  • Hakan
  • Hakan
25 Dec 2024 11:16
Replied by Hakan on topic PDO variable 64 bit
PDO variable 64 bit
Category: EtherCAT
In the bash prompt, you type in the command "ethercat pdos". This will list all pdos of all ethercat slaves in your system.
You have to wade through that output and see what options the device give you.
  • papagno-source
  • papagno-source
25 Dec 2024 11:07
Replied by papagno-source on topic PDO variable 64 bit
PDO variable 64 bit
Category: EtherCAT
i use debian 10 with linuxcnc 2.9.pre0 and ethercat 1.5.
for use Pdo at 64 bit write in xml :
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="poscommand" halType="double" scale="838860.7"/>
  • Sandro
  • Sandro
25 Dec 2024 10:17
Probe Basic M6G43 (m6_tool_call_tool_page) not working
Category: QtPyVCP
This works! Thank you very much! I totally overlooked it in the documentation and actually removed it from my old configuration.
Is there a way, that a tool touch off is automatically performed on every tool change?
  • Hakan
  • Hakan
25 Dec 2024 09:58
PDO variable 64 bit
Category: EtherCAT
You look at the drive's capabilities
ethercat pdos
  • papagno-source
  • papagno-source
25 Dec 2024 09:50
PDO variable 64 bit
Category: EtherCAT
i use debian 10 , with ethercat.
How can search path for this datatypehandler.ccp , for ceck if have support for 64 bit ?
If not have support , i can patch manually and recompile.
The sintax for use is :
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="poscommand" halType="float-double-ieee" scale="838860.7"/>
or
  • csurimilan
  • csurimilan
25 Dec 2024 09:48
Replied by csurimilan on topic Versaprobe
Versaprobe
Category: Qtvcp
so the versaprobe i can use only with the 3d probe correctly?
  • papagno-source
  • papagno-source
25 Dec 2024 09:41
PDO variable 64 bit
Category: EtherCAT
I use Mitsubishi MRj5 and it have encoder absolute value multiturn , without battery memory wirh resolution 26 bit.
With 26 bit you have much count for revolution and 32 bit pos-command hal pin, is full in 326 cm travel axis , with screew 10 mm pitch.
In drive parameter gear normally 1/1 , if you make a long machine with travel 10 meter , not can use 1/1 gear in drive , because after 326 cm moving , the pos-command return on -326 cm and linuxcnc return following error. For resolve now have increase gear in drive at 1/100 and can travel now 32600 cm. But normally is good have gear at 1/1 and use a 64 bit variable for command position and feedbak position.
  • bharath12
  • bharath12
25 Dec 2024 09:32
Retrofit Engraving machine was created by bharath12
Category: Milling Machines
I have bought this engraving machine to retrofit for my end use and want to learn from it. I want to know what size of steppers? I am thinking of attaching steppers using couplers, but is this type good?
  • bkt
  • bkt's Avatar
25 Dec 2024 09:29 - 25 Dec 2024 09:33
good day to all (in some gtp languages)
today is sunny ... cold ... there are snow in the ground .... is possible to skii .... I'm not at work ... at last the perfect day .... good Christmas day to all
Rumeno: Astăzi este însorit ... frig ... există zăpadă pe jos ... este posibil să schiezi ... nu sunt la muncă ... în sfârșit, ziua perfectă ... Crăciun fericit tuturor.
Albanese: Sot është me diell ... ftohtë ... ka borë në tokë ... është e mundur të skijosh ... nuk jam në punë ... më në fund dita perfekte ... Gëzuar Krishtlindjen të gjithëve.
Americano (Inglese Americano): Today is sunny ... cold ... there is snow on the ground ... it's possible to ski ... I'm not at work ... at last, the perfect day ... Merry Christmas to all.
Francese: Aujourd'hui, il fait ensoleillé ... froid ... il y a de la neige au sol ... il est possible de skier ... je ne suis pas au travail ... enfin, la journée parfaite ... Joyeux Noël à tous.
Tedesco: Heute ist es sonnig ... kalt ... es liegt Schnee auf dem Boden ... es ist möglich zu ski fahren ... ich bin nicht bei der Arbeit ... endlich der perfekte Tag ... Frohe Weihnachten an alle.
