  • rock861261
  • rock861261
26 Mar 2026 03:07
Replied by rock861261 on topic El5101 Config
El5101 Config
Category: EtherCAT
doesnt enc-pos provide an accurate speed.
26 Mar 2026 02:05
Replied by tommylight on topic Review Request for Arc Volt Sensor Schematic
Category: Plasma & Laser
I have these:
www.ti.com/product/LM331
but i never bothered to use them as the time is worth more than the price of THCAD.
Easy to use and can be plugged to parallel port with a single optocoupler.
  • Hakan
  • Hakan
26 Mar 2026 01:23
Yes, inverting and decoupling.
Wouldn't be surprised if there is a similar isolated SPI component.
Best if the ADC has some kind of free run mode. Otherwise the reading of a value can take too much time.
Was looking for a new value every millisecond, with as many bits of resolution as possible.
Have also used ADS1014 with similar good result.
25 Mar 2026 23:51
Closed loop - encoder/position not updating while moving
Category: HAL
Some clarifications before this goes sideways:
-COM0/COM1/COM2 are referred to serial ports, be it RS232 o other, usually.
-LPT0/LPT1/LPT2 and sometimes only P0/P1/P2 are referred to parallel ports, usually.
What are you referring to with COMn ?
Serial ports are pretty much useless with LinuxCNC, except for some stuff.
Parallel ports, also known as IEEE 1284, are used for machine control still, are perfectly usable with LinuxCNC, but have limited pulse rate capabilities compared to Mesa board.
Reasonable pulse rate or encoder pulse rate for parallel port would be 10000-20000 PPS, sometimes can go to 50000 PPS with a bit of luck/tweaking the BIOS.
At 3000 RPM, that is 50 RPS, so for a 100PPR encoder ends up 5000 PPS, and for a 1000PPR encoder it is already way to fast for most PC setups, see above.
Now convert that to mm/m, as you gave us no info about drive/gear/reduction.
After all that, yes, you can use a parallel port, yes it will work with encoders (2 max normally per port), and yes, you can lower the speed if you have higher count encoders.
But first, fix the wiring and get rid of interference/bad grounding.
25 Mar 2026 23:17
My intention with the TVS was to limit input voltage to 250V.
OK, but you must also add resistors in front of it, or it will blow up the first instance the voltage goes above 250V.
Personally, i have a strict policy of doing the voltage divider using 3 resistors, always, saves a lot of headache in case of mishaps or wires shorts or any of plasma wires touching ground or machine.
Example, in case of Hakan's schematics, i would use a 2K7 in the middle of two 50K. The other side of both 50K would go to plasma arc voltage, and the measuring would be done on the 2K7.
  • leexi
  • leexi
25 Mar 2026 23:09 - 13 Apr 2026 18:43
probe basic lath to define a net spindle-index-en spindle.0.index-enable
Category: HAL
hi, I am using a absolute multiturn spindle encoder , it is working but I need to simulate de Z index for G33 and G76
so I define the follow net
net spindle-index-en    and2.2.out => spindle.0.index-enable
but always say spindle-index-en and after some test I found spindle.0.index-enable it is already linked
So I delete may hal and leave just basic things like lcec  etc.. basic to make my ethercat network working
but any way say the signal is already linked, I made allot names changes and this has the same result
on ini file I have only a call to this hal file.
after I comment the net line and run the linuxcnc
On hal show I look for the linked spindle.0.index-enable, and I can toggle  the input spindle.0.index-enable
on bash I look for the variable
halcmd show pin spindle.0.index-enable
at moment the linuxcnc probe basic stance running, there is not link result.
so mean that input is not linked jet, but after I close the linuxcnc instance and remove the comment the net on hal file I get the same error,
spindle.0.index-enable already liked
I been using probe basic GUI for lathe. i found that you can simulate the spindle feedback or use the encoder feed back, is this option can declare this spindle input?
as additional comment I have the encoder count working and can calculate the right speed test as  tested whit tachometer and it is really precise , so I can control the spindle position [code]net spindle-revs-raw rev_scale.out => motion.spindle-0-revs
but not
Any advice
[/code]
  • scotta
  • scotta's Avatar
25 Mar 2026 23:03
Struggling with LinuxCNC RPi distro, Remora, NVME V5
Category: Driver Boards
Have you tried to use the example configuration?
github.com/scottalford75/Remora-RT1052-c.../remora-rt1052-basic
There is some latching logic in the hal file:
net user-enable-out <= iocontrol.0.user-enable-out => remora.enable
net user-request-enable <= iocontrol.0.user-request-enable => remora.reset
net remora-status <= remora.status => iocontrol.0.emc-enable-in
  • alangibson
  • alangibson
25 Mar 2026 21:35
Replied by alangibson on topic Review Request for Arc Volt Sensor Schematic
Thanks for the schematic. I wish I had found this a while ago.
