  • Grotius
  • Grotius's Avatar
08 Dec 2024 14:48
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Hi Rob,
looks like you have been bussy Grotius
Yeahh...
ill try and find the page in one of my manuals for lathe and share will give you some ideas i think
Perfect.
The super imposed interpreter itself does not track the axis positions as it run's non-realtime.
I see no reason to run it realtime.
Each (sub) interpreter has it's own motion component running on the servo_thread 1ms.
Responsible for scurve motion, probing sequence, homing, etc.
Then the base_tread has it's own components running to execute the position commands from the motion components.
This can be a ethercat servo, a stepgen component, a probe input sensor, etc.
The position feedback is done in the base_thread's, this feedback is stored in the shared memory region(s).
The gui, servo_thread, base_thread, can see the feedback positions by just calling the shared memory name and value.
Will introduce axis group's.
And introducing global variables that can be used by all 3 interpeters. As they now have their variables only local.
Finally i now can start the qt program and start the servo_thread & base_thread from there using a rt_loader class.
Before today this was a problem.
Now also using multiple shared memory region's works fine.
Edit 07 Dec 2024 12:10:
Today did a mayor bug fix. It turn's out that multiple shared memory regions updated by thread's, would not exchange data
properly. Even when mutex etc. was set.
In the end it worked by using a single shared memory region for all thread's.
This is now solved in the source code. Was not the cause.
  • piter_iceman
  • piter_iceman
08 Dec 2024 14:16 - 09 Dec 2024 21:45
Replied by piter_iceman on topic Error reading pdos / motors are not moving - solved!
Category: EtherCAT
I followed this guide exactly:
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
along with the instructions from:
forum.linuxcnc.org/ethercat/53785-instal...epositories#309793.I reinstalled LinuxCNC, but there were no changes
  • PCW
  • PCW's Avatar
08 Dec 2024 14:15 - 08 Dec 2024 14:35
Replied by PCW on topic Xilinx Setup to edit config for 7i92T
Category: Driver Boards
The pinout is determined by the pinout file (PINXXXX.vhd)
This file is identical for Xilinx or Efinix chips. Basically to make
a new pinout, you copy an existing pinout file ( one that's similar
to what you want) to your new pinout file, edit that file to match
the required pinout and module counts. Add that new file to
the project  (with "Edit Project" --> "Design" -->  "Add design file")
and include  it in the toplevel source file (TopEthernet16HostMot2_efx.vhd)
by adding it like this:
--use work.PIN_7I85SD_7I76_SSI_34.all;
--use work.PIN_PMDX126x2_34.all;
use work.PIN_NEWPINOUTFILE_34.all;  <<<<<<<<
--use work.PIN_7I85S_4PWMD_34.all;
--use work.PIN_APSX_SWISS.all;
--use work.PIN_IOONLY_34.all;
--use work.PIN_ST8_RC8_34.all;
Note that only one pinout file is uncommented
The .xml files are for the project manager and the interface designer
you do not edit them directly, nor do you change anything with the interface
designer unless you have different hardware (a custom FPGA card for example)
  • MirkoCNC
  • MirkoCNC
08 Dec 2024 14:15
I forgot to mention, in case of dual-purpose pins like the PINOUT_WLED1_DATA of the Tangbob board, it needs to be configured as regular I/O pin. (It is a dedicated SSPI pin.) In the IDE, it can be done under Place&Route -> Configuration by right mouse click.
  • MirkoCNC
  • MirkoCNC
08 Dec 2024 14:03
Thanks for solving the diff issue, it has given me a real headache.
The Compile button is enabled now and I am going to check, if it compiles etc.
By the way, Tangbob config.json contains a plugin "blink" mapped to pin10, which is not available on the Tangbob FPGA board (not wired on your PCB). Furthermore, pin10 belongs to the bank 3, which works with 1.8V (not 3.3V) causing an error when placing in the toolchain.
(I used the generated files from your program in the Windows Gowin IDE for running the whole process. It gives me more control what's going on during the processing)
  • PCW
  • PCW's Avatar
08 Dec 2024 13:59
Replied by PCW on topic Trion T20 FPGA Questions
SPI should work though a Efinix specific top level file would need to be
made from the Xilinx source.  Efinix tools don't automatically
translate "Z" types into tristate pins so you have to export the signal
_and_ enable pins from the top level file. Note for the current SPI source
(GCSPI) The SPI clock must be routed to a FPGA clock pin.
Any package is OK
  • csurimilan
  • csurimilan
08 Dec 2024 13:38
Accuracy was created by csurimilan
Accuracy
Category: Configuration Tools
Hello,
i finished with my linuxcnc setup and now i have some trouble with the accuracy.
Im using qtDragon and the newest version of linuxcnc (2.9.3 i think).I home my maschine first and after i send it to the G54 g0 x0 y0 z0 and the machine is going there but not reaching exactly the 0 position.
anyone could maybe help me or explain me?
  • machinedude
  • machinedude's Avatar
08 Dec 2024 12:53
Replied by machinedude on topic Black Friday Deal got me :)
Category: Plasma & Laser
I've been gathering and planning quite a bit. My motors and drives came in yesterday and another batch of goodies should be here in the next few days.
I'm still working on my finished plan but have a much better idea of how thing will look coming together.
But with a floating head with a magnetic breakaway and about 5 inches of Z travel i came up with this so far.
  • MarkoPolo
  • MarkoPolo
08 Dec 2024 11:36
Replied by MarkoPolo on topic qtvismach, a axis toolpath
Category: Qtvcp
length = hal.get_value("hor_pos")
length = (float(length) + 115)
mat = Box(60, -30, -30, length, 30, 30)
mat = Color([0.4, 0.6, 0.2, 0.4],[mat])
mat = Rotate([mat],0,45,0,0)
mat = Translate([mat],0,0,0)
mat = Color([1, 1, 0, 1],[mat])
This is how I build a material element mounted in a lathe.
