  • Philip Lydin
  • Philip Lydin
09 Jan 2025 20:59
ethercat relay module was created by Philip Lydin
Category: EtherCAT
Has anyone tried this module out? Would be super useful and very neat, not to expensive aswell. Documentation seems very limited i tried to contact them but no answer yet. Should not be hard to write programs for such simple io boards, right?
www.485io.com/io-isolation-protection-bo...put-board-p-575.html
  • PCW
  • PCW's Avatar
09 Jan 2025 20:57
Replied by PCW on topic Help configuring RTeligent R86 driver
Category: Milling Machines
Those timings should work with almost any drive.
  • Philip Lydin
  • Philip Lydin
09 Jan 2025 20:54
Vertical layout gui was created by Philip Lydin
Vertical layout gui
Category: Other User Interfaces
Hello, does anybody know if there is a good looking vertical layout gui including some features like toolchanger, probing, etc. I know there is some development currently going on to create a vertical probe_basic which would be wonderful but i dont think there is a tested and working version yet.
  • Philip Lydin
  • Philip Lydin
09 Jan 2025 20:48
At20 modbus communication was created by Philip Lydin
Hello, im thinking about buying this at20 vfd and im wondering if anyone knows if there is a already a plugin to control it by modbus. Down below i linked to the manual. the parameter addresses are located at page 173-178. If there isnt already a plugin made for this specific protocol i would really appriciate some guidance to get started programming it myself.
Any information is helpful. Regards Philip
www.dropbox.com/scl/fi/vxghbvlia2pd496fm...e=1&st=8owqf4jl&dl=0
  • resmond
  • resmond
09 Jan 2025 20:48
Replied by resmond on topic Help configuring RTeligent R86 driver
Oops, I forgot a couple of things:
setp hm2_[MESA](BOARD).0.stepgen.02.step_type 0
setp hm2_[MESA](BOARD).0.stepgen.02.control-type 1
  • Grotius
  • Grotius's Avatar
09 Jan 2025 20:35
Replied by Grotius on topic PathPilot V2 source code
Category: PathPilot
@John,
Send mail to adres on this site: to codeberg.org/skynet/linuxcnc
09 Jan 2025 20:16
Replied by Cant do this anymore bye all on topic Real-time kerel not detected on patched 6.12
OK,
There still seems to be patches required for RT.
One does include the above mentioned patch and the other does touch on what I mentioned but this depends of KVM being disabled.
So I would guess that the patches here:
www.kernel.org/pub/linux/kernel/projects/rt/6.12/
Would be correct for 6.12.8 ?
Which include the patch that allows Linuxcnc to detect a RT kernel and also allows the selection of a fully preemtible kernel.
  • PCW
  • PCW's Avatar
09 Jan 2025 20:02
Replied by PCW on topic THCAD 10 question
THCAD 10 question
One 2.4M resistor in series to the negative lead will give you a 250V full scale range
which should be OK
  • smc.collins
  • smc.collins
09 Jan 2025 19:58
Replied by smc.collins on topic M6 Remap Lathe (Remap T & ignore M6)
If you post up the wiring a d function diagrams for your tool changer i could help, but it's more complicated than just hooking up hal pins
09 Jan 2025 19:44
I see a lot of talk regarding enabling expert, that’s a sub menu with quite a few options, non relating to enabling a fully preemptible kernel.
The mod to the kconfig is a switch, as far as I can see, that the platform is RT capable.
  • resmond
  • resmond
09 Jan 2025 19:39
Help configuring RTeligent R86 driver was created by resmond
The user guide offers very little in the way of specs on timing of Step/Dir signals and isn't listed in the Driver drop-down in MesaCT.
Could anyone give me some advice for the following settings:
MAX_VELOCITY = 20
MAX_ACCELERATION = 50
DRIVE = Custom
STEP_INVERT = False
DIR_INVERT = False
STEPGEN_MAX_VEL = 24.00
STEPGEN_MAX_ACC = 60.00
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 2000
STEPSPACE = 2000
ENCODER_SCALE =
I think Rob mentioned in another thread that he had one of these and I'm trying to rule out any timing mis-configuration as I figure how hum much damage I did to my 9i95T board.
  • johnbl
  • johnbl
09 Jan 2025 19:36 - 09 Jan 2025 19:37
Replied by johnbl on topic PathPilot V2 source code
Category: PathPilot
Personally, i would think they should provide it publicly... but still, they were selling the full PathPilot on a USB stick for 35$, so i can not be angry at them.
I actually asked them. They wanted me to send a $10 cheque to some address. I did. After a few weeks they told me they never received it.
Then they gave me a second address. I sent another cheque to that address. USPS bounced back the mail as the address was invalid.
  • johnbl
  • johnbl
09 Jan 2025 19:30 - 09 Jan 2025 19:32
Category: PathPilot
I'm also only interested in reviewing their TP changes, I couldn't care less about their GUI.
Grotius, could you please consider sharing the emc sources (the src/emc directory)? The GPL grants you this right.
  • Lezard
  • Lezard
09 Jan 2025 19:23
Solved - LinuxCNC does not work with new Delta ASDA-A2 drive
Hello @tommylight, thank you for your suggestion.
I'm off the machine at the moment, and working through the Delta documentation and build notes from back then. I suspect that the backup parameters file might be wrong, I'll check tomorrow by downloading the X axis parameters first to compare.
Thanks again
  • ric812
  • ric812
09 Jan 2025 19:20
Replied by ric812 on topic THCAD 10 question
THCAD 10 question
Would the resistor I have listed work for the THCAD to read the voltage?
Displaying 20221 - 20235 out of 21718 results.
Time to create page: 0.342 seconds
