16 Jun 2025 00:46
Replied by tommylight on topic Email Notification?
Email Notification?
Category: Forum Questions
Oh i am sure:
  • directandrew
  • directandrew
16 Jun 2025 00:34
New to linuxcnc, basic question for DRO modes with encoded handwheels
Based on what im reading, it does seem ill need a larger card to handle all the limit switches and 3 encoders, one for each hand-wheel. I will prob go RJ45 as the parallel ports are less and less these days.
Thinking this guy, not cheap but one stop shop correct?
store.mesanet.com/index.php?route=produc...id=399&search=7I76EU
  • spumco
  • spumco
16 Jun 2025 00:27
GUI that somewhat resembles haas or fanuc workflow.
Is the Fanuc style of Gcodes display really better then linuxcnc's?
Not in my opinion.
There are quite a few characteristics with Fanuc (and other commercial offerings) which are user-unfriendly compared to LCNC.  The gcode display is a good example of that.
Another one I hate is when my Fanuc 21TB removes the tool offset when I switch from MDI to jogging and then to some other mode.
  • snowgoer540
  • snowgoer540's Avatar
16 Jun 2025 00:01
Replied by snowgoer540 on topic Email Notification?
Email Notification?
I wouldn't be so sure.  I haven't received the moderator emails (email for every single post) since March, and it was sporadic before that.  I haven't received an email for a thread I asked to be notified of replies for in ... years.
At this point it's not a complaint, I've just accepted it, getting an email for every post is excessive anyways.
  • DMNZ
  • DMNZ
15 Jun 2025 23:47
Replied by DMNZ on topic Error finishing read... *sigh*
yip, very similar to what i am having on mine, interesting to see your latency histogram figures.
i still see occasional 1+ms packets once in a while mostly when I heavily use disk or usb which interrupt pci bus, or may be it is just noise and bad cable, but as i mentioned hm2_eth can work around it unless you get something over 3-4ms or 3-4 long packets in a row. then it will error out with can't finish read.
cheers!
  • chernogorsky
  • chernogorsky
15 Jun 2025 21:57
JGL-80/1.5R24 ATC 1.5kW spindle Used (about 60-80 hours) for sale. US/MA
Category: User Exchange
slightly used JGL-80/1.5R24 for sale.
About 60-80 hours of work 1500$ + shipment
Can add FR-D720S-1.5K-CHT + FR-PU07 (both slightly used) for another 200$
Has its configuration for mesa / rs485
  • EmilDLo
  • EmilDLo's Avatar
15 Jun 2025 21:39
Cumark Closed-Loop VFD with EtherCAT (non-CiA402) Configuration
Category: EtherCAT
Hello EtherCAT gurus,
After generous help from OncedLoved and AI we have reached the end of our troubleshooting patience trying to resolve the strange behavior of my new closed loop VDF (Cumark 15 KW) connected to LinuxCNC via EtherCAT (non- CiA402).
Current Condition:
  • The VFD is properly set up for the spindle (motor parameters and encoder) and it runs perfectly using the keypad.
  • The drive successfully enters OP mode when LinuXCNC starts up and the PDOs are displayed in halshow (see attached screenshot and xml)
  • In halshow, when I set Ref 1 (motor speed) to 500 and ControlWord to 2178 (decimal for hex 0x0882 = Start Command), the spindle instantly runs to 500rpm as expected.
  • After a few seconds the motor speed changes to 2178 rpm! As if the motor reference value is the decimal start command value. This can happen from 10-90 seconds after the spindle is turned on.
  • Then I set ControlWord to 2177 (decimal for hex 0x0881 = Stop Command), and the spindle unreliably either:
    • Turns off after a delay of 30 to 120 seconds, or
    • the motor speed changes to 2177 rpm after a similar delay range, and then turn off after and additional delay range.
  • As a result, the spindle eventually turns off but not instantly.
  • Actual values Act1 and Act2 are either displaying the wrong value or there is also a delay.
  • This strange behaviour happens when controlling the VFD from TwinCAT as well. So I am guessing that something in the drive is not setup correctly.
