  • NWE
  • NWE's Avatar
31 Jul 2026 22:40
using linuxcnc on a raspberry pi to prog and test steppers and servos
Hi Group
I would like to potentially use linuxcnc on a Raspberry Pi to program and test steppers and servos
  • Are there any solutions that I can see samples of or potential uses that are using a Raspberry Pi or Arduino and LinuxCNC to control and test servo and stepping motors?
  • One plan is to have a test bench to play with ideas; this will have a controller board, some switches, sliders, connectors for motors, a variable power supply, etc..
    - Could LinuxCNC be used for this? i.e can i program it with Python or similar to run my code snippets or a full program?
    - When connecting motors that use pulse and direction, will I be able to connect any motor as long as the variable power supply is adjusted to give the right power to the motor?
    - Has anyone done this before like this?
  • Another plan is to create individual builds that will have one or more motors, sensors, switches, etc.. and will be all built into a case or item as a stand-alone solution. With a customised touch control screen. So when powered on, it boots up and is ready to use and be controlled from the touch control screen.
    can linuxCNC be used like this?
    if so is ther any links to videos or projects that do similer?
    Z
Sounds similar to some of my customizations. I get, you won't need to run G-code files?
Look at the  hal introduction , and the tutorial that follows. There are several methods of connecting your own custom gui to a stand-alone basic hal config. I tend to use glade. Yes you can then also have the app auto-start, that is configuration in the desktop environment, same as auto-starting any other app at boot.
31 Jul 2026 22:39
  • tuxcnc
  • tuxcnc
31 Jul 2026 22:38
Replied by tuxcnc on topic Hole Spotting
Hole Spotting
Category: Fusion 360
I'm trying to stay in Fusion (for now at least).
In my opinion using Fusion for plasma (or laser) is like bought truck for drive to church - more troubles than benefits.
My favorite option is Librecad plus dxf2gcode - GPL and cost free.
Try this, even if you will not like them, this is simple and you will easy learn something.
  • rodw
  • rodw's Avatar
31 Jul 2026 22:29
Replied by rodw on topic Hole Spotting
Hole Spotting
Can't help in fusion but in Sheetcam you can create layers and you can define the minimum diameter of holes you can cut (say 12mm) so you move all of the small holes onto a new layer. When you generate the code for that layer  it will create the spots at the hole centre.
The torch won't fire if there is no movement in the following segment so move to relative coordinates to move a tiny amount to keep LinuxCNC happy and make the torch fire.
So now see if you can translate that to fusion.
  • tuxcnc
  • tuxcnc
31 Jul 2026 22:20
You can build this, but it will be absolutely useless.
  • hitchhiker
  • hitchhiker
31 Jul 2026 22:05
Replied by hitchhiker on topic PUMA 200 Robotarm and some Hal/INI issues
Which infos you need?
I can upload actual hal and ini again.
I thinking about the issue with the moving b axis when turn a axis.
Issue is that the b axis encoder is not reading the moving because it comes from the mechanical buuld of a ans b axis. Should i make a video???
  • dlv
  • dlv
31 Jul 2026 21:41
Hole Spotting was created by dlv
Hole Spotting
I'm reasonably decent at CAD having used Fusion360 to design and 3D print for some time now.  However I'm a newbie (and I mean COMPLETE newbie) to CAM, gcode and post processors.
I've built a 1500x1500mm downdraft plasma CNC table.  It's working rather well.  I've managed to get myself as far as the most basic of understanding manufacturing in Fusion.  Using the PP from the forum here I can get a flat pattern, generate a tool path and post it to an NC file and get parts cut with reasonable success.
I haven't figured out hole spotting though.  I know folks may say use something like Sheetcam and I'm sure it's a good solution but I'm trying to stay in Fusion (for now at least).
