25 Aug 2024 13:48
Replied by tommylight on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
Hmmmm... is the loop being closed in the drive or LinuxCNC?
If in the drive, first thing to check is the encoder wiring (if it is not factory sealed), then change motor wires to change the direction.
  • PCW
  • PCW's Avatar
25 Aug 2024 13:40
Replied by PCW on topic 7i96s with 7i76 on P2
Category: PnCConf Wizard
i made it work already, somehow it could see 10 stepgens and after modification of the hal file to read stepgen 05 and 06 instead of 00 and 01 previous, now the axis servos can run, but i am still unable to get the outputs to work.
Anyone able to let me know in a 7i96s + 7i76 config, what hal label will output 0 on the 7i76 be on linuxcnc?
It will be on sserial channel 1
You can check the I/O pin mapping by running:
mesaflash --device 7I96S --addr [card_ip_address] -dbname3 7i76 --readhmid
  • Aciera
  • Aciera's Avatar
25 Aug 2024 13:31
Replied by Aciera on topic durchmesser stimmt nicht
Category: Other User Interfaces
Invalid tab configuration
Lösche doch mal das hier aus deiner ini:
  #PYVCP = custompanel.xml#
  EMBED_TAB_NAME=Probe Screen
  EMBED_TAB_LOCATION = ntb_user_tabs
  • PCW
  • PCW's Avatar
25 Aug 2024 13:20 - 25 Aug 2024 13:51
Editing Bitfile on 7i97t for extra smart serial connections
Category: Driver Boards
The problem with the .pin file in the distribution zip file is that it was made assuming
you had a 7I85 so it lists 7I85 pins not P1 pins. To make a pin file that lists P1 pins:
mesaflash --device 7I97t --addr [card_ip_address] --readhmid > 7i97t.pin
Also in case there is a question, 26 pin header physical pin arrangement is:
1  2
3  4
5  6
 etc etc
Pin 1 is marked with a square pad
This means than a flat cable has wires in numerical sequence
(with the red wire being pin 1 if made correctly)
  • besriworld
  • besriworld
25 Aug 2024 13:15
Replied by besriworld on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
What error is the driver showing?
  • karlhe
  • karlhe
25 Aug 2024 13:06
Replied by karlhe on topic durchmesser stimmt nicht
Hallo, danke für die info, häckchen entfernt...neuer fehler report, neues geändertes maschinen verzeichnis..Grüße karlhe
25 Aug 2024 12:03
Category: EtherCAT
Closed loop in LinuxCNC must be tuned in LinuxCNC, for stepper systems mainly just the P and FF1 values.
For P as high as it can go without vibrations at standstill, then just back a bit to be on the safe side.
For FF1 there is a corelation that i can not recall and can not check as i am on the phone, but try some rough values like 0.4 or 0.5 or 0.6 and see how it works then some finer value changes after you get it to jog, untill you can jog at full speed without error.
  • Lcvette
  • Lcvette's Avatar
25 Aug 2024 11:24
Replied by Lcvette on topic Display setup sheet
Display setup sheet
Category: QtPyVCP
check the custom config yaml file for the changes made. always compare your sim config files first that is 99% of the time where your error originates from. if the sim launches and runs without issue.
  • Lcvette
  • Lcvette's Avatar
25 Aug 2024 11:19
Replied by Lcvette on topic probe_basic read jog increments
Category: QtPyVCP
you could make a custom ui file, i believe there is some discussion on this on the discord chat.
  • Lcvette
  • Lcvette's Avatar
25 Aug 2024 11:12
Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
Category: QtPyVCP
sure, just submit a pull request maybe and we can put the options in the sim config
25 Aug 2024 11:11
Replied by Cant do this anymore bye all on topic How to Uninstall LinuxCNC
Category: Installing LinuxCNC
Sometimes what I think is clear to myself doesn’t end being that way for others.
25 Aug 2024 11:08
Replied by Cant do this anymore bye all on topic Editing Bitfile on 7i97t for extra smart serial connections
Any file ending in “bit” is the programming file for the card.
Any file ending in “pin” is a plain text file that describes the pin functions and which connector and pin it is on.
The best resource for location of connectors for you board is the Manual for the board.
  • Krulli_Fräser
  • Krulli_Fräser
25 Aug 2024 09:15
I already have the correct bitfile on the card. My question is where the physical pin on the card is located.
when the bitfile says expansion port Pin 1 where is it on the expansion connector on the card.
  • fat238sg
  • fat238sg
25 Aug 2024 09:05
Replied by fat238sg on topic 7i96s with 7i76 on P2
  • shaying526
  • shaying526
25 Aug 2024 09:03
Replied by shaying526 on topic How to Uninstall LinuxCNC
thanks!
very clear. I will try it
Displaying 23311 - 23325 out of 24338 results.
Time to create page: 0.462 seconds
