  • emresensoy
  • emresensoy
23 Apr 2025 17:41
Replied by emresensoy on topic EtherCAT Servo cannot set to OP state
Category: EtherCAT
nothing but something:D
  • jjdege
  • jjdege's Avatar
23 Apr 2025 17:23
Are all the drivers the same, or did you do your check all axis with the same driver?
hi
the same driver for all axes.
I tried to unsolder the chip, without success
the board does not respond, for now I do not think I will buy another
thanks for the support
  • tiagounderground
  • tiagounderground
23 Apr 2025 16:48
Replied by tiagounderground on topic LinuxCNC S-Curve Accelerations
this is from my INI file. i raised the values but see no difference.
before i tried with the values you send, is the same on the ethercat config example
[TRAJ]
TPMOD = tpmod_scurve
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 20800.33
MAX_LINEAR_VELOCITY = 20800.33
DEFAULT_LINEAR_ACCELERATION = 350000
MAX_LINEAR_ACCELERATION = 350000
POSITION_FILE = position_mm.txt
  • cakeslob
  • cakeslob
23 Apr 2025 16:39
  • notJamesLee
  • notJamesLee
23 Apr 2025 16:38
Tangential Cutting Path - Post Processor/ Filter File?
Hi Friends,
I've spent the last few months modifying a chinese cnc with a mesa 7i96s and a custom cutting head I've made with the end goal making it a tangential cutter  I've long dreaded this part because i simply do not know where to start. I am working on tuning the error in the cutting motor but this is next on the list.  I am going to lay out what i would like the machine to do, and hopefully you guys can point me in the right direction.
Attached is a cad screenshot with a visual of the cutting head. There are two pneumatic cylinders that can deploy the cutting head down or up with a solenoid valve controlling them both. I wanted to leverage some of the 7i96s auxiliary outputs or the torch up/down to control this valve.
I am not sure what cad program that will be outputting these, probably fusion or solidworks in the long run so i am leaning towards a filter file or i guess this is technically a post processor, as mentioned in this post, but i didn't see really any progress so here i am.
forum.linuxcnc.org/38-general-linuxcnc-q...n-of-travel-possible
My fundamental issue is i don't understand what node is doing what. I haven't ever uploaded a file to LCNC but i imagine its Gcode.
So my simple brain wants to understand;
- Cad program - > outputs generic 2D gcode
- **NEW FILTER FILE** -> magic happens here?
-LCNC - > doesn't know the difference, its just following orders.
Requirements (will probably grow):
-be able to set "cut depth' (the z position with 'torch down')
-set cutting motor to only find angle in one direction (not sure if i can or should do this on LCNC and not the filter file) because belts aren't very good pushers..
-I'd like all travel movements and find next angle to happen with the torch up, and it only go torch down only when the next angle is good and its in position
-BUT i would like arcs and angle to be smooth, i need to differentiate between lines with arcs an endpoints.
also sorry i am rambling, can you tell i've thought about this.
  • Hakan
  • Hakan
23 Apr 2025 16:11
Replied by Hakan on topic EtherCAT Servo cannot set to OP state
Category: EtherCAT
What did I do :) ?
  • Grotius
  • Grotius's Avatar
23 Apr 2025 15:30
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Hi Rod,
The Cia-402 i have seen the source code. It does not much.
It sends and recieves position, velocity, torque  trough a can protocol?
  • Grotius
  • Grotius's Avatar
23 Apr 2025 15:25
Hi Tia,
when i change to tpmode=scurve
It is : tpmod_scurve
And check if you use values for the trajectory :  vel + acc.
 [code]# Trajectory planner section --------------------------------------------------
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
DEFAULT_LINEAR_VELOCITY = 208.33
MAX_LINEAR_VELOCITY = 208.33
[/code]
I just isnstalled debian 13 on the desktop pc and installed the same software, but the ethercat-master from the codeberg repo.
It also runs ok. So that's a good sign.
  • besriworld
  • besriworld
23 Apr 2025 15:03 - 23 Apr 2025 17:11
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
Today I ran some more tests. I can now reproduce the issue described in the other thread with 100% consistency. I noticed that when the Z-axis is moving, G96  doesn't seem to be working. I recorded a video showing that the spindle speed doesn't change at all during the movement.
PS. I think there might be something wrong with the HAL configuration. I just noticed that when starting LinuxCNC, I need to go into the calibration settings and re-save the PID values for the spindle (I enter test). If I don’t do that, the PID control is soft– under higher spindle load, it triggers a hold  .Also, if I leave LinuxCNC running idle (without running a program) for about an hour, and then start program execution again, the axis movement speed during a G1 command is once again higher than what was set.
  • fletch
  • fletch's Avatar
23 Apr 2025 14:58
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
That would be lovely - the CM5 has one but then you need a carrier board and I don't know if the LinuxCNC image would run on the CM5/eMMC? With the right carrier board would be perfect though...
  • unknown
  • unknown
23 Apr 2025 14:54
Dunn why RPi doesn't add a connector for an external antenna.
  • fletch
  • fletch's Avatar
23 Apr 2025 14:35 - 23 Apr 2025 14:37
Just for completeness and to save anyone having to mess around with compiling kernel modules, here is what looks like a fairly comprehensive (at least until 6.13) list of in-kernel USB WiFi devices: github.com/morrownr/USB-WiFi/blob/main/h...in-kernel_drivers.md
Discovered it a little late but I think only one has an RP-SMA connection.
  • tiagounderground
  • tiagounderground
23 Apr 2025 14:00
tried here, it works with the original trajetory planer on the rip install, when i change to tpmode=scurve i need to desable homing on the gantry axis and i can do jog movements but when running gcode the machine seens to be stoped but it is runing with an extremaly low aceleration, near 1 minut to move 1mm
  • PCW
  • PCW's Avatar
23 Apr 2025 13:49
Mesa CT 2.1.7 and Mesa 7I97T setup running Gmoccapy
Category: Configuration Tools
net estop-loopback => hm2_7i97.0.ssr.00.out-00
should probably be:
net estop-loopout => hm2_7i97.0.ssr.00.out-00
  • emresensoy
  • emresensoy
23 Apr 2025 12:12
Category: EtherCAT
- Solved -
There is a startup sequence in control word,
set bit number 1 2, 0 to 1
then if you set bit 3, drive goes to enabled state,
Thanks a lot
Displaying 16711 - 16725 out of 17168 results.
Time to create page: 1.680 seconds
