  • ihavenofish
  • ihavenofish
03 Feb 2025 20:24
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
So as it turned out we have lots of IO on the drives. 24 in and 6 out. So really It will be down to figuring out the spindle. RS485 is an option on the drive, but I know virtually nothing about how that works. Anyone got a link to some "for dummies" instructions? and whether it will work alongside ethercat?
  • RNJFAB
  • RNJFAB
03 Feb 2025 20:24
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Category: Show Your Stuff
I’m sure it’s something very simple that I have got wrong.
last night I realised that I don’t have an arc ok showing when the torch fires. Checked wiring and it’s all correct.
Cpc pin 12 goes to input 10 on the Mesa, pin 14 goes to common +.
03 Feb 2025 20:11
Replied by tommylight on topic The dumification of humanity through internet
We are humans, and as such we all have our ups and downs.
Hence, it's also human to restrain when someone else has a bad day as not to amplify whatever hardship they are going through.
As for spammers, they do damage, actual damage, as clicking on some of those links will literally grant them full access to your PC and everything on your network, yes even cameras, followed by misusing whatever info they got out of your systems and then some will add extortion to that threatening with making that info public. Or completely locking you out of everything, and extorting you to get your own stuff back.
So calling us names here and a bit of cursing and swearing just makes this place more "colorful" :)
  • Aciera
  • Aciera's Avatar
03 Feb 2025 20:08
Program exceeds machine maximum X and Y Axis
No idea really but maybe you have active G92 offsets.
To clear run this in MDI:
G92.1
If that does not fix it we would need to see your the .ini file of your machine config.
  • Hakan
  • Hakan
03 Feb 2025 20:04
Replied by Hakan on topic lcec config exited without becoming ready
Category: EtherCAT
Do you use some special double-quotes around D1, D2,D3 and D4?
Replace them with the normal ones, that are around 0,1,2,3 in slaves
names="D1"
  • BigDee
  • BigDee
03 Feb 2025 20:00 - 03 Feb 2025 20:02
Edit config file from 2.9.3 in stepconf 2.9.4
Category: Installing LinuxCNC
I've tried to re-install my system (Dell Optiplex Athlon, Dual Core 4400+, 4 GB. Parallel Port) via Live CD. This didn't work at all on my system (sadly I didn't take a screenshot of the failure message but it was the step after partitioning the hard drive). I tried the same with a 2.9.3 Live CD and this was immediately successful. Afterwards I could flawlessly update to 2.9.4.
Linux was up and running as expected. I ran stepconf wizard to create a machine config and afterwards replaced it by my backup config files (2.9.3) to the created folders. My machine was running without any issues.
I then started stepconf wizard (2.9.4) to check my setting of my backup config from 2.9.3 and got an error message:
Is there anything i need to do to update the 2.9.3 config file to be used with 2.9.4 stepconf wizard?
Thanks in advance for your support.
Dieter
03 Feb 2025 19:58
Installing NoMachine Remote Desktop - Package installer issues
Never used it, but i did use VNC always, well till some 8 years ago, now i sue nothing of such sort.
There are several versions of it though, so check for the fact that the same version works on Linux and Windows.
  • my1987toyota
  • my1987toyota's Avatar
03 Feb 2025 19:46 - 03 Feb 2025 19:54
Replied by my1987toyota on topic The dumification of humanity through internet
I just figured tommylight was having a bad day.
tommylight, I remember those posts I couldn't believe he wasn't banned at that point because of how
he was acting. I think we are tougher on spammers then people were on that guy.
  • Aciera
  • Aciera's Avatar
03 Feb 2025 19:44 - 03 Feb 2025 19:45
Please don't open new threads about the same topic.
Please continue in your original thread which I renamed to be more descriptive:
forum.linuxcnc.org/38-general-linuxcnc-q...-x-and-y-axis#320525
  • Aciera
  • Aciera's Avatar
03 Feb 2025 19:40 - 03 Feb 2025 19:42
I just had this problem where it says Program exceeds machine maximum X and Y Axis. I cannot figure out why it is saying this i’ve had the CNC PLASMA CUTTER (5x10) for about a month and never encountered a problem like this. I have a few pictures! If someone can help please let me know, thanks!!
