  • cmorley
  • cmorley
11 Oct 2024 03:39
Replied by cmorley on topic Retract no longer works after a while.
Category: Qtvcp
I don;t see any glaring problems in the INI.
You could try checking the system monitor to see if a particular program is stealing all the cpu cycles.
You could try a larger servo period to give the GUI more cycle time, but if this is a 'sometimes' problem, I would look at hardware: memory, storage medium, temperature, power supply.
  • cmorley
  • cmorley
11 Oct 2024 03:24
Replied by cmorley on topic Where did the REFX REFY REFZ buttons go?
Category: Qtvcp
It's also possible to customize (a bit ) what shows on the popup context menu in stylesheets:
linuxcnc.org/docs/devel/html/gui/qtdragon.html#_stylesheets
  • cmorley
  • cmorley
11 Oct 2024 03:20
Replied by cmorley on topic Probe Duplicate oWord?
Category: Qtvcp
line 173 and 185 both define o510
You need to change one to another number.
  • digiex_chris
  • digiex_chris
11 Oct 2024 01:28
> I saw some pretty nice ones you have that look like they might plug into a pi?
Do you mean this one ?
github.com/multigcs/rio-iceshield
it's not so easy to solder :(
Yes that's the one thank you! Which XO91 did you end up going with? Is that for the SPI CLK? I'm looking into having jlcpcb solder it for me, their cost for the parts is quite low.
  • gardenweazel
  • gardenweazel's Avatar
10 Oct 2024 23:39
Probe Duplicate oWord? was created by gardenweazel
Category: Qtvcp
Any reason why I am getting a "duplicate oWord on this one?
10 Oct 2024 23:30
Replied by tommylight on topic New update on STMBL
New update on STMBL
Category: Driver Boards
That is a nice price, very nice in fact, considering how everything has gone up.
Thank you very much, but for now i can not buy any ...
One of the reasons is here: :)
forum.linuxcnc.org/54-user-exchange/5403...-sale?start=0#311679
  • Freak
  • Freak
10 Oct 2024 23:10 - 18 Oct 2024 20:21
10 Oct 2024 22:38
Replied by tommylight on topic No of I/O pins available on Pi 5
26 to 28 depending on who you ask
www.google.com/search?client=firefox-b-l...+number+of+usable+io
I like parallel port, i do not like RPI, so here is my take:
-use HP Z200 or Z210 old workstations, they have a parallel port header, built like a tank and never fail
-Some Dell 980 something or another have built in parallel ports, the "tower" version only
-HP 800 or older 8000 series small form with PCI-E port with add on parallel port cards
-On the big ones you can put 2 or more parallel port cards for more IO
-Mesa 7i92T, connects to PC through EtherNET so easy to find PC's, can do 34 IO pins at very, very high speeds so you can use more microstepping on your drives for much smoother motion and less vibrations
-Mesa 7i96S, has headers for everything, EtherNET, very fast, and can also do a parallel port at very high speeds.
10 Oct 2024 22:27
Replied by tommylight on topic LinuxCNC 2.8 Buster on VM
Category: Installing LinuxCNC
Any progress on this?
You can always use a USB to boot LinuxCNC from it and use it even to control the machine, without installing anything.
Will not work for Probe Basic as that needs to be installed, though.
10 Oct 2024 22:23
Qtdragon interface touchscreen no longer responds during operation.
Category: Qtvcp
First thing i would check is if the monitor and PC are properly grounded, touch screens are now usually capacitive so very susceptible to EMI.
10 Oct 2024 22:17
Replied by tommylight on topic Backspace key identifier - Solved
Bump to remove it from the "no replies" list.
Thank you.
10 Oct 2024 22:14
Replied by tommylight on topic interresting surge protection view
It does not say what kind/type of surge
1-from the grid due to something disconnecting elsewhere and voltage going above tolerance
2-from lightning strikes and the resulting induced surge on the grid wiring
First is quite easy to protect from although absolutely not 100% safe, using fuses and varistors on the power input, fixed a fair share of those, i would say 95% fix rate so far.
Second is a cr@p shoot as it is unpredictable and varies a lot on how much energy got dumped, had from easy fixable to utterly destroyed.
As a side note, lightning strikes usually cause damage to whatever has long cables, and it is proportional, so longer cables = more chances of something letting out the magic smoke. Cabled camera surveillance systems and ISP routers suffer from this often.
10 Oct 2024 22:00
Replied by tommylight on topic siemens 1200 safety for sale
Category: User Exchange
Naming a price usually helps move things along, pictures too.
10 Oct 2024 21:59
Probe Basic Lathe - Konfiguration von Axis übernehmen
Category: QtPyVCP
Google translate:
Hello community,
I have completed almost all the settings for my lathe with the "Axis" interface and am now slowly thinking about transferring the whole thing to the "Probe Basic Lathe interface".
What is the best way to go about this and what do I need to pay attention to?
Tips and advice?
"Probe Basic Lathe" is already installed on LinuxCNC 2.9 and also works in its basic configuration (starts without error messages).
Thanks and regards
Moving it to QtPyVCP section for now.
Displaying 22951 - 22965 out of 22970 results.
Time to create page: 0.511 seconds
