  • Toyota1zz
  • Toyota1zz
30 Dec 2024 10:13
Chasing Threads and Re-Threading was created by Toyota1zz
Greetings. I've been looking online but havent figured out what size tap i need for a thread in my engine block where a 17mm metric sized bot goes in to botl on the tensioner. I appreciate any help!
I think I will have to rethread it. It would be my first time.
  • fully_defined
  • fully_defined's Avatar
30 Dec 2024 08:19
Replied by fully_defined on topic Rotary Selector Switches & Resistors
For absolutely no reason at all, I decided to make it fancy. Now I can choose the orientation of the center of the switch sweep, like noon, 3, 6 or 9 o'clock.
If I were to do this again, I would probably start measurements like a unit circle, with all angular measurements a positive value from the x-axis, CCW. Live and learn.
  • timo
  • timo
30 Dec 2024 07:37
Replied by timo on topic mill 4th axis
mill 4th axis
Category: Milling Machines
In addition to info from spumco.
Commercial suppliers of 4th axis usualyl differenciate between positioner (brake opens, thing rotates, brake closes)
Movable axis which allow light milling up to heavy milling. (workpiece weigth torqure)
Movable axis that are even fast enough to do turning operations. (sometimes even with direct drive)
If a positioner is "good enough" it makes things a lot easier.
  • cmorley
  • cmorley
30 Dec 2024 07:31
Replied by cmorley on topic qtvismach, a axis toolpath
Category: Qtvcp
Ok I pushed some work on this.
vismach_mill_xyz should show case it.
in your vismach script you need to add:
on top:
from qtvcp.core import Status
STATUS = Status()
and in the Window class:
        STATUS.connect('motion-type-changed', lambda w, data: v.choosePlotColor(data))
        # uncomment to change feed color and to see all colors
        #v.setColorsAttribute('FEED',(0,1,0))
        #print(v.colors)
  • onceloved
  • onceloved's Avatar
30 Dec 2024 07:11
Replied by onceloved on topic Probe Basic - How does tool setter calculate ?
Category: QtPyVCP
You can watch this video
  • fully_defined
30 Dec 2024 04:07
Replied by fully_defined on topic xfce panels are hidden
I want my desktop to look like this:https://www.tecmint.com/wp-content/uploads/2013/07/xfce-11.jpg
I like the mouse background! Is that still available as an option in LinuxCNC?
It reminds me of the startup screen on Heidenhain TNC640, since it's no secret that it's just an application running in Linux on XFCE desktop. In fact, my job programming for and running a Hermle 5-axis mill is part of why I decided to finally start using LinuxCNC at home.
I am otherwise totally new to Linux, and I haven't even bothered to figure out how to change the desktop background yet. I am one of those weird people that usually keep the default desktop background.
  • Lcvette
  • Lcvette's Avatar
30 Dec 2024 02:44
Replied by Lcvette on topic Probe_Basic Bugs?
Probe_Basic Bugs?
Category: QtPyVCP
Excellent news!
  • PCW
  • PCW's Avatar
30 Dec 2024 02:35 - 30 Dec 2024 15:08
Replied by PCW on topic Fast Hole EDM from Hacked Parts
Yes, duty cycle is the correct pin.
Is the frequency reasonable and the valid bit set?
It sounds like the EDM output is single ended which means:
1. The EDM duty cycle output should connect to TB2 pin 13 (IDX+)
2. The EDM signal ground should connect to TB2 pin 15 (7I96S ground)
3. The 7I96S IDX input should be jumpered for TTL mode (W1 left)
4. 7I96S IDX- (TB2 pin 14) must be left unconnected
Note the if you connected the inputs to TB2 pins 13 and 14 without a ground
and ran the EDM system you may have damaged the EDM output or
7I96S input.
  • cmorley
  • cmorley
30 Dec 2024 01:08
Category: Qtvcp
I should have explained more.
point = [wx, wy, wz]
if not self.plotdata or point != self.plotdata[-1]:
self.plotdata.append(point)
This adds a plot point. We would need to change it to also add color.
point = [wx, wy, wz,color]
or maybe better:
self.plotdata.append([point, color])
then later in the file:
#GL.glColor3f(1.0, 0.5, 0.5)
GL.glBegin(GL.GL_LINE_STRIP)
for p,c in self.plotdata:
GL.glColor3f(*c)
GL.glVertex3f(*p)
GL.glEnd()
a few other initialization and clearing details to follow up. but that might work.
  • IronManDylan
  • IronManDylan
30 Dec 2024 00:04
Replied by IronManDylan on topic Fast Hole EDM from Hacked Parts
Another update.  It seemed that I didn't have the Mesa tied to ground properly.  It is now tied to earth ground (I also tied the shielding into earth ground). The jittering all went away and now the 'hm2_7i96s.0.periodm.00.duty_cycle' is sitting at 0 even when the EDM is running.  Anyone have any ideas?
Is 'hm2_7i96s.0.periodm.00.duty_cycle' the correct pin?
  • MarkoPolo
  • MarkoPolo
29 Dec 2024 22:07
Replied by MarkoPolo on topic qtvismach, a axis toolpath
Category: Qtvcp
I have tried various ways to use this code, but so far no results..
29 Dec 2024 20:49
Replied by Cant do this anymore bye all on topic LinuxCNC 2.9.x hand wheel xhc-whb04b OFF/ON problem
Category: Installing LinuxCNC
I stay away from USB pendants and the like.
  • Labiman
  • Labiman
29 Dec 2024 20:48
stepper driven turret with index and home switch
Category: Turning
Did you find a solution to this problem? Having the same issue
  • Labiman
  • Labiman
29 Dec 2024 20:46
Category: Turning
29 Dec 2024 20:45
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Use the one Rod linked to on his google drive as it handles screen resolutions much much better.
With Linuxcnc is somethings works generally users stick with it. There is still many machines running earlier versions of Linuxcnc on Ubuntu 10 series.
Think of a machine running Linuxcnc the same as an ECU on a pre 2000's car or bike, if it works don't mess with it..........unless you're racing ;)
Displaying 21016 - 21030 out of 21823 results.
Time to create page: 0.450 seconds