Moved here from your other thread which I locked.
forum.linuxcnc.org/38-general-linuxcnc-q...-x-and-y-axis#320519
Please continue here.
  • ihavenofish
  • ihavenofish
03 Feb 2025 19:39
Decided this should be its own thread to not get all buried in the main one.
Trading for some ethercat servos this week so I'm going to make a whole separate new control for testing.
Drives are omron RD88 400w and 200w models. 20 bit incremental encoders.
They do seem to have at least a couple IO on each one, but I think I definitely need more IO. I did have an EK1100 somewhere, but I cant find it and it would cost a few hundred to get the IO modules, especially spindle analogue.
Does anyone have a link to a low cost IO module that works well with linuxcnc? I've seen a few floating around, but I have no idea if any of them "just work".
  • spumco
  • spumco
  • spumco
  • spumco
03 Feb 2025 19:30 - 03 Feb 2025 19:35
Replied by spumco on topic Remap M6 Prolog & Epilog question
Create a subfolder in your config folder named 'python.'
Put remap.py, stdglue.py, and toplevel.py in the new 'python' folder.
An example can be found here:
github.com/LinuxCNC/linuxcnc/tree/master...ython-stdglue/python
The change_prolog & epilog stuff are contained within the stdglue.py file.  What the "REMAP=" statement in the INI file is doing is telling LCNC:
  • When LCNC sees and "M6"
    • Look at toplevel.py and import (use) everything in remap.py
    • Look at remap.py (import stdglue.py)
Look at stdglue.py and substitute all the "change_prolog"  and "change_epilog" sections for LCNC's built-in behavior
And the ngc=Tool_change_sub section is telling LCNC to substitute that file (i.e. do whatever is in the file) for LCNC's built-in behavior.
EDIT-
Forgot to add... you also need a [PYTHON] section in your INI file if you don't already have one.  That 'TOPLEVEL=' part tells LCNC where to start looking for everything.
[PYTHON]
PATH_PREPEND = python
TOPLEVEL = /your config folder name here/python/toplevel.py
PATH_APPEND = /your config folder name here/python/
  • Sziggy_NC
  • Sziggy_NC
03 Feb 2025 18:37
Remap M6 Prolog & Epilog question was created by Sziggy_NC
I am attempting to setup a standard carousel style atc.
In my INI my RS274NGC is as follows:
[RS274NGC]
PARAMETER_FILE = parameters.var
SUBROUTINE_PATH = /home/sabre/linuxcnc/configs/sabre_500_mesa_7i97t/subroutines/
REMAP= M6 modalgroup=6 prolog=change_prolog ngc=Tool_change_sub epilog=change_epilog
Does this mean that I need a file named change_prolog.py and change_epilog.py saved in the subroutines path? (I see the change_prolog & change_epilog sections in the stdglue.py)
Currently I have stdglue.py and tool_change_sub.ngc in the subroutine path and I get pycall(remap.change_prolog)failed on a tool change.
I have been reading the Remap Extending G-Code, and I don't see where or how I should save the prolog and epilog.
  • PCW
  • PCW's Avatar
03 Feb 2025 18:08 - 03 Feb 2025 18:18
Stuck with spindle interface 7i76 card and weird BLDC driver
The outputs on TB3 pin 4 and 5 should be used individually,
 that is, you would use the appropriate output and
GND (TB3 pin 1) NOT both outputs to create a 5V signal
Which output you chose depends on the direction polarity.
On later bitfiles I have changed from PWMDIR to GPIO
on some configurations because it is more flexible
(many systems do not use the DIR pin and it is unavailable
as a general purpose output in these cases)
And yes, GPIO8 can be used for any type of output.
Displaying 19576 - 19590 out of 19592 results.
Time to create page: 0.416 seconds
