  • tivoi
  • tivoi's Avatar
19 Jun 2025 05:45
  • Kieran
  • Kieran
19 Jun 2025 05:18 - 19 Jun 2025 05:20
Replied by Kieran on topic How to jog when beyond soft limits
Category: EtherCAT
On my AXIS gui setup, I can switch to "joint mode" by hitting $ (shift-4)
which lets the servos jog slowly back into the normal travel range. Hit $ again to go back to "world mode" to run as normal from there. Im guessing the other GUI have an easy way to get into joint mode as well. you could also manually turn the ballscrew a little :D
  • Kieran
  • Kieran
19 Jun 2025 04:58 - 19 Jun 2025 05:05
Getting Ebay 2.6kw ethercat kit going.
Category: EtherCAT
Im trying to get my 2.6kw spindle servo going. its got a P200SE drive. the instructions are written in Chinese. I used google translate and it worked pretty good. Right now im running it as a Z axis just to see if i can get it working. I got my XML setup enough that Linuxcnc reads the encoder no problem. the servo powers up and holds position along with my stepperonline X and y servos. my current roadblock is that its not listening to commands and doesnt move and it gets a following error shortly after. if i power off and turn the motor the DRO moves the distance expected so that's a good sign. the servo load meter on the PYvcp is workign for this servo too, when i "fight" the servo. i must just be missing something simple in my XML?
lcec_configgen gives me this
Warning: Spoiler!
my xml so far
Warning: Spoiler!
  • unknown
  • unknown
19 Jun 2025 04:45
Replied by unknown on topic HP T510
HP T510
A little underpowered, if you have one give it a go, if not I wouldn't recommend buying one.
T630 isn't a bad choice for connecting to a mesa Ethernet card.
T610 Plus maybe ok for a Parallel Port system with an RTAI kernel, or Debian Wheezy might be the go. 2.7.x Linuxcnc
  • arijitdutta
  • arijitdutta
19 Jun 2025 03:45
Replied by arijitdutta on topic Weird problem happening during g71, g70 cycle
More findings:
I am running g95 with a manual bldc controlled spindle. The jerk happens at around z -17.2 everytime no matter if the spindle was running at 1200 rpm or stopped or at 100 rpm. It never happens before that or after that no matter how much time was given for the axis to reach at that point. So i can safely rule out any problems with electrical noise and such issues (though my control panel isnt good enough).
Now if i change the backlash from 0.08 to 0.0- the problem vanishes.
Even on the graphical interface it looks like a straight like, g70, g71 trie to do a small move at z-17.2 for reasons unknown, for which the backlash motion is triggered. I am not sure yet. Let me increase the backlash to much higher numbers to see if the jerk increases or stays the same as before.
  • Sekai
  • Sekai
19 Jun 2025 03:07
Replied by Sekai on topic LinuxCNC MillTurn
LinuxCNC MillTurn
Thx for the reply.
I know that linuxcnc has 9 axis in total and the name in different.
For now i have the linear guide rails and i'm working in Solidworks to build the 3d model of the entire build.
What i dont know is how to use linuxcnc for the spindle configuration.For example should i use a servomotor for the spindle head, main and subspindle or use a different style like a regular 3 phase motor with a VFD comanded by RS485 and then when i need position i can switch to servomotor or a stepper motor.
The advantage will be with 3 phase motor i can get higher rpm.
  • nunolopez
  • nunolopez
19 Jun 2025 02:45 - 19 Jun 2025 02:45
HP T510 was created by nunolopez
HP T510
Hello I wanted to know if it was possible to install linux cnc on the HP T510?
Here's a link for the thin client specs www.parkytowers.me.uk/thin/hp/t510/
  • kubes
  • kubes
19 Jun 2025 02:35
Replied by kubes on topic How to jog when beyond soft limits
Category: EtherCAT
This is just soft-limits as I am using absolute encoders and while I "home" it only sets the axis as homed, there is no travel or switches involved. I may add hard-limit but that is really more of a belts and suspenders solution.
I am not understanding how HOME_OFFSET will fix this for soft-limits. My understanding of HOME_OFFSET my be wrong. but it will offset the home and then the soft-limits will be offset, but I can still jog right to them, and my "little over error" will still be an issue.
Does the LIIMITS OVERRIDES only there for hard limits or will also work for soft-limits?
This all can be just me and my very limited understanding of how to correctly set-up high resolution absolute encores and soft-limits.
  • kubes
  • kubes
19 Jun 2025 02:19
Connecting a tool setter and touch probe at the same time
I took a slightly different direction.  By adding a "probe-connected"  hw pin, I can select probe or toolsetter.  This also has the benefit of checking if the probe is connected in the probe sub routine.
As my probe uses a USB-C connector, it's not a USB device; it simply uses D- and D+ as the trigger pins.  And the fact that USB-C can be flipped, I was able to use the CC pins (which are tied together on the probe's USB port) to have a hardware pin when the touch probe cable is connected.
