  • jmelson
  • jmelson
23 Apr 2024 14:05
Any other driver board choice except mesa board?
Category: Driver Boards
No, these USB to parallel adapters do not work properly as a stepper output.
You can get PCI or PCIe parallel port cards to plug into your PC motherboard.
There is also the Pico Systems universal stepper controller board (my product)..
Jon
  • Abdulkareem
  • Abdulkareem
23 Apr 2024 14:03
Auto tool measuremnt when homing in QT Dragon
Hi every one i want to measure the tool automatically when homing in Qt Dragon, any help how to do that ?
  • drboeller
  • drboeller
23 Apr 2024 13:58 - 23 Apr 2024 14:12
Replied by drboeller on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I have exact the same problem with this drive.
Tried:
ethercat state -p0 PREOP -> drive shows 20ry, 2 is flashing
ethercat state -p0 INIT -> drive shows 10ry
ethercat state -p0 SAFEOP -> drive shows 20ry, 2 is flashing
ethercat state -p0 OP -> drive shows 20ry, 2 is flashing
Linuxcnc startup:
20ry
Switch machine on
40ry
10s later
F0ry and log shows safeop+error
Log Shows:
  +3,998716] EtherCAT WARNING 0-0: Slave did not sync after 5000 ms.
[  +5,004000] EtherCAT ERROR 0-0: Timeout while setting state OP.
  • MarkoPolo
  • MarkoPolo
23 Apr 2024 13:54
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Hi Chris
Have you looked at the files I sent?
I don't know if you were thinking about this arrangement or should I do something differently?
Marek
  • PCW
  • PCW's Avatar
23 Apr 2024 13:50
Can not get stepper motors to move with Gecko g250x drivers
Category: PnCConf Wizard
It means the step pulses are being generated and the drive is not responding
maybe enable related?
I would also check setting hm2_7i96s.0.stepgen.00.step.invert_output true
and seeing if that gives you a bright LED on TB1 Pin 3
23 Apr 2024 13:46
Replied by tommylight on topic PNCconf 7i92H and 7i76
I would change the 5V power supply first, find a good one, preferably MeanWell or Delta or FSP or ... older Samsung mobile chargers, original ones only.
  • Sandro
  • Sandro
23 Apr 2024 13:42 - 23 Apr 2024 13:45
Replied by Sandro on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Alright I can check on the weekend. If I remember correctly when starting LCNC the diplay went from 20ry (preop?) to 40ry (safeop?) to 4hry after about 10 sec (safeop + error). When exiting it went back to 20ry.
Did you have to do some special configuration on the driver end?
  • stonebite
  • stonebite
23 Apr 2024 13:36
Replied by stonebite on topic PNCconf 7i92H and 7i76
if I use a standard example file, e.g. When I open “axis” in LinuxCNC, nothing happens.
When I open the STONEBITE AXIS file, which I created with PNCconf, there is no error at first and after about 30 seconds the same error always occurs.
  • cmorley
  • cmorley
23 Apr 2024 13:31
Replied by cmorley on topic z_level_compensation
Category: Qtvcp
net    xpos-cmd    z_level_compensation.x-pos    #      <= axis.x.pos-cmd
net    ypos-cmd    z_level_compensation.y-pos    #      <= axis.y.pos-cmd
net    zpos-cmd    z_level_compensation.z-pos    #      <= axis.z.pos-cmd
This is no good. Why did you comment out the end?
  • Smitherman
  • Smitherman
23 Apr 2024 12:17
Replied by Smitherman on topic LinuxCNC for SLA, DLP and mSLA/mLCD Printers
Category: Show Your Stuff
What a nice Project!
would Like to Work on Something similiar in the Future, is there a way to Talk to you directly?
23 Apr 2024 10:20
Close LinuxCNC, start again, does the same thing happen?
  • meister
  • meister
23 Apr 2024 09:40 - 23 Apr 2024 09:41
gCode/NGC preview/thumbnailer was created by meister
little tool to convert ngc to svg:
github.com/multigcs/riocore/blob/main/riocore/files/ngc2svg.py
it use the rs274 standalone command from linuxcnc,can only generate 2d (XY-Plane) previews
  • rodw
  • rodw's Avatar
23 Apr 2024 09:24
Mesa 7i92 Installation, considering old ATX psu for I/O voltage source...
This video of mine will help.
Its for the 7i76e but its all similar.
23 Apr 2024 09:18
Replied by Cant do this anymore bye all on topic Mesa 7i92 Installation, considering old ATX psu for I/O voltage source...
Meanwell supplies will be fine, been using them for years.
I power mine together, actually I think mine are powered directly from the 7i92.
The Mesa I/O are pretty hardy and have no issues using them directly.
No need to worry about card drivers these, pretty much everything is handled via the hostmot2 driver & the hm2_eth driver, which are loaded via hal. Config is done when loading the hostmot2 driver.
Once the hardware side is setup, load the required firmware via mesaflash and then you can almost forget about mesaflash. The rest is getting the ini & hal files done. This is a mix of using the config program of your choice and editing by hand.
23 Apr 2024 09:08
Displaying 26671 - 26685 out of 26686 results.
Time to create page: 0.514 seconds
