  • rodw
  • rodw's Avatar
04 Apr 2026 09:27
Replied by rodw on topic Ethercat SDOS to XML
Category: EtherCAT
Damn,
I am sick of this device!
Had it working with one register, redid it all properly, wrote a script to set them all and now none of the vfd registers are showing. I'll check dmesg again later....
I'll look at your tip...
  • HansU
  • HansU's Avatar
04 Apr 2026 08:38
Replied by HansU on topic Display slightly too big
Category: Gmoccapy
Problem came back! Something updated, possibly Debian, and now my screen is too wide again. See attached photo. What's different is that I can't set it to Start as Windowed and then back to Start as Fullscreen to fix the problem. Also, the modification to Gmoccapy by alex_sar earlier in this thread does not work anymore, although it did for 6+ months.
My touchscreen monitor is set for native resolution, 1024 x 768
I have the latest version of Debian Bookworm.
I thought that updating everything might help, so I updated LinuxCNC from 2.92 to 2.93 and Gmoccapy from 3.4.6 to 3.4.8. No joy.
Help me
newbynobi, you're my only hope!
Can you post your configuration? Its this still an issue with LinuxCNC 2.9.8 ?
  • RotarySMP
  • RotarySMP's Avatar
04 Apr 2026 08:24
Gmoccapy scaling up each time you exit tool table - 2.9.8 trixie
Category: Gmoccapy
I just realised that the main Gmoccapy screen now behaves nicely. However, now I no longer have the tab for Andy's lathe macros.
  • HansU
  • HansU's Avatar
04 Apr 2026 08:00
Category: Gmoccapy
It's not really an error in your INI file. The lathemacro just needs too much space for some reason and in ntb_user_tabs is just more space available ;-)
  • RotarySMP
04 Apr 2026 07:25 - 04 Apr 2026 07:25
Category: Gmoccapy
Hans got me sorted out. I had an error in my INI.
He had me replace:
with
EMBED_TAB_LOCATION = ntb_user_tabs
Now it has stopped scaling.
Big thanks to Hans for getting that straight.
Cheers,
Happy Mark :)
  • Marcos DC
  • Marcos DC's Avatar
04 Apr 2026 07:18
Hello, I would like to add an EtherCAT IO device. What should I do
Category: EtherCAT
from your latest output, both PDO entries are clearly 16-bit and your XML uses bitLen="16", so that part looks correct.
also, halType="u32" does not mean the PDO is 32-bit. It only affects how the value is exposed in HAL.
it doesn't look like a bit length issue anymore.
given that, I would focus on:
- XML syntax issues (even a small typo can break it, and LinuxCNC may stay silent — checking dmesg helps here)
- verifying that the PDO/SM structure matches exactly what `ethercat pdos` reports
- keeping the mapping minimal until it reaches OP
once it reaches OP, then refine the mapping.
  • cekaa
  • cekaa's Avatar
04 Apr 2026 06:37
Category: EtherCAT
I struggled a lot because it was a topic I didn't understand at all. I added the pdos and the lcec_configgen result, but I didn't understand what kind of structure I was supposed to create.
When 32 bit = 16 bit
ceka@debian:~$ ethercat slave
0 0:0 OP + XINJE-DS5C1 EtherCAT(CoE) Drive Rev4.0 v3.7.70
1 0:1 OP + XINJE-DS5C1 EtherCAT(CoE) Drive Rev4.0 v3.7.70
2 0:2 OP + XINJE-DS5C1 EtherCAT(CoE) Drive Rev4.0 v3.7.70
3 0:3 SAFEOP+ERROR E EM32DX-E4   ????????????????????????????????????????????
