  • natas01
  • natas01
13 Mar 2026 17:27
Replied by natas01 on topic pin locations
pin locations
When i look at the mesa manual the numbers don’t match for example 30-33 in pnccofig where are those on the board it self
  • PCW
  • PCW's Avatar
13 Mar 2026 17:08
Replied by PCW on topic pin locations
pin locations
That would be the 7I96S manual that lists the terminal block pins for
step/dir, analog out. encoder  and SSR channels.
These are also listed by mesaflash's  readhmid command
  • natas01
  • natas01
13 Mar 2026 16:53
pin locations
I think what I'm trying to translate pncofig to the physical location on the mesa board
  • GiBi77930
  • GiBi77930
13 Mar 2026 16:52
Replied by GiBi77930 on topic heure et date
heure et date
Category: Français
Mon interface est une carte Mesa qui prescrit de ne pas activer le WiFi pour des raisons de temps réel. Alors, j'ai respecté cette consigne sans avoir osé tester si cela était vraiment utile.
Depuis ma demande initiale, j'ai trouvé comment faire en sorte que le module DS1307 s'intègre bien au système en rédigeant un petit service qui se met en route durant le boot.
  • natas01
  • natas01
13 Mar 2026 16:45
pin locations
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • PCW
  • PCW's Avatar
13 Mar 2026 16:35
pin locations
Pncconf does not have pin numbers, for things like 7I96S PWM outputs
and SSR outputs (the things that are needed for spindle interfaces)
They are listed by channel number (the channel number matches
the 7I96S manual names and mesaflash listings)
Do you have a more complete spindle interface description?
It looks like the 7I96S analog output will need an external 12V or 10V source
(since unlike a normal VFD it looks like the drive does not supply a 10V source)
  • natas01
  • natas01
13 Mar 2026 16:04 - 13 Mar 2026 16:06
pin locations
the header pins on the mesa boardIt's a project that was stared a couple years ago that I'm trying to finish and now on my own its PM728v-t everything is working except the spindle that I'm trying to figure out how and where to hook up. pncofig has PIN numbers I'm trying to figure out where the number is physically on the board. attached image is what I'm trying to hook up
13 Mar 2026 15:36
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
Its not possible to install Debian without an internet connection (hardwired is best) The Linuxcnc installer depends on internet (It uses the Debian Live INstaller).
Debian WILL install and run without internet connection, all the ISO versions except the Net version.
Your version does NOT install and run without it.
Over 2 years of never ending issues...
Remaster the Debian ISO, everything works properly.
  • h.hermes
  • h.hermes
13 Mar 2026 15:30
RPi and 7i90 via SPI, estop was created by h.hermes
Category: Driver Boards
Hello everybody!
I am new to this forum, so first I want to thank everybody for all the information posted here.
I want to replace my old 32-bit computer running a 3-axis stepper cnc via a parallel port.
What I succeeded in:
  1. I bought a Raspberry Pi 4 and a Mesa 7i90 card.
  2. I used my old computer with parallel port, connected to the 7i90 and programmed the 7i90_spi_svst4_8.bit firmware using mesaflash.
  3. I downloaded the LinuxCNC disk image for the RPi 4 and installed it.
  4. I connected the 7i90 to the Raspberry Pi (about 3 inch flat-cable, all ground lines connected). I can read the device configuration using mesaflash without problems (well after a new install of mesaflash from the git repository).
Now I want to start ``linuxcnc linuxcnc/configs/by_interface/mesa/hm2-stepper/7i90-rpi-spi.ini``. The GUI pops up and everything seems fine.
But when I press F1 to reset the estop latch nothing happens. Up to now I did not connect any drivers or switches to the 7i90.
I changed 'DEBUG = 0x7fffffff' in the ini-file and added a 'show' to the end of the ini-file. I attach the output when running the linuxcnc. I marked what happend when I pressed F1 by '******' in the text.
If you need more information (ini-file, hal-file) let me know.
Many thanks for any support, H. Hermes
  • Atsu
  • Atsu
13 Mar 2026 15:29 - 13 Mar 2026 15:33
Replied by Atsu on topic Ethercat random jitter fix
Category: EtherCAT
Experienced some jitter as well today while running grandixximo's fork. I doubt there is any synchronization being done while the dc-phased pin is false and all pll-*** pins are 0. Ran sudo dmesg to see what is happening in the background. Maybe someone can notice something clear in the log:
During startup:
[  801.691210] EtherCAT: Requesting master 0...