I like how you use isolated and regulated voltage. I need to see if I can find a single component that does that.
> The torch is negative, ground is positive.
Ah right. I forgot that. Is that why U4 is inverted?
I took a stab at dissecting your schematic. This is what I got:
Voltage source
5V: Common 5VDC power source
U1: 1W Isolated DC-DC 9V out; Isolation 1.5k VDC/min
C3: Decoupling
U5: 5V LDO voltage regulator
C3: Decoupling
VCC_ISO: Isolated 5VDC
Input stage
R7,R9: Voltage divider, 38:1 ratio
D1: Limit input to max 5V
R6: Current limiting
U4: Voltage buffer (inverted ?)
R8: ?
R5: Current limiting?
C4: Decoupling?
C5: Decoupling?
U3: ADC with 12C output
R4: Pull-up resistor
R5: Pull-up resistor
C2: Decoupling?
Output stage
U2: I2C isolator; Isolation 2.5-kVrms
C1: Decoupling?
R1: Pull-up resistor
R2: Pull-up resistor
  • PCW
  • PCW's Avatar
25 Mar 2026 21:24 - 26 Mar 2026 01:42
Replied by PCW on topic Connect Spindel with 7i96s
At a first glance, I think you have the wrong GND
connected to  the 7I96S spindle analog SPINDLE- (TB2 pin 22).
It should be the potentiometer GND not the digital input GND.
  • dm17ry
  • dm17ry's Avatar
25 Mar 2026 21:10
Replied by dm17ry on topic Mitsubishi Meldas Control and Motors
Category: Milling Machines
mitsubishi cnc never had step/dir controled drives...
meldas 3 had a parallel differential bus
meldas 5/6 is serial differential
meldas 7/8 is optical
i can interface them all..
  • alangibson
  • alangibson
25 Mar 2026 20:59
My intention with the TVS was to limit input voltage to 250V. The ADC expects 0-5V range, and voltage division is 50:1, so anything above 250V is out of range.
In reality 250V is way high for a cutting voltage. I just came up with it by working backwards from the ADC voltage range.
Does that make sense?
Optoisolators are a good idea. I was planning on the TVS limiting the voltage, but I guess it's always possible that someone would hook this board up to a HF start torch.
  • dm17ry
  • dm17ry's Avatar
25 Mar 2026 20:51
Replied by dm17ry on topic Mitsubishi MR-J3-XX"A" drive + 7i94 config?
X1 just has 5V power and rs-485 YIO bus...
  • rodw
  • rodw's Avatar
25 Mar 2026 20:40
too long hm2_7i97.0.read.tmax or something else?
What CPU do you have? How many cpus does it report?
what does echo $(nproc) say?
Its possible you are trying to isolate a nonexistent core
  • rodw
  • rodw's Avatar
25 Mar 2026 20:34
Replied by rodw on topic El5101 Config
El5101 Config
Category: EtherCAT
One would like to have a speed output from the drive but there isn't one.
Should be possible to get rps or rpm in the frequency output
by setting proper scaling factor in frequency-scale.
Have not tried it, though.
Should be possible
    65  float OUT             0  lcec.0.El5101.enc-frequency
    65  float I/O          0.05  lcec.0.El5101.enc-frequency-scale
  • Tach0
  • Tach0
25 Mar 2026 20:25
Connect Spindel with 7i96s was created by Tach0
Hello guys,
im new in Linux CNC i wat to connect Linux CNC with my Spindel+YL620a Frequency Converter
via a 7i96s and failed. I dont understand what im doing wrong.....
I connectet the Components like the Picture.
Added this to the Hal
setp hm2_7i96s.0.pwmgen.00.output-type 1
setp hm2_7i96s.0.pwmgen.00.scale [SPINDLE_0]OUTPUT_SCALE
net spindle-vel-cmd-rpm => hm2_7i96s.0.pwmgen.00.value
net spindle-enable => hm2_7i96s.0.pwmgen.00.enable
Added this to the ini
MAX_OUTPUT = 24000.0
OUTPUT_SCALE = 24000
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 24000
Changed the Frequency Converter Settings like in the Picture.
Im grateful for any help or tips.
Thaks in advance
Tach0
Displaying 3751 - 3765 out of 14018 results.
Time to create page: 0.429 seconds
