  • besi99
  • besi99
15 May 2025 23:09
Issues installing LinuxCNC was created by besi99
Category: Installing LinuxCNC
Hello,
I just installed my first Linux version on an old Thinkcentre i have laying around. Iam planning onbuilding a new CNC using LinuxCNC so I thought maybe I can and lear how to use it before i finish my CNC. Kinda just to get used to Linux.
So after like 2 hours I finally managed to get debian 12.10.0 running on my Thinkcentre. Then I started to follow the instructions on the LinuxCNC page.
I did the updates:
sudo apt-get update
sudo apt-get dist-upgrade
Then I installed the Preempt-RT kernel
sudo apt-get install linux-image-rt-amd64
everything worked fine. After the restart it selected the right linux RT version.
So the issue starts here.
If i click on the link for the linuxcnc-install.sh file it doesnt download anything. So where exactly do I get the script? Iam probably just to stupid to understand it.
Also chmod +x linuxcnc-install.sh doesnt work. I have even tried opening an txt.file and naming it linuxcnc.install.sh with the script from the browser. But still nothing.
Found another thread with simillar issue
$ chmod +x besnik/home/Downloads/linuxcnc-install.sh
Or better yet
$ cd besnik/home/Downloads/
$ chmod +x linuxcnc-install.sh
Always says No such file or directory.
Does anyone have an idea what I am missing I can already deel its something easy to fix I just dont see it. Kinda embarrassing asking for help :D
15 May 2025 22:43
Replied by tommylight on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
Moved to QtPyVCP section.
  • Doc_emmet
  • Doc_emmet
15 May 2025 21:46
Install Probe Basic was created by Doc_emmet
Install Probe Basic
Category: QtPyVCP
After installing and configuring Probe Basic I always get these errors, the user_tabs folder is present:
  File "/usr/bin/probe_basic", line 8, in <module>
    sys.exit(main())
  File "/usr/lib/python3/dist-packages/probe_basic/__init__.py", line 20, in main
    qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
  File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcp
    run(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in run
    launch_application(opts, config)
  File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 78, in launch_application
    loadWindows(config)
  File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 230, in loadWindows
    window = _initialize_object_from_dict(window_dict)
  File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 210, in _initialize_object_from_dict
    return obj(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 53, in __init__
    self.load_user_tabs()
  File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 87, in load_user_tabs
    user_tab_folders = os.listdir(user_tabs_path)
FileNotFoundError: [Errno 2] Datei oder Verzeichnis nicht gefunden: 'user_tabs/             # REQUIRED Setting for Probe Basic'
Maybe someone can shed some light on the matter for me.
  • PCW
  • PCW's Avatar
15 May 2025 20:51
mesa 7i73 4x8 keypad problems on KEY8 input
Category: Driver Boards
Normally we would not use hex files at all because the standard way to update
would be over serial. I will look into why the serial update fails.
  • fc60
  • fc60
15 May 2025 20:47
linux cnc keeps bending shortcutting to the next line.
Greetings,
I only gave you half of the equation.
Insert G64 P0.001 into the startup line at the top of the program.
The P parameter is what does the work.
If this cures the issue, modify your post to insert it automatically.
Cheers,
Dave
  • RNJFAB
  • RNJFAB
15 May 2025 19:58 - 15 May 2025 20:07
Job not showing in position - 2.9.4 - v2.9-238.315
Category: Plasmac
Thanks Snow,
You always do a great job, i'm just a bit different.
Using the laser button is 3 clicks and wait for lag. first to "laser" then "mark edge" then "set origin", then the machine moves.
With the user button, its a one click and the machine moves to where i need it, zero's, and i'm ready to start cutting. the code i'm using is the one I found worked many years ago and i have just kept it. i also have another button used for the air scribe offset (albeit still a work in progress). I have only had this issue since the update to 2.9.4.
My normal operation flow goes.
home machine
sheet on machine
import drawing
align x,y using laser
click laser offset to zero torch on where i lined up laser pointer
frame to check cut file will fit (done alot when cutting multiple parts from sheets that have already been cut)
then cut
I'll try the new code now and see how it all goes.
new code is G10 L20 P0 X0 Y0 \ G0 X-2.5 Y104.3 \ G10 L20 P0 X0 Y0
Works perfectly, thanks again Snow !!
