  • hakinen2255
  • hakinen2255
03 Mar 2025 18:12
Replied by hakinen2255 on topic How to open QT ui file in LinuxCNC
Category: Qtvcp
Hi cmorley,
I am designing the QT interface from scratch but it will take some time to be able to use my machine in the meantime i wanted to load this vertical qtdragon_hd ui but it didnt work linuxcnc gives an error and close,
i have this folder ../linuxcnc/config/sim.qtdragon_hd.qtdragon_hd_xyz/qtvcp
i made a copy of qtdragon_hd with qtvcp copy command to this folder, so its like this now:
../linuxcnc/config/sim.qtdragon_hd.qtdragon_hd_xyz/qtvcp/screens/qtdragon_hd/
and there is the .ui file etc in there,
i copied the original one to somewhere else and put the vertical ui file there and changed the name to qtdragon_hd.ui
so when i select qtdragon_hd_xyz or _xyza during linuxcnc launch under my configurations it should load the vertical ui right? am i wrong?
  • bnet
  • bnet's Avatar
03 Mar 2025 17:11
Fanuc Serial Pulse Coders - Red cap servos, mesa 7i76e, how to?
Category: Driver Boards
The image below is where I'm getting the idea to use Stepgen to convert my fanuc encoder data to AB quadrature for outputting to the drives, but I could use some insight as to whether or not it will function or if I'm missing some important details.. Does anyone know?
Within the HAL, is there a possibility of connecting the fanuc encoder data position output to the 'position in' port of Stepgen as it runs in quadrature output mode, to then output the quadrature pulses to my AB Ultra3000 drives to provide the position feedback to them? Or is there some major flaw in this concept..
  • RDA
  • RDA
03 Mar 2025 16:15
Replied by RDA on topic Plasma and Ethercat?
Category: Plasma & Laser
This machine had a Burny controller so unfortunately no hal scope :( What I had was my portable scope, that's it.
If you compare my plot to yours, you have 50V/div if I look at it correctly. You can see my capture tops at around 400-450V so that would be already out of your display range? Maybe it is roughly the same?
  • RDA
  • RDA
03 Mar 2025 16:09
If you measure from the work to signal ground with a GHz capable scope at say 1ns/per division,
You will see fractional ns spikes of significant voltage on the work (or low end of divider)
( arc starting is instantaneous an even if the current ramp is controlled, the plasma wiring
has significant capacitance)
Ok, yeah that can make sense. Its something I can't test so I will take you word for it. My original point was that I thought that having 500V OVP on the divided signal was an exaggeration.
  • bigmactx
  • bigmactx's Avatar
03 Mar 2025 14:46
Replied by bigmactx on topic LinuxCNC 2.10 build
LinuxCNC 2.10 build
Category: Installing LinuxCNC
yeah sorry about the typo in the title. should have been 2.10
  • NT4Boy
  • NT4Boy
03 Mar 2025 14:27
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
checked that motion.is-all-homed is TRUE , then had one last prod of the buttons, and the axis does jog on the wheel.
Only if both my plus and minus buttons are pressed together.
With both pressed the scale is .0001
What I really want to do is with those buttons is to duplicate what the rapid plus and minus do on the Axis gui
03 Mar 2025 14:03
Replied by tommylight on topic Hurricane Milton
Hurricane Milton
Take care rodw. that kind of weather is no joke. hopefully damage will be minor. Prep for the worst, hope for the best.
+1
  • unknown
  • unknown
03 Mar 2025 13:49
Replied by unknown on topic Hurricane Milton
Hurricane Milton
Shit mate didn't know it was that bad up there.
We Gunna have to send truck & dogs and bobcats up again to help with the cleanup ?
  • unknown
  • unknown
03 Mar 2025 13:46
Replied by unknown on topic LinuxCNC on Intel Clear Linux
You could always choose not to run them.
Or you could run them when not machining a part.
Why is it when I hear the word "maker" I envisage some hipster with soft hands, a man bun and a manicured beard ?
I know, cos I'm a cranky old bastard who's one step away from yelling at clouds, I've already got the yelling at tv and birds covered.
  • rebelx
  • rebelx
03 Mar 2025 12:54
Replied by rebelx on topic LinuxCNC on Intel Clear Linux
Thank you so much! I will certainly give it a try. I have been monitoring your github page for quite a while in anticipation of your great work, so this is big news!
As for Clear Linux, I believe they finally got it working on their distro, but made it part their maker-cnc bundle, which includes programs like inkscape and OpenSCAD, which are great apps but should not run on a machine controller. They do not seem to fully understand the LinuxCNC ecosystem, so I have already lowered my expectation (or should I say hopes?).
  • my1987toyota
  • my1987toyota's Avatar
03 Mar 2025 10:37 - 03 Mar 2025 10:39
Replied by my1987toyota on topic Hurricane Milton
Hurricane Milton
  • NT4Boy
  • NT4Boy
03 Mar 2025 10:21
Yes, I have checked them over and over, so may have developed a blindness.
I have my rapid plus and minus buttons connected to the scale inputs.
the input pin for each one goes yellow when pressed.
axis.L.jog-scale is zero when no buttons pressed, and 1e5 for left button and 1e6 when right button is held in.
axis.L.jog-enable each of the three axes lights go yellow when the appropriate button is pressed
axis.L.jog-counts large numbers go up and down on all three axes as the wheel is turned
  • Aciera
  • Aciera's Avatar
03 Mar 2025 10:01
Replied by Aciera on topic LCNC 2.10 - Ask for AUTOMATIC_G43
Category: Gmoccapy
Spam removed
  • rodw
  • rodw's Avatar
03 Mar 2025 09:53
Replied by rodw on topic EL6751 native support
Of course we are interested! Please share.
x 2 !
I was going to suggest a pull request to github.com/linuxcnc-ethercat
That way it will find its way into the Debs for all to use....
  • Aciera
  • Aciera's Avatar
03 Mar 2025 09:41
Replied by Aciera on topic EL6751 native support
Displaying 18346 - 18360 out of 18598 results.
Time to create page: 0.446 seconds