BTW: the toolset I have is NC, so I needed to invert the pin. (I guess lcec does not support '-not')
here the sniplet of my hal:
loadrt mux_generic config="bb2"
addf mux-gen.00 servo-thread
# the UI is connected in postgui.hal
# this handles the hw, which probe is connected
# 3=probe-connected, 4=probe-trigger (NO),  5=tool-setter-trigger (NC)
net probe-connect lcec.0.Z.din.3 => mux-gen.00.sel-bit-00 motion.digital-in-00
net probe-in mux-gen.00.out-bit => motion.probe-input
net probe-trigger lcec.0.Z.din.4 => mux-gen.00.in-bit-01
net toolsetter-trigger not.1.out => mux-gen.00.in-bit-00
net toolsetter-trigger-inv lcec.0.Z.din.5 => not.1.in
  • arijitdutta
  • arijitdutta
19 Jun 2025 02:10
I am running this off a 7i96s. I never changed the servo period, so it should be default. The P value for both axis is 1000
  • PCW
  • PCW's Avatar
19 Jun 2025 02:06
Need some debug help isolating a spindle problem
“hm2/hm2_5125.0: Smart serial card hm2_5i25.0.7176.0.0 remote error = (27) Over Current”
Means there is an an issue (most likely a short) on one of the 7I76 field outputs
  • dokwine
  • dokwine
19 Jun 2025 01:42
Particulars on my set up at the end. My machine crashed and I’m way behind on a deadline. Thought I’d throw some questions out there in the hope of getting to the bottom of this quickly. Running 2.9.2 QT Dragon HD.
Everything has been running well (software at least) for the past 6 Mo. Today I was making a cut similar to other work I’ve been doing and the spindle stopped spinning half way through the job.  QT showed the error “hm2/hm2_5125.0: Smart serial card hm2_5i25.0.7176.0.0 remote error = (27) Over Current” I assumed this involved my Modbus connection to my Hitachi VFD and there was a VFD complaint re: the spindle. I power reset everything and restarted, hoping to get lucky.
After restart and Homing, in QT Dragon MDI I issued an s5000 which should start the spindle, right? Nothing.
I pulled up Halshow for the wj200 driver for the Hitachi VFD. The Modbus watchdog is ticking, the heat sink temp seems to update, and it shows ready and enabled. s5000 does not show the commanded-frequency (Driver setting) to the VFD however.
When I unlink commanded-frequency and attempt to set with halshow, I lose the Modbus watchdog. With s5000 set, the VFD just shows 000 on its display. The fluke in AC mode seems to agree there is nothing going to the spindle.
So. Everything else on the machine is healthy/ power is good. The VFD seems ok (watchdog, sets ready when machine enabled, HS temp). I’m prepared (sorta) to believe that the spindle died for some random reason, BUT I can’t get past the fact that I don’t seem to be able to command the VFD to turn the spindle on.
Maybe I’m going at this wrong? I’m avoiding trying to command the VFD from its front panel because the process is error prone (for me at least) and I wouldn’t know if the spindle was busted or I just screwed up the VFD commands.
Thanks for any suggestions. I’ll need to start doing things the old fashioned way pretty quick I I don’t get this thing running.
Machine summary: Gantry style router. Clear path servos. Quad core I7 with 5i25/7i76. Hitachi WJ200 VFD. 3hp Chinese WC spindle with ATC.
  • ttt
  • ttt
19 Jun 2025 01:39
How to link existing glass scale DRO readout to LinuxCNC for cheap
Category: Driver Boards
I finally finished a little project I had in my mind for a long time. I have some pretty common TOAUTO glass scale DROs with readout which I always wanted to connect to my LinuxCNC machine(s) to get DRO output on my touch screen and maybe also experiment with closed loop operation.
It can be done cheaply, total cost is maybe $30 in parts total, no custom parts. In essence it's based on a RP2040-Zero and a TXS0108E level shifter. The RP2040 acts as a regular USB device which can be accessed from a custom HAL component. This is not using some serial or ethernet connection but it's a full speed USB device implementation which means I can get about 1000 readouts per second. Is it as reliable as ethernet? I would not think so, but for $30 you can't ask for much more and my ethernet ports are limited :-)
The way the electronics work is that you splice into the existing signals on the DB9 connectors on the DRO readout. So you get to keep your existing DRO panel fully working. My current hardware setup for that is rather janky, but modifying the existing DB9 connectors will probably be easier and nicer looking. The most tricky part here is that the cable lengths need to be as short as possible and ideally shielded if you want to avoid noise affecting the signal.
More information, full code and images for this project here:
github.com/tinic/rp2040-encoder
Someone should be able to solder this up in an afternoon after ordering the parts from Amazon the day before...
  • PCW
  • PCW's Avatar
19 Jun 2025 01:24
Replied by PCW on topic Mesa 7i96s step/dir issues
Sounds like maybe a damaged step/dir output.
It could also be marginal drive if you are using differential
wiring to a step motor drive. (its suggested to use
single ended drive with opto-isolated step/dir inputs
and differential drive with servo drives with line receiver inputs)
You can check the STEP/DIR outputs with a voltmeter.
 When the 7I96S is first powered up, the STEP/DIR pins will
be in one state and when LinuxCNC is launched (before starting
any motion), the states will be reversed. With no load, the outputs
should  equal the 5V supply  voltage in one state and near 0V in
the other state.
  • DMNZ
  • DMNZ
19 Jun 2025 01:17
I've been looking into RIO for couple of days, reading forums and one question i can't find the answer for, may be it is obvious for all but me, what is the data protocol used in RIO over the spi? is it the same as Mesa LBP16 commands requiring hostmot2 or something else?
Displaying 14836 - 14850 out of 15366 results.
Time to create page: 2.453 seconds
