit,  and it shuts down the terminal window,
when i open the terminal window back up ,  i think i am logged in automatically
and i tried the stty line again ,  no luck.
 i power cycled and still no luk
Does there have to be live activity on the serial port ??? for this to work?
  • Mars
  • Mars
17 Aug 2025 22:14
Replied by Mars on topic Remora - Can't get it out of estop....
oh....that is why. Thanks for the answer. You may consider putting something in the documentation to flag this so that others don't try this path. I need to regroup and figure out the next cheapest HW to work with the Rpi5. Do you think the STM based boards will be around for awhile? I was hoping to go Remora but I have to think about that parallel port board that someone makes for the Rpis.
17 Aug 2025 22:13
Logout out then log back in, then you'll be good for your permissions and group membership.
Yeah, i forgot this, sorry.
  • unknown
  • unknown
17 Aug 2025 22:06
  • Chock
  • Chock
17 Aug 2025 21:38 - 17 Aug 2025 21:48
Good afternoon Tommylight thanks, I tried something pretty similar to this with out the < > .
That was several tries back
i just tried it and i added the < > with my username in the middle of the<> and i got a
bash: syntax error near unexpected token 'newline'
next i tried without the < > and i got asked for my password,       that is good correct?
i made a typo next, trying the stty -F /dev/ttyS0
and on the 2nd try with the stty i got permission denied again.
if i make a typo do i lose my root access? and need to start over with dialout line ?
i tried the whole process starting with the  " ls " again,  no typos and still permission denied
Since the command line has my name twice that means i am logged in correct?   does that mean  i am logged in a both user and admin?
17 Aug 2025 20:58
ls -l /dev/tty*
then
sudo usermod -a -G dialout <username>
replace "username" with your actual username on that pc
  • AkkiSan
  • AkkiSan
17 Aug 2025 20:52
Replied by AkkiSan on topic How to fix "Queue is not empty after probing"
A lot of things could go wrong there; why not check the "obvious error" ```[tm]``` first?
Probably just a race condition?
if (settings->probe_flag) {
    int queue_empty = 0;
    int retry = 0;
    static int probe_count = 0;
    probe_count++;
    while ((queue_empty = GET_EXTERNAL_QUEUE_EMPTY()) == 0 && retry < 100) {
        esleep(0.010);
        retry++;
    if (retry > 0) {
        logDebug("probe #%d: waited %dms for empty queue (state: %d)",
                probe_count, retry*10, queue_empty);
    CHKS((queue_empty == 0),
         "NCE_QUEUE_IS_NOT_EMPTY_AFTER_PROBING (probe #%d after %dms)",
         probe_count, retry*10);
Out testing,
AS
  • Chock
  • Chock
17 Aug 2025 20:47 - 17 Aug 2025 20:51
Good afternoon I have a question,   It is both linuxCnc, and just Linux.
      First   I have been running LinuxCnc from a  Startup Boot thumbdrive.    I had a friend help with the original Linux install, and LinuxCnc install on this computer  Lenovo intel g73.
     At some point I think  i would like to get rid of the thumbdrive boot ,  and have this computer just run linuxCnc , or if possible Linux Debian 12, and LinuxCnc .     But for now i am pretty happy with the LinuxCnc on the thumbdrive and i have  Linux Debian 12 without the thumbdrive.
I am still learning both Linux and LinuxCnc for sure.
     I have a very old robot arm that i can run on a windows terminal .   I ASSUME i should be able to run the arm from a Linux terminal????
BUT
I can not seem to change the serial port parameters in either Linux, or LinuxCnc.
I have tried several times to change the serial port parameter with various different terminal  commands?
    I have tried
             "     stty -F /dev/ttyS0 57600 cs8 -parenb -cstopb   "     i have also tried to add " sudo" in front of the line.
i always get permission denied.
    I believe i have root access,   but maybe not.    i have tried to change my user status to  a  " ALL "   and some other things,  but no luck
I am not sure if this is a problem with my install,  or if i need a more potent permission .
I thought i was the only user on this install and i thought i have    "  ALL access"   but apparently I don't..
Shouldn't i have the same access in linux and LinuxCnc
i did mange a command that listed all my permissions and i am pretty sure i have at least admin level
how can i get permanent root access
thanks
  • scotta
  • scotta's Avatar
17 Aug 2025 20:45
Replied by scotta on topic Remora - Can't get it out of estop....
Hi Mars,
Unfortunately, there is no support for the LPC based boards with the RPi5 version of the Remora component. The LPC chips need the CS line to toggle on each byte being sent out. This would be why it's not coming out of eStop.
Also, the firmware for the LPC boards is outdated in terms of the Remora data structure.
  • PCW
  • PCW's Avatar
17 Aug 2025 20:41
Replied by PCW on topic Issues with MESA 7976eu analog-in
Category: Driver Boards
If the NTC is in the positive side of the divider, its the equivalent
of lowering the negative side resistor value to its current value
in parallel with 11K Ohms. If it is setup this way, you could raise
the value of the negative side resistor so the parallel combination
on this new resistor and the 11K is the same as the old resistor.
Displaying 13546 - 13560 out of 14173 results.
Time to create page: 1.108 seconds
