  • angelnu
  • angelnu
08 Dec 2024 08:44
Replied by angelnu on topic Arduino IO Expansion
Category: Show Your Stuff
Hello everyone.
I am trying to connect an MPG encoder, but it does not work, it does not always count to 0. I connect it to an Arduino Nano in pins 2 and 3 that are the pins with interruptions.
I have modified in the .ino file:
#define Quadencs 1;
Encoder Encoder0 (2,3); // a, b pin
const int quadencsig = {2,2};
const int quadencmp = {4.4};
In the .py file
Quadencks = 1
Quadenck = [2,2]
  • roland
  • roland's Avatar
08 Dec 2024 08:30
Replied by roland on topic 3D - SpaceMouse on the Robot-Arm
Very, very cool!
  • Mecanix
  • Mecanix
08 Dec 2024 08:13 - 08 Dec 2024 08:25
EMC2 featured on a movie, they made us change the name to LinuxCNC
Nope, not implying anything, i just liked the name and wondered how the hell did they get it registered as it is the equation for energy
E=M*C2
Prolly tied up to that 4-years term elected decriminalized mob. You know, the same mobsters who facilitate the multi-billions annual drug trade, int'l lethal weapons trade, human trafficking, child porn, (the illicit list is endless), all that by means of monetary supplies & financial services?! Hint; hides its true color behind the pretext of "freedom" ;)
Permission granted to do what the f you want. Unethical business practices incl. Enjoy that announced freedom!!
  • DSS
  • DSS's Avatar
08 Dec 2024 06:45
Trion T20 FPGA Questions was created by DSS
Category: Driver Boards
A Couple HostMot2 / Efinix Trion FPGA questions.
  • Is SPI a option or only Ethernet & PCI at present? I did not see a spi _efx.vhd but I may have over looked it.
  • Any reason a T20Q144C4 could not be used instead of the T20F256C4 with Hostmot2? I feel like I may be over looking something obvious for the sake of solderability while perusing the source files.
  • cmorley
  • cmorley
08 Dec 2024 01:23
Replied by cmorley on topic qtvismach, a axis toolpath
Category: Qtvcp
Have you looked at HalToolCylinder and HalToolTriangle ?
These change the shape of an object.
Can you post the material object building code?
  • CallumRD1
  • CallumRD1
08 Dec 2024 01:19
Replied by CallumRD1 on topic EtherCAT hardware requirements questions
Category: EtherCAT
Just closing the loop on this topic. I've gotten my Delta B3 Ethercat X, Y, and Z servos working properly over Ethercat and I decided to take the cheap and easy solution to spindle control for now. I picked up a USB to RS485 stick quick inexpensively and just this afternoon got it working with LinuxCNC over MB2HAL. It took a fair bit of trial and error to figure out all the syntax, but I got there in the end.
Long term, I'd like to find a solution that would allow for full real-time control over the spindle servo for rigid tapping, but I'm plenty happy with this stopgap solution for the time being. Now that I have all 4 servos running properly on a bench, I'm going to hook everything up to my mill tomorrow.
  • cmorley
  • cmorley
08 Dec 2024 01:09
Replied by cmorley on topic Inconsistent values from Versaprobe
Category: Qtvcp
I remember we had a similar problem with a toolchange remap a long time ago.
The toolfile would be written to and then read back as part of the process.
The problem was that the OS would cache the save sometimes and the toolchange failed intermittently.
We used os.fsync() when modifying the tool table to fix this.
This sound similar to your investigation.
I don't know linuxcnc's internals enough to know if this is a possibility.
I wonder if just adding commands between G10 and G43 would help?
I'm not sure what commands cause a tool sync.
The fact that this sometimes works makes it a very difficult case to debug and also possible that only a few suffer from it.
08 Dec 2024 00:22
Replied by tommylight on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
This is the only one i could find that resembles what you describe, but no GUI is visible, just lathe doing it's thing
  • martyop
  • martyop
08 Dec 2024 00:15
Replied by martyop on topic Jitter around 50,000,000 ns
That should be -amd64 not -1md64, my typing error.
  • martyop
  • martyop
07 Dec 2024 23:54
Thanks for your reply.
uname -a reports
Linux garage 6.1.0-28-rt-1md64 #1 SNP PREEMPT_RT Debian 6.1.119-1 (2024-11-22) x86_64 GNU/Linux.
The garage computer has an intel atom processor.
07 Dec 2024 23:54
Replied by tommylight on topic Lathe spindle speed PWM control
Category: Turning
Have a look after 3 minute mark, that is CSS (i think) and that should be included in LinuxCNC
  • MarkoPolo
  • MarkoPolo
07 Dec 2024 23:48
Replied by MarkoPolo on topic qtvismach, a axis toolpath
Category: Qtvcp
The improved color control is nice, but I haven't been able to get the material resizing to work yet.
  • jmelson
  • jmelson
07 Dec 2024 23:43
Replied by jmelson on topic Kuka robot project - hardware choice
-For Pico systems,do you think your brushless PWM servo Amp can drive my motor and the robot's largest motors? (unfortunately, I don't have the nameplates of the largest motors, but I was able to look up on a kuka KR16 that the motors are 2.5KW 5.4A 185V).
Well, the 185 V is an issue, we do not recommend running over about 122 V DC on our servo amps, so that would limit the top speed to about 66% of the rating.  The 5.4 A is not an issue, our amp can go up to 20 A peak.
In principle, resolvers are somewhat absolute,  but if you convert them to quadrature, then you lose the absolute alignment, and have to perform a homing procedure whenever you start the control software.
Jon
  • cmorley
  • cmorley
07 Dec 2024 23:36
Replied by cmorley on topic camera resolution doesn' fit
Category: Qtvcp
I just pushed the fix to 2.9 and master branch.
If you are using a released version, it wont come out till 2.9.4, but we could work around that if you need.
  • cmorley
  • cmorley
07 Dec 2024 23:31
Category: Qtvcp
I pushed HALColorRGB and HALColorFlip functions to master.
I added them to the docs too.
Displaying 22051 - 22065 out of 22095 results.
Time to create page: 0.545 seconds