Questions:
  1. What is causing this inconsistent delay behaviour?
  2. Anyone experienced in custom EtherCAT configurations (non-CiA402)?
  3. How do I convert decimal values transmitted from the VFD  to legible Drive Status Word: (vfd manual page 59 section 6.05)
Attached is:
  1. ethercat-conf.xml (just testing the VFD - slave 0)
  2. generic ini and hal files for testing
  3. spreadsheet of VFD ethercat relating settings and PDO mapping
  4. Link to vdf and ethercat card pdf manuals, and xml from Cumark.
  5. screenshot of the lcec hal pins when spindle off and on
  6. Pictures of the machine frame build and spindle for your interest
It would be great to get this running and I am sure others would find this useful otherwise I would switch for Modbus or analog (not ideal).
Your expertise in this nuanced topic would be greatly appreciated!
Background about the Build in case you are interested:
CNC milling machining for my business in designing and building scientific instrumentation. The frame is made out mineral casting by Muller (Germany). The travel is 600mm X x 500mm Y x 350mm Z. It has 23 23-bit absolute encoders, AC Servos driven by EL8 Leadshine drives. It has a DECI 24K rpm, 15 kw continuous, 18 kw peak HSK 63f liquid cooled direct drive spindle controlled by a CUMARK closed loop VFD hopefully via ethercat.
  • PCW
  • PCW's Avatar
15 Jun 2025 21:18
homing with Phase Z encoder on MESA 7i96s
To check, in halcmd:
sets b-index-enable true
and watch b-index-enable in halshow
Then move the axis past an index mark
b-index-enable should go false when the index is detected
  • JackRay
  • JackRay
15 Jun 2025 19:45
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
hello,I've managed to set my PID.I've mounted an encoder directly on my machine B axis. My encoder is of the phase type A+,A-;B+,B-;Z+,Z-.the feedback is correct on my axis position. However, it's impossible to detect my Z0. I have a 7i96s and I've connected my two Z+,Z- wires to pins 13 & 14 of TB2 on my card. My .hal file is correctly configured for homing with this Z phase. I've tested 5 encoders of the same type. but I can't find the Z pulse.Is there a trick? Can anyone help me? Thanks
  • cakeslob
  • cakeslob
15 Jun 2025 18:48
The modal/active gcodes personally I find them to be more/less the same. I dont really find it any more readable than linuxcnc. They are both just a jumble of g and m codes with F S H T at the end. I just takes more space with coloums instead of rows
  • SebastianM
  • SebastianM
15 Jun 2025 17:50
Replied by SebastianM on topic Error finishing read... *sigh*
this is crazy!! after applying your parameters, my ping went down from 1.xx to 0.3xx
Thx so much.
  • aeth
  • aeth
15 Jun 2025 16:47
Tool changer script was created by aeth
Tool changer script
I want to use an ATC spindle with a rack tool changer. I was struggling to find some ready-made script I could use and perhaps modify that would fullfill this goal. Is anyone aware of an existing implementation that was tested/proven by some people that does this? I was able to find some carousel tool changer scripts/designs, but I explicitly need a simple rack solution since the machine is a router with 1m length I can use for holding plenty of tools.
  • zajc3w
  • zajc3w
15 Jun 2025 16:21
Replied by zajc3w on topic Magnetic scales on new gantry mill
Megnetic are cheaper but more dust tolerant, just like rotary encoders.
Pros are price and dust/ contamimation tolerance, unless you get them full of steel shavings they will work.
Optical, glass scales will fail sooner than magnetic if you install them within fine dust presence area.
Big con is magnetic field sensitivity. Use of magnetic holders for coolant/air nozzles may shift your readings.
My(£100 motor and driver) magnetic encoder servo motors suffer so bad(plastic encoder covers) can make them rotate 3°(0.1mm axis move witn 10mm pitch screws) by putting magnetic indicator base next to them. Running spindle makes z motor 120mm away move the axis up/down 0.02-0.05mm and with right spindle speed it would start oscillating into oercurrent error. swapped the motor to optical encoder(£40 extra) and it all went away...
15 Jun 2025 16:15
Email Notification?
E-mails are working for sure.
  • SebastianM
  • SebastianM
15 Jun 2025 15:55
Replied by SebastianM on topic Email Notification?
Email Notification?
Hello my friends.
I dont receive any notifications as well.... I checked my spam folder and I checked the option to subscribe several threads... but no emails at all...
Displaying 14986 - 15000 out of 15377 results.
Time to create page: 0.458 seconds