  • unknown
  • unknown
15 May 2025 19:54
Why does it seem like everyone here is Australian?
The plants can be pretty rough as well.
The beer's good, no I no longer indulge.
The back roads are great for a fang & scratch.
Funny thing is Australia is hot & dry but Aussies have a rep for being pretty quick on a wet circuit, go figure.
Another good thing is the drive in bottle shops, ya can get beer, wine, spirits and chips and other party supplies without having to get out of your car. Unlike some nanny state countries where you can't even buy beer & spirits in the same place. The same country that was so scared of Trump they voted in the same party that made them a laughing stock that was led by Castro's son and used to club baby seals. The same country that you can't walk the street with a beer or other drink in your hand, and you pay for stuff with loonies. Oh and don't ask for a hamburger with the lot, they can't fathom it.
To be fair we only got electricity yesterday and fire the week before. Fresh water, that's for cowards that are scared to go to creek to grab some water cos there might be a salty wanting to eat you. Or a shark that wants to bite a leg off, a blue ring that wants to end your day.
  • atrex77
  • atrex77's Avatar
15 May 2025 19:25
W5100S-EVB-PICO stepgenerator and encoder driver
Dear linuxcnc users,
i want to introduce my new open source project based on the W5100S-EVB-PICO . ~10 USD (raspberry pico clone)
features:
1 to 8 step generator with 255KHz maximum output in this version, (possible higher freq) enough for 15m/min with 0.001mm
1 to 8 quadrature encoder counter with 12.5MHz theoretical maximum counting frequency.
current version in the github page is support 4 stepgen and 4 encoders
linuxcnc driver supports multiple instances
planned direct SPI communication with raspberry-pi4 (with normal pico)
github: stepgen-encoder
  • Milkof
  • Milkof
15 May 2025 18:32
  • Aciera
  • Aciera's Avatar
15 May 2025 18:02
Replied by Aciera on topic Preview plot with touchscreen gestures
Category: Gmoccapy
Nice, thanks for sharing.
  • Wischi
  • Wischi
15 May 2025 17:11 - 15 May 2025 17:13
Category: Gmoccapy
Hello everyone,
i was facing the same problem preview plot bug in LinuxCNC 2.9.4 with Gmoccapy 3.4.9 as described in this thread:  Question: Gmoccapy 3.4.2 and touchscreen
Preview only moves a couple of mm then stops.
So i decided to change the gremlin.py to use the Gtk3 Gestures. With the modified version you can rotate the preview with one finger again, but also zoom in and out with pinch gestures as well as pan with two fingers. In X, Y, Z view the rotation is locked, only zoom + pan. As of right now it will disable the mouse, but my machine only has the touchscreen so for me its no problem.
~$xinput list show my touchscreen as:
eGalaxTouch Virtual Device for Single
eGalaxTouch Virtial Device for Touch
No further driver installed. Tested with fresh 2.9.4 live iso.
Just replace gremlin.py in /usr/lib/python3/dist-packages/
I just wanted to drop this file in here in case someone has the same problem. It does not work in Axis though! There the preview jumps to a random place, but it is the same behaviour with the original gremlin.
Also made a small video:
  • PCW
  • PCW's Avatar
  • youngyaper
  • youngyaper
15 May 2025 16:28
  • fc60
  • fc60
15 May 2025 16:24
Greetings,
I think I had a similar situation.
I needed to activate G64 to tell the controller not to move until the previous event had finished it's travel.
Cheers,
Dave
  • youngyaper
  • youngyaper
15 May 2025 16:17
I have an issue that im sure some of you know the solution. It seems linuxCNC/ AXIS processor  instead of completing a move to a coordinate begins moving to the next coordinate creating a curve/ bend toolpath between the two points, almost like a shortcut. It does this only from an X or Y cordinate to a Z and vise versa, but not from an X to Y coordinate. Please help !! thanks.
Displaying 15511 - 15525 out of 17072 results.
Time to create page: 1.163 seconds
