08 Aug 2025 23:33
modprobe: ERROR: could not insert 'ec_master': Key was rejected by service
Category: EtherCAT
Please post output of ip a
He did, so why ask again?
On topic, that seems an issue with the EtherCAT key, it has nothing to do with networking, also supported by "modprobe" in the error as the module could not be loaded/inserted.
  • ihavenofish
  • ihavenofish
08 Aug 2025 23:32
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
ATC design is final. Also did up a quick 4th axis rotary table using a surplus harmonic. The body is a steel block, faceplate is steel. printed nylon dust seal, and then an 60mm motor shaft coupling. It takes a  52mm round quick change plate for vises. Just enough centre height to spin the small xindian h67 vise with a 4" long work piece. Total cost with the harmonic drive, 200w ethercat servo, machined parts from JLC is in the $800usd mark. Not bad! :)  There are a small amount of these surplus harmonics, so if someone wants to build their own high quality rotary, I can give you the files. (I cant post publicly on here though). Note that the precision of the housing block is probably not going to be perfect, and you may way to scrape in the bottom to be dead square square.
  • ihavenofish
  • ihavenofish
08 Aug 2025 23:20
Replied by ihavenofish on topic PathPilot V2 source code
Category: PathPilot
This is still not the build with the jerk limiting right?
  • andypugh
  • andypugh's Avatar
08 Aug 2025 22:58
Replied by andypugh on topic injection mold machine custom gui
I did a hydrauic press brake without conventional axes of G-code some time ago. I am not sure that was worth the trouble in the end, as with axes you get homing and speed control for free.
forum.linuxcnc.org/30-cnc-machines/42100...ions?start=10#204551
There might be some reusable ideas there though.
  • PCW
  • PCW's Avatar
08 Aug 2025 22:10
Starthilfe Retrofit ISEL CPM4030 MESA7i95T+7i83
Category: Deutsch
You don't need any PWMgens,
The PID output would be connected to the hm2_7i95.0.7i83.0.0.analogout-NN
pin in hal
  • Chris91
  • Chris91
08 Aug 2025 21:49
Category: Deutsch
Hallo,
ich benötige mal etwas Input...
Ich versuche einen Servocontroler mit +/-10V anzusteuern über die 7i95T+7i83.
Ich habe mir jetzt 4 PWMgen per Bitfile erstellt, verstehe jetzt aber noch nicht, wie ich die Verbindung
pid.x
hm2_7i95.0.pwmgen.00
hinbekommen soll?
Kann mich wer in die richtige Richtung weisen?
  • Firehunter
  • Firehunter
08 Aug 2025 21:36 - 08 Aug 2025 21:37
Replied by Firehunter on topic M66 keeps waiting
M66 keeps waiting
Category: G&M Codes
The other L-modes also don't work. Timeout doesn't work. Nothing happens after 10 seconds. Yes I'm looking at the digital-in-xx pins. LinuxCNC version on the splash screen is 2.9.0~pre1+git20230208.f1270d6ed7
  • andypugh
  • andypugh's Avatar
08 Aug 2025 20:51
Replied by andypugh on topic M66 keeps waiting
M66 keeps waiting
Category: G&M Codes
L3 is correct for this application, but out of interest, does L1 work?
Does the 10 second timeout work?
Which LinuxCNC version?
In halshow are you looking at the motion.digital-in pins? (rather than the IO pins)
  • andypugh
  • andypugh's Avatar
08 Aug 2025 20:35
Replied by andypugh on topic Basic hal config
Basic hal config
Category: HAL
forum.linuxcnc.org/38-general-linuxcnc-q...ideas?start=10#82686
Maybe.
That's shown embedded in Touchy, but it could be standalone.
I also did a similar thing with a hydraulic press-brake, but don't know how that worked out in the end. That didn't use LinuxCNC at all, it was pure HAL. But I am not sure that was the best of ideas in the end.
  • andypugh
  • andypugh's Avatar
08 Aug 2025 20:23
Replied by andypugh on topic New PC build: Asrock N100DC
I think that's about as good as it gets, and it's perfectly usable for most purposes (especially if you don't plan on using software step generation or encoder counting)
  • andypugh
  • andypugh's Avatar
08 Aug 2025 20:19
Replied by andypugh on topic Warning before homing?
Category: Basic Configuration
Gmoccapy is written in Python, you might want to look at just adding some more code. If you know Python, that is.
  • andypugh
  • andypugh's Avatar
08 Aug 2025 20:16
Replied by andypugh on topic how to make M7 (mist on) generate step pulses
Category: G&M Codes
Just open the terminal and type
halcmd setp stepgen.4.velocity-cmd 40
Anything that is a valid HAL command for the HAL file can be run from the command line with "halcmd"
If you want to do more than a single line, then
halcmd -kf
will open an interactive HAL session where you can type commands (without halcmd) with tab-comoletion and command history.
To exit the interactive session, type "exit"
But if you want to control it from a switch, or pot, or VCP then that can be done too.
  • joshualee777
  • joshualee777
08 Aug 2025 20:12
Replied by joshualee777 on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
Hello, I reset the device to factory defaults as you advised, but the "Amplifier Fault" error still persists. Is it because the DC setting is not set correctly? I'm wondering if you have any other advice.
  • tcbmetalworks
  • tcbmetalworks
08 Aug 2025 20:10
Basic hal config was created by tcbmetalworks
Basic hal config
Category: HAL
Hello, I am trying to build a cnc band saw. I am looking to build a custom python gui. Does anyone have a example of a super minimalistic hal configuration? All i would like is to power outputs on and off some inputs and a linear incremental Encoder to track position i see there's lots of configurations for plasma mills lathes etc but not much that is this simplistic.
  • andypugh
  • andypugh's Avatar
08 Aug 2025 20:05
Replied by andypugh on topic Controlling existing motors with resolvers
Category: Driver Boards
Resolvers are very good (and very expensive) they will never break. (the bulbs in old optical encoders would burn out eventually, LEDs tend to last longer, but can still fail)
Given that only one drive has failed, have you looked at repairing it? It's unlikely that a hybrid system of one servo under LinuxCNC control and one under original control control would work very well.
Have you asked Mesa if the 8i20 is likely to come back into stock?
Do you know the power and voltage spec of the motors?
(I am on a train on mobile data, not in a good position to look through documentation links)
Displaying 13996 - 14010 out of 14179 results.
Time to create page: 0.551 seconds
