  • JT
  • JT's Avatar
07 Jan 2025 18:18
Replied by JT on topic Mesact 2 Setup
Mesact 2 Setup
Category: Configuration Tools
Using LinuxCNC Bookworm. Have downloaded file from packages.debian.org/sid/python3-distro. Not sure what to do with it.
Also tried adding linuxmint to Synaptic repositories. Not doing it correctly.
Some guidance would be appreciated.
Thanks.
What are you trying to do? Mesact is not in debian packages.
JT
  • rmavalente
  • rmavalente
07 Jan 2025 18:10
Gould Gettys Servo Amplifier Drifting User Guide
Category: Driver Boards
Hello Mates,
my milling machine is based on 3 N360 / A121 (I guess) servo amplifiers from gould. I believe they need a little adjustment to reduce drift (about 12 to 16V whe 0V at analog in). Thing is I can not find their manuals anywhere! Gould gettys has been dissolved, their tech support could no care less about my request. There is a guy selling one manual on ebay, but he will not ship to Brazil. Can anyone help?
Greetings!
  • JT
  • JT's Avatar
07 Jan 2025 18:09 - 07 Jan 2025 18:09
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
I just added the dynamic properties section to the docs and put links to it where dynamic properties are mentioned
gnipsel.com/linuxcnc/flexgui/property.html
JT
  • Aciera
  • Aciera's Avatar
07 Jan 2025 17:59
  • gbsd86
  • gbsd86
07 Jan 2025 17:51
Replied by gbsd86 on topic Mesact 2 Setup
Mesact 2 Setup
Thanks.
  • Martin.L
  • Martin.L
07 Jan 2025 17:39
Replied by Martin.L on topic Raspi5 + VH229 no HDMI0 audio
Category: Installing LinuxCNC
Hi, still I can't figure out whats the issue, sigh
  • blazini36
  • blazini36
07 Jan 2025 17:37
Replied by blazini36 on topic Building and configuring a stmbl v5
Wow a stmbl v5, didn't know that was happening. Think I've been waiting 5 years or better to see that.
  • jst
  • jst
07 Jan 2025 17:28
Replied by jst on topic Building and configuring a stmbl v5
I would like to, but it tells me that they are to big. Even at like 200 kB. The error message says they can be up to 1.6 MB
  • blazini36
  • blazini36
07 Jan 2025 17:24 - 07 Jan 2025 17:26
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
OK yeah, that's the part that was missing from the first video. Youtube embeds don't work well on my end so I missed it in the 2nd
I see some of the other controls items have dynamic properties so it might be mentioned elsewhere in the docs but I didn't see any mention of it while just progressing through.
Edit: I see it in "Step by Step" gnipsel.com/linuxcnc/flexgui/hal.html#step-by-step
07 Jan 2025 17:18
Replied by tommylight on topic Building and configuring a stmbl v5
Thank you very much, but could you please upload pictures here on the forum?
  • jst
  • jst
07 Jan 2025 16:45 - 07 Jan 2025 16:56
in the following topic I want to document the process of building and configuring a stmbl v5 servo drive. Since I found it a bit hard to get started and reading through the documentation, I will try to explain my process step by step so others can follow.
But first I wand to thank freak for designing the v5 and bringing the project back to life. Also thanks to Rene and all other contributors.
I got two Mitsubishi RV-4FLM robots without a controller, so I need 12 drives. I decided to build them my self, because I wanted to get a bit back into electronics and also save some money. You can also buy drives form freak (contact is on the github page). The price he asks is very reasonable and I wouldn't recommend building the drives yourself if you don't have a fair amount of experience with electronics. So if you only need a few drives, please support freak. Before I get questions about it, I also want to clarify, that I will not sell drives as long as they are available from the project maintainers.
So lets get started:
I ordered 15 PCBs with almost all SMD components assembled from JLCPCB. I did solder some inductors by hand, because I couldn't easily find a exact match in the jcpcb parts catalog. While doable, I would recommend against it, the layout is just not made for hand soldering. I'm still waiting for some connectors to arrive, so I only have pictures of half completed boards.
imgur.com/a/0Gni6MG
  • JT
  • JT's Avatar
07 Jan 2025 16:35
Flexible GUI
Category: Flex GUI
That section only shows up after you select the button then press the green plus symbol and add a dynamic property.
JT
  • PCW
  • PCW's Avatar
07 Jan 2025 16:20 - 07 Jan 2025 16:44
Calculating step length/space timings for Delta B3 servo drives
At 4000 steps/mm *133.33 mm/s (8000 mm/m) the step rate is ~533 KHz.
so your 700 ns step length and 700 ns step space are fine as these limit
the maximum step rate to ~714 Khz   = 1/(steplength+stepspace)
The drives maximum step rate in step/dir mode is 4M steps per second,
which means ~125 ns minimum step space and step length so you have plenty
of margin. The setup and hold times are relatively unimportant as long as they are
long enough (they do not affect performance)
Note that all this assumes differential (line driver) wiring not open collector.
  • PCW
  • PCW's Avatar
07 Jan 2025 16:06
Replied by PCW on topic Weiler DZ26 Millturn Conversion
Category: Turning
Does the 6I25 finish configuration loading?  (no red LEDs except briefly at power up)
Is the 6I25 jumpered for 33 MHz PCI clock?
Displaying 20446 - 20460 out of 21723 results.
Time to create page: 0.951 seconds