For now, only the material length is determined automatically, depending on the position of the lathe tailstock.
After the first simulation run, the material dimensions are drawn correctly. The problem is with rebuilding the dimension after running another ngc file with different dimensions.
I tried using HalToolCylinder and HalToolTriangle in various ways, but I must be doing something wrong
  • StoneB
  • StoneB
08 Dec 2024 10:34
Replied by StoneB on topic Xilinx Setup to edit config for 7i92T
Thanks PCW and cornholio for your pointers!
I would really want to try a custom firmware as the card will interface with two pre-existing connectors / controllers within a very tight space - adding a DB25 cable which reroutes the ports will be an absolute pain
I have now Efinix loaded and running, and I have found how to load the 7i92t-hm2 project (I assume from other forum posts that the 7i92t25 is for larger projects and so not applicable for me). I'm not able to find a pointer as to where to edit my pins? I read that I need to edit seveni92t.peri.xml but that file looks daunting: how I find which pins (of the two ports) are meant?
Also, thanks for the pointer regarding toggle: I have amended my notes, does it work to have just one Step, or do they need to come in step/dir pairs?
P2: LPT 1 (Slider SFX)
IO Connections for P2
DB25 pin#             I/O   Pri. funk    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       None
14                      1   IOPort       PWM              1        PWM             (Out)
 2                      2   IOPort       StepGen          0        Dir/Table2      (Out)
15                      3   IOPort       None
 3                      4   IOPort       StepGen          0        Step/Table1     (Out)
16                      5   IOPort       StepGen          4        Step/Table1     (Out)     (Toggle 250Mhz PWM)
 4                      6   IOPort       StepGen          1        Dir/Table1      (Out)
17                      7   IOPort       None
 5                      8   IOPort       StepGen          1        Step/Table1     (Out)
 6                      9   IOPort       StepGen          2        Dir/Table2      (Out)
 7                     10   IOPort       StepGen          2        Step/Table1     (Out)
 8                     11   IOPort       StepGen          3        Dir/Table2      (Out)
 9                     12   IOPort       StepGen          3        Step/Table1     (Out)
10                     13   IOPort       None
11                     14   IOPort       None
12                     15   IOPort       None
13                     16   IOPort       None
P1: IO & Encoder (Pendant & Future Spindle)
IO Connections for P1
DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                     17   IOPort       None
14                     18   IOPort       QCount           1        Quad-A          (In)
 2                     19   IOPort       None
15                     20   IOPort       QCount           1        Quad-B          (In)
 3                     21   IOPort       None
16                     22   IOPort       QCount           1        Quad-IDX        (In)
 4                     23   IOPort       None
17                     24   IOPort       None
 5                     25   IOPort       None
 6                     26   IOPort       None
 7                     27   IOPort       None
 8                     28   IOPort       None
 9                     29   IOPort       None
10                     30   IOPort       QCount           1        Quad-A          (In)
11                     31   IOPort       QCount           1        Quad-B          (In)
12                     32   IOPort       QCount           1        Quad-IDX        (In)
13                     33   IOPort       None
Slider SFX Pinout
Pin 1 Relay 1, e.g. main spindle on/off
Pin 2 Direction motor X
Pin 3 Clock motor X
Pin 4 Direction motor Y
Pin 5 Clock motor Y
Pin 6 Direction motor Z
Pin 7 Clock motor Z
Pin 8 Direction motor 4
Pin 9 Clock motor 4
Pin 10-13 Forwarded inputs, e.g. for signals from limit and
 reference switches
Pin 14 PWM signal
Pin 15 Output for ready signal
Pin 16 Toggle signal
Pin 17 Current reduction input (active low)
Pin 18-25 Signal ground (0V, GND)
Thanks for your patient help :)
  • EndCNC
  • EndCNC's Avatar
08 Dec 2024 09:49
(Solved)NameError: name 'tool' is not defined on Probe_Basic_Lathe
Category: QtPyVCP
Problem solved! The solution was a clean uninstallation and then a complete reinstallation.
  • piter_iceman
  • piter_iceman
08 Dec 2024 09:47
Category: EtherCAT
Hello
Thank you for your comments, please see below the updates.
I modified ethercat-conf.xml -
It looks that there is still no connection between XML and linux.I ran the command
sudo dmesg -wH
to monitor system logs in real time. (dmesg_wH.png)
  • The white area at the top of the output corresponds to the period when LinuxCNC was started.
  • The logs below show what happens when the LinuxCNC session is terminated (after clicking "Exit")
The same has been proceed for: sudo dmesg | grep EtherCAT
I would appreciate your support!
  • meister
  • meister
08 Dec 2024 08:47 - 08 Dec 2024 08:54
thanks MirkoCNC,
the -p stands for preview, which should be omitted when generating correctly (fixed in dev branch)
the diff command should be replaced, preferably with a python lib, as it does not exist under windows
EDIT: diff is now replaced with python code
  • angelnu
  • angelnu
08 Dec 2024 08:44
Replied by angelnu on topic Arduino IO Expansion
Category: Show Your Stuff
Hello everyone.
I am trying to connect an MPG encoder, but it does not work, it does not always count to 0. I connect it to an Arduino Nano in pins 2 and 3 that are the pins with interruptions.
I have modified in the .ino file:
#define Quadencs 1;
Encoder Encoder0 (2,3); // a, b pin
const int quadencsig = {2,2};
const int quadencmp = {4.4};
In the .py file
Quadencks = 1
Quadenck = [2,2]
Displaying 22036 - 22050 out of 22095 results.
Time to create page: 0.505 seconds
