  • CNC_Manni
  • CNC_Manni
06 Aug 2026 14:54
Remora on NVEM board - unable to upload new configs
Thanks for sharing your experience - I'm running into a very similar issue and hoping you might have found a solution since posting this.
I'm using an NVEM V5 board (RT1052 chip). I successfully flashed the firmware via pyOCD (tried multiple firmware versions: remora-rt1052-NVEM-0.2.1.bin, remora-rt1052-0.0.1.bin, remora-rt1052.bin - all flashed without errors). Ping to 10.10.10.10 works perfectly and consistently.
However, unlike your case, I'm getting a timeout on my very first config upload attempt - not after a successful first upload. I've tried:
- My own custom config file
- The unmodified official example configs (both nvem-rt1052.txt and remora-rt1052-basic/ec500-rt1052.txt)
- Uploading with the SWD/ST-Link connection both attached and disconnected during the upload
- Confirmed via tcpdump that the WRQ packet is sent correctly on port 69, but no response ever comes back from the board
- No firewall involved (iptables set to ACCEPT), direct point-to-point Ethernet connection, no router
The script always confirms "Valid JSON config file" and calculates the CRC correctly, so it gets stuck at exactly the same point you describe - after everything on the PC side looks fine.
Did you ever find out what caused the board to stop responding to TFTP? Was it possibly related to the eStop/enable state getting stuck, as you mentioned the LED stayed permanently lit? Any insight into how you (or anyone else) resolved this would be hugely appreciated - trying to avoid unnecessary re-flashing if there's a known cause.
Thanks in advance!
  • BigDo
  • BigDo
  • emresensoy
  • emresensoy
  • CNC_Manni
  • CNC_Manni
06 Aug 2026 13:12
Replied by CNC_Manni on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hallo zusammen, könnt ihr mir bei folgendem Problem helfen?
Board: NVEM V5 (i.MX RT1052)
Getestete Firmware-Versionen: remora-rt1052-NVEM-0.2.1.bin, remora-rt1052-0.0.1.bin, remora-rt1052.bin — alle zeigen identisches Verhalten
Ping auf 10.10.10.10 funktioniert einwandfrei
upload_config.py sendet korrekt eine WRQ-Anfrage auf Port 69 (bestätigt per tcpdump), erhält aber nie eine Antwort vom Board
Keine Firewall aktiv (iptables ACCEPT), direkte Verbindung ohne Router
Gibt es eine spezielle Prozedur, um den TFTP-Config-Upload auf diesem Board zu aktivieren (Pin kurzschließen, erst einen Befehl senden, o. ä.)?
Vielen Dank schon mal im Voraus!
  • CNC_Manni
  • CNC_Manni
06 Aug 2026 13:10
NVEM V5 RT1052 was created by CNC_Manni
NVEM V5 RT1052
Category: Driver Boards
Hello everyone, could you please help me with the following problem?
Tested firmware versions: remora-rt1052-NVEM-0.2.1.bin, remora-rt1052-0.0.1.bin, remora-rt1052.bin — all show identical behaviour
Ping to 10.10.10.10 works fine
upload_config.py sends a WRQ request on port 69 correctly (confirmed via tcpdump), but never receives a response from the board
No firewall active (iptables ACCEPT), direct connection without a router
Is there a special procedure needed to enable TFTP config upload on this board (short a pin, send a command first, etc.)?
Thanks a lot in advance!
  • BigDo
  • BigDo
06 Aug 2026 12:08
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
Hi!
Nice to see NativeCAM alive again.
I have a new clean installed Trixie and NativeCAM 2.0b all looks fine but i get a error
Negative F-WORD at Line near 101
Does anyone have any ideas?
  • 5280
  • 5280
06 Aug 2026 12:03
Replied by 5280 on topic Ver 10 NEW install
Ver 10 NEW install
Tks for the info But I stick to GIVE THE USER THE CHOICE right off the bat....! an force me to "DIG" for that info to have to disable. at a later date
I under stand with the internet the way it is.? "BUT" give me the "choice"
I understand this will never HAPPEN but had to get my 2 cents worth in.!
the old timer
  • Todd Zuercher
  • Todd Zuercher's Avatar
06 Aug 2026 11:44
Replied by Todd Zuercher on topic Ver 10 NEW install
Ver 10 NEW install
It is possible to set up a linux system with no passwords, but it isn't completely simple or recommended (especially on systems with any internet exposure.)
First you can do away with a root password, by leaving that blank when installing. The user password is required while installing, but you can configure Linux to boot directly to the user interface by enabling automatic login, and the system will start without needing to input a password.
If you configured the system without a root password, the installer will have given sudo privileges to the user, and will promp for a password when a sudo command is input at the terminal.
With automatic login and sudo privileges for the user, you would only need to enter your password to perform administrative tasks that probably should be password protected. Otherwise you shouldn't normally need to user your password.
There are ways to even remove the requirement for a password for sudo tasks, but I've never tried and would have to google instructions how to do it. (not to mention that it's generally probably not a good idea.)
  • emresensoy
  • emresensoy
06 Aug 2026 10:42
Replied by emresensoy on topic LS L7N Servo drives standing INIT state
Category: EtherCAT
I installed linuxcnc 2.9.4
and problem solved,
lol
  • 5280
  • 5280
06 Aug 2026 10:19
Ver 10 NEW install
Sorry about Pxxx/Moning about passwords I am leaving M.S. because of how they handle the passwords. I have been building boxes since Aug of 1977 (Almost 50 years) and over 100 boxes's
why cant they just have a check box do you need a password yes / no and leave it at that
1 frustrated old man
Ken (5280)
  • 5280
  • 5280
06 Aug 2026 09:36
Ver 10 NEW install
Thank you for the reply (link to the Debian 13 install link after building a USB boot install flash drive and doing the install on the (older Dell laptop 8 gig memory)thee install goes fine till the password section which i have tried any number of password from 4 letters to 20 letters / numbers .? nothing get me past the enter login on the reboot . Every thing looks fine on the setup "but" ? I guess I am not to have this I have never understand why since I am the only person "WHY " I need a password" and the only person who will use this people have gotten crazy with the requiring passwords
Thanks for the help
  • Mars
  • Mars
06 Aug 2026 08:07
Best bet for a low cost HW assisted Linuxcnc engine....
Thanks to everyone for their comments. The overall take away from this is that you want a solution with minimal hassle, go with Mesa and pay accordingly.
Let me ask a related, more targetted question: what is the most solid Remora implementation both in terms of solid operation once configured *and* using HW that is solid and has a reasonable support expectancy. Novusun (sounds iffy), esp32 based? RP2040 (sounds experimental), some kind of 3D printer driver board? Other?
  • saxa
  • saxa
06 Aug 2026 06:18
Gantry oxyfuel / plasma type machine from scratch
Ok, I got this searching the forums and internet. So would be needed to test it to see eventually how that latency would be affecting it. Another question is if there is an better suitable industrial PC to buy ?
I mean do you have any recommendations on what motherboard and chipset is preferable for use with LinuxCNC ? I understand that this would be any motherboard
that Debian or linux kernel supports, but is there a some preferred hardware list or suggestions for a good LinuxCNC industrial PC ?
Displaying 2086 - 2100 out of 11357 results.
Time to create page: 1.631 seconds