[  801.691215] EtherCAT: Successfully requested master 0.
[  801.691915] EtherCAT 0: Domain0: Logical address 0x00000000, 74 byte, expected working counter 12.
[  801.691918] EtherCAT 0:   Datagram domain0-0-main: Logical offset 0x00000000, 74 byte, type LRW.
[  801.691932] EtherCAT 0: Master thread exited.
[  801.691933] EtherCAT 0: Starting EtherCAT-OP thread.
[  801.691970] EtherCAT WARNING 0: 1 datagram UNMATCHED!
During operation:
[  807.424674] EtherCAT WARNING 0-1: Slave did not sync after 5000 ms.
[  808.944250] EtherCAT 0: Slave states on main device: OP.
During shutdown:
[  841.183382] EtherCAT 0: Master thread exited.
[  841.183401] EtherCAT 0: Starting EtherCAT-IDLE thread.
[  841.183449] EtherCAT ERROR 0-0: Failed to receive AL state datagram: Datagram initialized.
[  841.183462] EtherCAT 0: Releasing master...
[  841.183464] EtherCAT 0: Released.
[  841.188247] EtherCAT 0: Slave states on main device: SAFEOP, OP + ERROR.
[  841.196539] EtherCAT ERROR 0-0: AL status message 0x001A: "Synchronization error".
[  841.197317] EtherCAT 0-0: Acknowledged state SAFEOP.
[  841.208612] EtherCAT ERROR 0-1: AL status message 0x001A: "Synchronization error".
[  841.209116] EtherCAT 0-1: Acknowledged state SAFEOP.
[  841.220587] EtherCAT ERROR 0-2: AL status message 0x001A: "Synchronization error".
[  841.221590] EtherCAT 0-2: Acknowledged state SAFEOP.
[  841.256274] EtherCAT 0: Slave states on main device: PREOP.
[  841.828318] EtherCAT WARNING: Datagram 0000000031def7fe (master-fsm) was SKIPPED 1 time.
  • Xnke
  • Xnke
13 Mar 2026 15:04
Rod, I literally just did exactly that. It booted and worked perfectly fine, with the caveat that the .sources list for Aptitude is empty, and you need to manually populate it.
Once manually populated, the system was able to be connected to the internet and it worked exactly as you'd expect with regard to installing new packages.
  • arsenix
  • arsenix's Avatar
13 Mar 2026 13:21
Replied by arsenix on topic New update on STMBL
New update on STMBL
I wanted to bump this thread and inquire if anyone was using the STMBL v5 on their LinuxCNC projects? With native SS support, small size and support for straight rectified 220v I have always felt it was an amazing solution. It is pretty well documented but I'm wondering how challenging it is to tune the drive for the motors once all setup? The instructions seem fairly straightforward but it is hard to know until you try!
Also big thanks to Freak for reviving this project!
  • billykid
  • billykid's Avatar
13 Mar 2026 12:19
xhc-hb04 does not communicate was created by billykid
Good morning, I bought an xhc-hb04 because mine had fallen and the wheel didn't turn well, but it still works. When the new one arrived, I immediately noticed that it stays on even when the PC is off, which the old one didn't. It's detected because if I remove the LinuxCNC dongle, it gives me an error. The working one has a chrome power button, while the new one has a plastic button. I think it's defective. What do you think?
  • Todd Zuercher
  • Todd Zuercher's Avatar
13 Mar 2026 10:13
Updating Old GladeVCP Files? was created by Todd Zuercher
Category: GladeVCP
I am working on updating the control an older Linuxcnc machine.  I need to make some modifications of the old GladeVCP it uses.  Are there any steps or instructions for updating older GladeVCP files (from Linuxcnc 2.7) to current versions of GTK/Glade for Linuxcnc?
  • masawee
  • masawee
13 Mar 2026 07:00
Replied by masawee on topic 7i92 cnc motion controller from aliexpress?
aliexpress 7i92 have anyone used this card, how can use,https://www.aliexpress.com/item/1005011667901833.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.1.7ccfDf5dDf5dYi
Displaying 4246 - 4260 out of 14024 results.
Time to create page: 0.326 seconds