Kosovaro (Dialetto Albanese parlato in Kosovo): Sot është me diell ... ftohtë ... ka borë në tokë ... është e mundur të skijosh ... nuk jam në punë ... më në fund dita perfekte ... Gëzuar Krishtlindjet të gjithëve.
Russo: Сегодня солнечно ... холодно ... на земле лежит снег ... можно кататься на лыжах ... я не на работе ... наконец-то идеальный день ... Счастливого Рождества всем.
Italiano: Oggi è soleggiato ... freddo ... c'è neve a terra ... è possibile sciare ... non sono al lavoro ... finalmente la giornata perfetta ... Buon Natale a tutti.
Spagnolo:
Hoy está soleado ... frío ... hay nieve en el suelo ... es posible esquiar ... no estoy en el trabajo ... al fin el día perfecto ... Feliz Navidad a todos.
Cinese (Mandarino): 今天阳光明媚……很冷……地上有雪……可以滑雪……我没有上班……终于是完美的一天……祝大家圣诞快乐。
Ucraino:  Сьогодні сонячно ... холодно ... на землі лежить сніг ... можна кататися на лижах ... я не на роботі ... нарешті ідеальний день ... Щасливого Різдва всім.
Hindi (Indiano): आज धूप है ... ठंड है ... जमीन पर बर्फ है ... स्की करना संभव है ... मैं काम पर नहीं हूं ... आखिरकार, परफेक्ट दिन ... सभी को शुभ क्रिसमस।
  • stefan63
  • stefan63's Avatar
25 Dec 2024 09:02
Anyone figured out how to get Trinamic's TMC5160 drivers working with LinuxCNC?
Category: Driver Boards
STEP/DIR is the way to go and maybe the Makerbase TMC5160 board is preferable since you can set your parameters with jumpers.
25 Dec 2024 08:19
Replied by tommylight on topic Probe basic Install errors
Category: Basic Configuration
CANNOT FIND FILE FOR:custom.hal
Could not open command file 'shutdown.hal'
In your ini file you have references calling those two files, and those two files are not in your config folder.
If there is nothing you added to those files, edit the ini and omit those two entries calling those files, save, try again.
  • Max
  • Max
25 Dec 2024 07:50
Replied by Max on topic One axis loosing it completely
Found the issue!
Checked all encoder connections, everythings fine. Removed the encoder cover and found small aluminum chips, removed them carfully and sealed it of better. Still the same issue.
The problem turned out to be the powersupply I suspect the thing was overheating after a while and shut off so the motor skipped some steps.
I will add cooling fans with fin filters to keep aluminum chips out. Thanks for the help I am happy to have cleared the chips from my encoder.
  • gblcody
  • gblcody's Avatar
25 Dec 2024 05:50
Probe basic Install errors was created by gblcody
Hey guys, I'm struggling. I am beyond frustrated with trying to get Probe Basic to launch fully. I have been trying to get this to work for the better part of 18 hours.
Here is what I know.
I can launch the Dev with the sim on the PC.
I figured out that one of my issues was the screen size. I now have a compatible screen installed.
I have reinstalled the bookworm iso and followed the instructions several times.
I have cleaned and wiped the system at least 6 times and still always come back to an error launching.
i was having the issue of probe basic not launching error but after a wipe and reinstall and apt repair it seems to have gone away.
I am now stuck at this point where "I think" I'm missing the custom.hal. I can not find any hal file by that name.
I have attached a text file of the crash report. I would be very grateful for the help, as I just received a new touch probe that I would like to use.
I apologize in advance if this is in the wrong section.
Let me know if you need anything else! Keep on makin chips!
  • Derek
  • Derek
25 Dec 2024 04:37
Replied by Derek on topic Retrofitting an 89 Chiron FZ12W aka Igor
Which spindle oil is used? Is the chamber where the motor and spindle connect also the oil reservoir? I too have a chiron fz12w I retrofitted.
  • Lcvette
  • Lcvette's Avatar
25 Dec 2024 04:06 - 25 Dec 2024 04:08
Replied by Lcvette on topic To Probe Basic from Gmoccapy
Category: QtPyVCP
Your missing some things from config docs still,
AXES = ?
GEOMETRY = ?
Displaying 21271 - 21285 out of 21863 results.
Time to create page: 0.417 seconds
