  • Clive S
  • Clive S
11 Mar 2026 13:43
  • garmanarnar
  • garmanarnar
11 Mar 2026 13:10
Mesa 7i76eu output_sink and output_source confusion
Category: Driver Boards
Hello all, I am trying to configure `output_sink` and `output_source` pins for my Mesa 7i76eu and I am running into some surprising behavior. My goal is to put `hm2_7i76e.0.7i76.0.0.output-11` into sink mode.
Long story short, putting `setp hm2_7i76e.0.7i76.0.0.output_source 0x0000F7FF` and `setp hm2_7i76e.0.7i76.0.0.output_sink   0x00000800` in my HAL file after loading `hm2_eth` does not seem to have any effect, output-11 remains in sourcing mode. I spent some time debugging this and found some surprising results.
The first thing I did was attempt to setup the pins manually without changing anything in my HAL file. For this test, my HAL file did not set `output_sink` or `output_source` at all. On a fresh power cycle of both my computer and the mesa card, the following works correctly (causes output-11 to sink when TRUE).
halcmd setp hm2_7i76e.0.7i76.0.0.output_source 0x0000F7FF
halcmd setp hm2_7i76e.0.7i76.0.0.output_sink   0x00000800
halcmd setp hm2_7i76e.0.7i76.0.0.output-11     TRUE
I can toggle output-11 back and forth between TRUE and FALSE and it appears to work just fine. The strange part is that if I set output_source = 0x0000FFFF output_sink   = 0x00000000 (going back to the default value), `output-11` remains in sinking mode, it does not switch back to sourcing mode. The only way I can get it to switch back is if I power cycle the Mesa card.
The second thing I tried was setting `hm2_7i76e.0.7i76.0.0.output_source 0x0000F7FF` and `setp hm2_7i76e.0.7i76.0.0.output_sink   0x00000800` as part of my postgui HAL, the thinking being that maybe there is some timing issue for when you configure the output pin modes. This does seem to work as long as I do a power cycle of the Mesa card and computer, but it feels like a bit of a hack.
I'm using this setup to control activation of a wireless probe receiver which needs `output-11` to sink to ground in order to activate the probe, so my main worry is that I'm just hiding a timing related issue by doing this in postgui and will end up running into a crash down the line. If anyone has some insight into how `output_source` and `output_sink` are supposed to work, that would be appreciated!
Thanks!
  • ihavenofish
  • ihavenofish
11 Mar 2026 13:05 - 11 Mar 2026 13:06
Replied by ihavenofish on topic motion channels for robotic atc library
neat. this is the current state of the robot. xyz (and call be point to point one axis at a time). a drawbar (air) and a pivot for the arm (air?) and the door opener (air?).
grr. how do i NOT embed the video? its stripping out the time index. 2:41.
  • ihavenofish
  • ihavenofish
11 Mar 2026 12:09
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
helo, give me your contact.
join the discord
discord.gg/PRkQbQ2wmZ
  • elisilva
  • elisilva
11 Mar 2026 11:15
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
Hi!Will upload! but photos not very good ! so hard to extract from case box.
  • tivoi
  • tivoi's Avatar
11 Mar 2026 10:58
Replied by tivoi on topic Mini wannabe datron build
  • DerKlotz
  • DerKlotz
11 Mar 2026 09:41
Wiring Leadshine DM856 Ena+ and ENA- -> Mesa 7i76e
Category: Milling Machines
Please see attached file
Can i just use one Mesa output for all three driver or do i have to use three outputs? One for each driver. In the LinuxCNC configuration i can set enable for x, y and z axis.
  • depronman
  • depronman
  • LucaGiorcelli
  • LucaGiorcelli
11 Mar 2026 06:58 - 11 Mar 2026 06:59
Machine choice for composite panel CNC + probe-driven XY/Z G-code compensation
Thanks for the response — this is helpful context.
I understand retrofit is a valid path and the point about ending up with a tank-built machine is well taken. My hesitation is mainly about the time investment: I'd rather spend that energy on the application layer (custom probe-driven post-processing workflow) than on commissioning the machine itself.
That said, I'm open to both paths if the retrofit is well-documented for a specific platform.
So to refine my question:
1. For **new machines**: I've been told some smaller European builders sell gantry routers either pre-configured with LinuxCNC or as bare mechanics without a controller. Can anyone confirm this and point to specific manufacturers with real-world experience?
2. For **retrofit**: which specific platforms (Biesse, SCM, other) have the best-documented LinuxCNC retrofit in this community? Ideally something where ATC and vacuum zone management via MESA I/O are already solved problems with existing examples.
  • Atsu
  • Atsu
11 Mar 2026 05:56
Replied by Atsu on topic Ethercat random jitter fix
Category: EtherCAT
I’ll switch to your PR and test it on my hardware the next time I’m working with my mill.
  • Xnke
  • Xnke
11 Mar 2026 03:52
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
How would Rufus be the problem? If the liveCD version runs, then the ISO has been written properly, and it's easy enough to run the verification check before using it as bootable media.
  • brianallen
  • brianallen
11 Mar 2026 03:45 - 13 Mar 2026 04:37
Replied by brianallen on topic some qs about Axis tuning
Hi Eugenius,
As far as I know with AXIS (the default LinuxCNC GUI) those things aren’t easily configurable from settings.
Bigger axis jog buttons: AXIS uses a Tk/Tcl interface, so the button sizes are basically defined in the GUI script. If you want them bigger you would need to edit the AXIS UI files (usually in something like linuxcnc/share/axis/). It’s possible, but it means modifying the Tk layout manually.
Secondary spindle control: AXIS is quite limited for multi-spindle setups. You can control additional spindles through HAL and M-codes, but the GUI usually won’t show extra spindle controls unless you customize the interface.
If you need more flexible controls, many people switch to QtVCP or gmoccapy, which are easier to customize than AXIS.
So yes, it’s possible, but it usually means editing the AXIS UI scripts or moving to a different GUI in wheelie life .
  • NWE
  • NWE's Avatar
11 Mar 2026 02:34
I trying ramake PCB of the BCL-AMP Friendess Preamplifier,
That sounds interesting! Can you share photos of the PCB?
  • rszemeti
  • rszemeti
11 Mar 2026 02:00
Replied by rszemeti on topic Base threadwith Mesa?
Sorted, cheers.
11 Mar 2026 01:12
Replied by tommylight on topic configuring 7i76eu to ip address 10.10.10.10
And the PC MUST be set to 10.10.10.nnn where nnn is anything from 1 to 254 but NOT 10.
So yes, the PC set at 10.10.10.11 will work.
Displaying 4321 - 4335 out of 14024 results.
Time to create page: 0.298 seconds
