  • ruediger123
  • ruediger123
01 Oct 2026 03:29
Would you use a feed rate for rotary axes in mm/min (surface speed)?
Hello,
In my view, the decisive factor is whether or not kinematics are taken into account:
without kinematics, values ​​are specified in angular units; with kinematics, they are specified in linear units, as the lever arms are factored in.
  • grandixximo
  • grandixximo's Avatar
01 Oct 2026 03:25
Replied by grandixximo on topic Installing 2.10 master
Category: Installing LinuxCNC
All qtvcp UI work on Debian 13, I'm not sure what python problem you are referring to, is this on the latest master?
  • tuxcnc
  • tuxcnc
01 Oct 2026 01:59
"G93 is fine for me" means nothing.
It is one thing when someone uses CAM and is not at all interested in how the g-code is created, and it is enough that it works, and it is completely different when someone writes the program themselves using functions, loops and subroutines.
  • tuxcnc
  • tuxcnc
01 Oct 2026 01:56
Replied by tuxcnc on topic Installing 2.10 master
I want to use 2.10 for some of the plasmac updates
2.10 only partially supports Debian 13.
I can't check everything, but it looks like any qtvcp based gui won't work.
Changes in Python traditionally cause the problem.
A new version of numpy, but maybe something else too.
You can work around the problem by installing LinuxCNC on Debian 12, or downgrading some Python packages on Debian 13.
This is of course not a solution to the problem, the solution will be to repair the LinuxCNC sources, but so far no one wants to do that...
  • Coyote
  • Coyote
01 Oct 2026 00:07
Replied by Coyote on topic PID tuning FF2 not working
In my opinion FF1 and FF2 should be delayed. If the PID output is the velocity setpoint, then FF2 is not used, FF1 should be equal 1.0, but it would produce spikes at acceleration change. It could be improved by adding a 1st order delay to the setpoint value, before it gets compared to the actual value.
  • grandixximo
30 Sep 2026 23:14
2.10 is currently transitioning to the a new hal API, so mind that is still somewhat work in progress, there is no 2.10 finished release
  • grandixximo
30 Sep 2026 23:13
There are installable artefacts in the GitHub actions, get a GitHub account, download those for your system, and install, I would reccomend to use a system for which the CI already builds, you'll have yourself way less headaches :-)
  • trackwhack
  • trackwhack
30 Sep 2026 22:44
Replied by trackwhack on topic Perpetual License CAM
Category: Show Your Stuff
Hi All,
Thank you everyone for the already great response. The 50% discount offer closes on 4th October, just a few more days to grab it.
We will be launching Takshak Turn for mill turn and Takshak Burn for Lasers, EDMs, Waterjets and Plasma Cutter between October and November. They will launch with a discount as well.
Thanks all for the support
30 Sep 2026 22:06
Replied by tommylight on topic MESA - Customer service.
Category: Driver Boards
Now you know why i use strictly Mesa for all my machines/retrofits, and i never ever had anything brake in over 15 years.
Yes i am biased as i do not have one or two Mesa boards, i have over 70 or 80 or 100 of them in daily use.
Thank you Peter and Mesa.
  • flyingbrick
  • flyingbrick
30 Sep 2026 21:41
MESA - Customer service. was created by flyingbrick
Hi guys.
Just quickly. I recently somehow ruined the +-10v analogue output on my 7i97T.
I emailed Peter at Mesa and he was kind enough to send me schematics and provide a fair bit of trouble shooting advice.
I ended up buying a hot air station and the failed component (Chat GPT helped me with how to test each device) and now have a fully functioning board for about $30c worth of components (I'm not counting the smd related consumables and tools that i wanted anyway).
This was probably the single best interaction that I have ever had with a company - that type of support (and the support showing within the LCNC community in general) is absolutely priceless.
So: Thanks PCW, thanks Mesa, thanks everyone else, and if anyone ever wonders which route they should take when planning a build- I obviously recommend having a good look at their range of products.
  • PCW
  • PCW's Avatar
30 Sep 2026 19:34
7i95T not seeing encoders or outputing step signals
The fact that the stepgen outputs work with  the test program
indicates that the hardware is likely OK.
The test program is this:
File Name: stepgens_2...9-30.txt
File Size:1 KB
Which will slowly toggle all step/dir outputs on any Mesa Ethernet FPGA card.
You may need to edit the file to change the IP address or select a different rate.
The default rate is quite slow to allow a DVM settling time to read both low and
high voltage states.
Did you try jogging in either direction with LinuxCNC to see if the DIR state changes?
The hal/ini file you sent had quite short step times (1000 ns) so could be a reason
for no motion. (Starting step times should be at least double the drives minimum timing)
If nothing else works, Mesa can issue a RMA for analysis/repair/replacement of the card
but the symptoms are very odd and don't  look at all like typical hardware issues.
  • snowgoer540
  • snowgoer540's Avatar
30 Sep 2026 19:33
Replied by snowgoer540 on topic QtPlasmac Updates
QtPlasmac Updates
Category: Plasmac
QtPlasmaC updates - Master (v2.10):
  • fix dual-code button's optional indicator
  • fix pmx485 0210 fault
  • clean up error message formatting
  • Mikel
  • Mikel
30 Sep 2026 19:00
Looking for an older CNC mill to refurbish/retrofit
Aircraft Instrument panels are larger than most knee mill tables.
Bridgeport Series II Interact have larger tables. Older Series II units have steppers.
  • PCW
  • PCW's Avatar
30 Sep 2026 18:32
Replied by PCW on topic mesa card 7i48 capacitor value
0.1 uF 25V 0603
  • billwitt
  • billwitt
30 Sep 2026 17:43
1. Encoders do not increment counters - hm2/hm2_7i95.0:     IO Pin 018 (TB1-01/TB1-09): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i95.0:     IO Pin 019 (TB1-04/TB1-12): Muxed Encoder #0, pin Muxed B (Input)
I have tried all encoder inputs using a stepper motor with attached encoder in differential mode. See signals clearly at TB1
2. Steps in Axis UI show movements from jogging in registers but do not show up on output pins TB3 or TB4 .
Tech at Mesa sent me a code snippet that did produce very slow signals at TB3 but the commands are not clear to me and I don't think they help debug.
From startup:
Machine configuration directory is '/home/bill/linuxcnc/configs/7i95t_xyz'
Machine configuration file is '7i95t_xyz.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./main.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: INFO: Hardware address (MAC): 00:60:1b:15:82:8b
hm2_eth: discovered 7I95T Thanks for any help. I don't want to pull my hair out, but is is getting close....
Bill Witt
Displaying 646 - 660 out of 11361 results.
Time to create page: 0.360 seconds
