28 Apr 2024 23:28
Replied by tommylight on topic Error in tool_offsetview.py
Category: Qtvcp
I have a 4K that does not get much use since i got a 34" ultrawide, so i might make some time to test it, so what would that entail?
  • MarkoPolo
  • MarkoPolo
28 Apr 2024 22:49 - 28 Apr 2024 22:51
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
It's hard to find a perfect solution, these empty spaces aren't the best either. I only have a 2560 screen, if anyone has a 4K screen, please try it, I'd love to see such a screenshot. In fact, I don't think anyone uses 4K screens for the machine. I don't see any side effects, so such a high resolution is not a problem.
  • shasse
  • shasse
28 Apr 2024 22:45 - 29 Apr 2024 12:42
Problems trying to customize safe_height.setRange(...) via qtplasmac_custom.py
Category: Plasmac
I was on the right track with the idea above, but it still did not fully work. Since the self.load_plasma_parameters() call also happened before the self.w.safe_height.setRange(...) call the in-memory prefs data was still respecting the built-in safe_height range that was in effect when it was initially loaded. The solution is to call self.load_plasma_parameters() again after updating the safe_height.setRange.
self.w.safe_height.setRange(0.125, int(self.maxHeight))
self.w.safe_height.setValue(self.PREFS.getPref('Safe Height', round(25.0 * self.unitsPerMm, 0), float, 'PLASMA_PARAMETERS'))
That worked. I could change, save, and reload Safe Height values below 0.75".
But looking at this now I think I could ditch the explicit self.w.safe_height.setValue(..) call since that is already being called in the self.load_plasma_parameters(). I'll try that next time I'm at the machine, but the good news is I think there is a way to customize the Safe Height using the stock customizations methods.
Thanks for the help Phillip!
Scott
  • jg00163206
  • jg00163206's Avatar
28 Apr 2024 22:45
slowly making progress. but still a long way to go.
m3,4,5 won't turn on the #5 output. all it does is turn on the spindle led on the mesa board. i tried all the m codes i could think of and i still can't get it working. i can enable the servo right from the drive if i need to. even with it enabled from the drive, i can't get it to move. i keep getting an hm2 error. maxvel is too large for current step timing on stepgen 04. when im in hal show, it shows the spindle enable is connected to the #5 output but when i turn it on, (through m code or from the gui) it just turns the spindle led on on te mesa board. i am new to linuxcnc but that just doesnt seem right to me. why is the led on te mesa board coming on? it's not connedted to anything. im at a loss here. is there a hal file that i could compare it to that is running a servo for a spindle? it shouldn't be this difficult. im missing something simple.
  • bullocks
  • bullocks
28 Apr 2024 22:22
Replied by bullocks on topic 2 Axis Foam Cutting CNC Controller Software
Got it. Solidworks because we are a racing team that uses it. Once it is in inkscape, do i save it as a DAT file in order to get it to run on the controller software?
  • cmorley
  • cmorley
28 Apr 2024 22:09
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
It's v e r y stretchy! I see what you mean about the look of the controls for instance when stretched.
try my rough changes to your changes
28 Apr 2024 20:55
Replied by tommylight on topic Retrofitting HURCO BMC30
Category: Milling Machines
Not sure as it was a long time ago, but i am pretty sure you can have everything working with just:
7i92TM plugged directly to 7i77 and a 7i84 connected with a cut in half LAN cable.
That is 64 inputs and 32 outputs, should be more than enough.
I did it the way i did as i am a control freak and like to have everything at a glance so 7i70 and 7i71 having LED for each IN/OUT helps with that. And if you look at my retrofits, all have every IN/OUT on screen ... yeah freak! :)
28 Apr 2024 20:47
Replied by tommylight on topic 2 Axis Foam Cutting CNC Controller Software
Yes and yes.
LinuxCNC is an Open Source project, and so is Inkscape.
And i have to ask, why use SolidWorks for 2D?
  • cncwhacko
  • cncwhacko
28 Apr 2024 20:26 - 28 Apr 2024 20:28
Replied by cncwhacko on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
File Name: nvmpg.bin.zip
File Size:22 KB
Attaching the nvmpg .bin I was able to extract from my unit. Hope this helps debug what's going on with the TFT/display oddities!
  • Spope
  • Spope
28 Apr 2024 19:48
Replied by Spope on topic Newbie here pin assignment
Category: Basic Configuration
Sorry for the late response. Truth is I found the replies quite daunting and so turned my attention to trying to get the software running. After repeated attempts I finally managed to get the exe file off the floppy disk and on to the harddrive. Once that was accomplished and DOS commands jogged from memory I managed to get it all running, well almost all. There's also a rotating axis which can run on one of the one of the three axises and which I think I'll wait a bit with. The DOS program is all in German which doesn't help a lot.
  • royka
  • royka
28 Apr 2024 19:03
Replied by royka on topic n100 mesact get cpu speed
A newer kernel might help indeed, my N100 mini pc without rt kernel, just preempt has a ping of 0.5 ms to the router. This is with kernel version 6.9.0 rc4.
  • MarkoPolo
  • MarkoPolo
28 Apr 2024 18:50
Category: Qtvcp
Thanks, it works fine this way.
I only changed the settings for "max_velocity_override" so that it took the max speed from the "MAX_LINEAR_VELOCITY" value
        FACTOR_VELOCITY_OVERRIDE = float(INFO.get_error_safe_setting("DISPLAY", "DEFAULT_VELOCITY_OVERRIDE"))
        DEFAULT_VELOCITY_OVERRIDE = float(INFO.get_error_safe_setting("DISPLAY", "MAX_LINEAR_VELOCITY", )) * FACTOR_VELOCITY_OVERRIDE * 60
        ACTION.SET_MAX_VELOCITY_RATE(DEFAULT_VELOCITY_OVERRIDE)
Try qtdragon with the ability to stretch to 3840x3840
  • rasmus
  • rasmus
28 Apr 2024 18:47 - 28 Apr 2024 18:52
Replied by rasmus on topic Retrofitting HURCO BMC30
Thank you for the quick replay as always!
Yes that is maybe a little overkill.
When having a further look at it a 7i92tm directly connected to a 7i77 (EUSurplus did have this in stock), a 7i74 and 7i70 and 7i71 for IO:s would also work fine as I can understand it and it will be a little cheaper as well
  • bullocks
  • bullocks
28 Apr 2024 18:21
Great, thank you for the info. Can I use solidworks and get the file into Inkscape from there? (Save as a 2D dxf file and import it into Inkscape)
Also is LinuxCNC free?
Displaying 26356 - 26370 out of 26678 results.
Time to create page: 0.473 seconds