ceka@debian:~$
old now
ceka@debian:~$ ethercat pdos
=== Master 0, Slave 3 ===
SM0: PhysAddr 0x1000, DefaultSize  128, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1400, DefaultSize  128, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1800, DefaultSize    5, ControlRegister 0x64, Enable 1
  RxPDO 0x1600 "RxPDO0-Map"
    PDO entry 0x7000:01, 16 bit, "OUT"
SM3: PhysAddr 0x1c00, DefaultSize    7, ControlRegister 0x20, Enable 1
  TxPDO 0x1a00 "TxPDO1-Map"
    PDO entry 0x6000:01, 16 bit, "IN"
ceka@debian:~$
lcec_configgen
<slave idx="3" type="generic" vid="0x00004321" pid="0x01100073" name="D4">
      <!--EM32DX-E4-->
      <syncManager idx="0" dir="in"/>
      <syncManager idx="1" dir="out"/>
      <syncManager idx="2" dir="out">
        <pdo idx="1600">
          <!--RxPDO0-Map-->
          <pdoEntry idx="7000" subIdx="01" bitLen="16" halPin="out" halType="u32"/>
        </pdo>
      </syncManager>
      <syncManager idx="3" dir="in">
        <pdo idx="1a00">
          <!--TxPDO1-Map-->
          <pdoEntry idx="6000" subIdx="01" bitLen="16" halPin="in" halType="u32"/>
        </pdo>
      </syncManager>
    </slave>
  </master>
</masters>
ceka@debian:~$
Would the `lcec_configgen` command help? Could someone write the correct configuration for me?
  • Hakan
  • Hakan
04 Apr 2026 06:30
Replied by Hakan on topic Ethercat SDOS to XML
Category: EtherCAT
Always something new to learn. Write-once sdos, ok.
If you aren't too bored of the device you might try with initCmds
if you understand the format of the input file. I struggle there but
there are examples I guess.
  • timo
  • timo
04 Apr 2026 06:09 - 04 Apr 2026 06:24
Nice small 5 axis machine with some nice features
Category: Show Your Stuff
I always wonder how to program those things.
Programming I see as the big bottle neck for 5-axis.
The type of machine seems to be of very limited practical use :-)
  • NWE
  • NWE's Avatar
04 Apr 2026 06:07
Can't install Linux 2.9.8 hybrid alongside Windows 11.1
Category: Installing LinuxCNC
Same here. with dual boot things get complicated when I want to replace one OS and keep the other. My fix has been: one hdd = one os.
Just to be safe, I pull all bootable drives and leave only the one connected, to which I'm installing the OS. This greatly reduces my chance of making mistakes when selecting what installs where. My dual boot mini-pc contains two SSD's.
That said, I can see the case for dual booting on one drive, especially if the machine only has one drive slot. Did you see  wiki.debian.org/DualBoot/Windows  ?
  • NWE
  • NWE's Avatar
04 Apr 2026 05:44
Wow!
Two things I see especially:
1. Wireless probe, probably bluetooth.
2. Run the program, providing feedrate override by spinning the jog wheel. Then switch over to programmed feedrate.
  • GeekyBoi
  • GeekyBoi
04 Apr 2026 05:17
Does auto-leveling for Probe Basic exist?
Category: QtPyVCP
I want to use my CNC to make PCB prototypes and just wanted to check if auto-leveling for Probe Basic exists.
By "auto-leveling" I mean the ability to probe at grid points and modify a gcode file to compensate for an uneven bed/PCB surface.
I have seen some auto-leveling projects compatible with LinuxCNC but not one that is compatible with Probe Basic.
Thanks in advance
  • rodw
  • rodw's Avatar
04 Apr 2026 05:14
Category: EtherCAT
Success! I used Ethercat download to set the parameters for one VFD register to measure the bus voltage instead of the ethercat-conf.xml file and I got a reading that changed from time to time. At one stage it was at 321.0 which also showed up on the vfd console. This is meant to be intermediate DC power which should be  1.414 x mains power input. Working backwards, that was 227 volts (should   be 240 volts). So learnings are:
1. Once a SDO is set, it can't be changed
2. You need to set the SDO's via Ethercat download, not via XML
3. SDO's are cleared when the slave is powered off.
Out of time now but It looks like I'll be able to get this going now. It was frustrating not being able to see anything at all.
Thanks for the help....
  • rodw
  • rodw's Avatar
04 Apr 2026 04:00
Replied by rodw on topic Ethercat Setup help needed for beginner
Category: EtherCAT
Yes, it certainly pays to get a quote from Beckhoff first. Some of their modules are really cheap and others like encoders 5151 etc al are expensive here in Australia.
  • rodw
  • rodw's Avatar
04 Apr 2026 03:51
I've finally got to a stage I never need to boot windows again. But what i've always done is install a second SSD/HDD and instal Linux to it. Then select what drive to boot from using the BIOS boot menu.
I did once have a dual boot laptop using grub but the system got its knickers in a knot and I lost everything so have never wanted to risk it again.
Displaying 3376 - 3390 out of 14000 results.
Time to create page: 0.261 seconds