I tested QtPlasmaC's built in spotting function by writing a really simple gcode file to spot at the torch's current zeroed position and it works.  The built in spotting is quite nice actually.  Leaves a perfect little dimple (I'm testing with 1/8" aluminum sheet).  500ms pulse@20A
G20          ; Set units to inches
G90          ; Absolute distance mode
N60 F#<_hal[plasmac.cut-feed-rate]>  ; Copied from other working NC files
G0 X0 Y0     ; Torch is already jogged to test location
M3 $2 S1     ; Fire spotting tool (triggers the millisecond timer)
G91          ; Switch to relative (why?)
G1 X0.000001 ; Microscopic move to satisfy LinuxCNC motion controller (why?)
M30          ; End program
Before I try to reverse engineer the Fusion360 post processor to figure this out I'm wondering if there's any cool tricks in Fusion to get the PP to write the M3 $2 S1 command at a specific point.
Or as a reasonable work around get it to write something out that's easy to search and replace with M3 $2 S1.   If that makes sense.
I did see something about adding in a drilling operation but when I tried it I discovered the free version of Fusion won't allow that.
Also not sure why the G91/G1microscopic move is necessary.  Pretty sure the tolerance settings will result in it being ignored but without it I get an error loading the file that it'll move outside my machine boundary.  I don't think that's the case but QtPlasmaC still throws the error.
Anyway I hope this isn't a bunch of utterly annoying newbie questions.  :)  I sincerely appreciate any help with this part of the learning curve.
Cheers,
-Dave
  • kostyadnepr
  • kostyadnepr
31 Jul 2026 20:54
Horizontal Z axis for Qtvcp ui was created by kostyadnepr
Category: Qtvcp
Hi everyone,Ho to make visualization of the tool path for machine with naturally horizontal Z axis?A would like to use it for surface grinder and possible horizontal milling machine. Those machines have XYZ axis, but Y is vertical and Z is horizontal. Is there any simple way how to rotate virtualisation?
  • PCW
  • PCW's Avatar
31 Jul 2026 17:34
Replied by PCW on topic 7i80db16 7i85s only one stepgen out
Category: Driver Boards
What does mesaflash --readhmid report when  the 7i80db_16_7i85sx3d.bit firmware is loaded?
  • NWE
  • NWE's Avatar
31 Jul 2026 17:23
That all sounds correct. I think I misunderstood your problem with Z position. Can you provide more details?
  • hitchhiker
  • hitchhiker
31 Jul 2026 16:14
Yes.. power up.. start linuxcnc... loose the brakes.. bring all joints to the sharpie marked position. Then reference/home to the index of every single encoder.
After this all joints at zero. B axis has offset 1 degree that there no failure message comes from linuxcnc because.. if all joints at 0 degree they are in singluarity... thats why its needed to brin as example a small offset to the B axis.
Thats how i understand it.
  • Logthor
  • Logthor
31 Jul 2026 16:06
Replied by Logthor on topic DIY CNC 2
DIY CNC 2
Category: Milling Machines
I really appreciate you info dumping here; so much good stuff to know.
  • billykid
  • billykid's Avatar
31 Jul 2026 15:47
7i80db16 7i85s only one stepgen out was created by billykid
I had a 7i80 with a 7i85s and a 7i37 working with 3 stepgen, I tried reconnecting it and only a step dir signal comes out of the y-axis and that's it. I loaded the firmware 7i80db_16_7i85sx3d.bit. I don't understand what could have happened, I put it away and all three axes worked.
  • NWE
  • NWE's Avatar
31 Jul 2026 15:41
I only had zero x y z in genser mode... not correct?!
First at powerup you have to zero every joint, did you do this?
disclaimer:
I have not yet had opportunity to run a LinuxCNC robot, except for playing with the sim. I have spent many hours programming/repairing Fanuc and ABB robots. Some day when I have enough projects completed to make more space in my shop I want to buy an old robot and put LinuxCNC on it.
  • hitchhiker
  • hitchhiker
31 Jul 2026 15:27
I know that when i rotate A axis the B axis make moves.. because the mechanical stuff inside the hand goes over small gears.. but this should not be the problem or???
Displaying 2266 - 2280 out of 11361 results.
Time to create page: 0.367 seconds
