  • coffeeking
  • coffeeking
30 Sep 2026 05:13
Replied by coffeeking on topic Notifications
Notifications
Category: Show Your Stuff
No problem, just trying to give a little back!
  • grandixximo
  • grandixximo's Avatar
30 Sep 2026 03:54
Replied by grandixximo on topic looks like a bug in linuxcnc?
Maybe it was a limit error, but the message did not help figuring that out at all, was the sub itself that was out of limit? and it caused the error in the picture?
  • grandixximo
30 Sep 2026 03:15
Would you use a feed rate for rotary axes in mm/min (surface speed)?
I'm deciding whether to work on a LinuxCNC feature and would like to know first whether anyone would actually use it.
Today, when a rotary axis moves together with X, Y or Z, F applies to the linear axes only, and a rotary move on its own runs at F in degrees per minute. On a 4th-axis wrap, where the surface of a cylinder is cut with X and A, the surface speed therefore doesn't match F. The usual workaround is inverse time (G93) from the CAM.
The idea is a reference radius for each rotary axis, set in the INI. For example, `[AXIS_A] FEED_RADIUS = 25` puts A in the feed calculation as if it were a length at 25 mm from its centre. A move of A alone at F100 would then run at 100 mm/min on the surface at that radius, and X with A would run at F along the combined path. Siemens (FGREF) and Fanuc (a parameter) do the same.
Questions:
1. Would you use this, or does G93 from your CAM already cover it for you?
2. What machine: 4th-axis wrap, rotary table, something else?
3. The useful radius is usually the stock radius, which changes per job. Is a fixed INI value good enough, or would you need to set it from G-code?
A short "yes, I'd use it", "no" or "G93 is fine" helps. If nobody needs it, I'll leave it.
  • trackwhack
  • trackwhack
30 Sep 2026 03:13
Replied by trackwhack on topic Perpetual License CAM
@plasmanfm
1.0.7 will release today and the help file fix is in.
  • Unlogic
  • Unlogic
30 Sep 2026 02:08
Replied by Unlogic on topic Optimum Optimill MH50V CNC conversion
Category: Milling Machines
I received the braking resistor yesterday and mounted it on the left side of the cabinet. The cables that came with it were just long enough to reach all the way to the spindle drive.
With the braking resistor installed and the parameters set in the spindle drive the faults when stopping the spindle from high RPM disappeared.
As the machine seemed to be ready for the first test cuts I cleaned the vices in the parts cleaner and installed them.
Getting all three of them trammed in took it's time as usual...
For the first nervous test cuts with the new spindle I used a piece of 7075 aluminum.
I started with an 80 mm face mill and immediately noticed a clear improvement in surface finish which I hadn't expected.
Next I milled the sides with a 16mm DLC coated solid end mill. The resulting finish was something I've never seen on this machine before.
This was just a quick cut with a width of 0,5 mm so this feels very promising. I'll report back when I've milled a few real parts.
29 Sep 2026 20:55
Retrofitting a 3-axis VMC with DC servos - guidance needed
Category: Driver Boards
All shielding should be wired to a terminal block to machine ground.
Search for HyperTherm grounding best practices, they had a very good pdf about it.
And since we are here, grounding and shielding is never simple, so requires a bit of time, but it is very well worth it for the time it saves when working with such machines.
  • my1987toyota
  • my1987toyota's Avatar
29 Sep 2026 18:56 - 29 Sep 2026 19:00
Replied by my1987toyota on topic LinuxCNC-Branded USB Drives
Got myself one. I will add it to my collection of backup ISO's
  • leandrocontarini
  • leandrocontarini
29 Sep 2026 18:35
Replied by leandrocontarini on topic XML Settings for EC1-57E
Category: EtherCAT
I managed to get it working. Here are the files.
29 Sep 2026 16:30 - 11 Oct 2026 07:37
Looking urgently for a german / european Linux CNC consulting help.
Category: User Exchange
I am not much help with probing nor QtDragon, for the rest probably yes.
As for video call, yes of course, now is OK for me as i am going in the shop, i have whatssapp only, but there are some general rules to follow:
-if something is unclear, ask again and again, there are always more than one way to describe something
-when using chat, read all the replies, not just the last one, so scroll before asking or doing anything
-follow instructions strictly
---Number delted---
will be available for the next hour, after that leave a message and i will get back, as i do not keep that phone with me all the time.
Will delete the number after confirmation you got it.
And you owe me a coffee whenever i come to Germany!
  • Avion
  • Avion
29 Sep 2026 15:52 - 29 Sep 2026 15:57
general setup question - standard cnc process
Category: Basic Configuration
Dear everyone, i have posted about my cnc issues and am kindly asking for help here   but i think this may become harder to find then i thought. Any tips if there is consulting help or physical help and an option, please do not hesitate. I am happy to spend a dime.
BUT i am preparing myself for a week of CNC evenings and nights as this is ultra urgent to fix for me and my small shop.
I am using a mesa MESA 7I76EU STEP/IO STEP DIR plus I/O controller card on my CNC. its about 1.5m X 1.2m with 35cm Z axis travel distance.
Sadly i was not able to perform the full retrofit fully myself due to time constraints. I did though the complete electronics overhaul.
I have added a new tool length sensor and a 3d probe.
From my cnc workflow so far i have this process in mind and I would love your take on it. I have used multiple CAD / CAM solutions in the past, the longest i have used fusion360 and right now im trying out onshape cam.
But in general the workflow was the same:
  1. CAD design the part
  2. In Cam I am creating a setup
  3. I create and define stock (if necessary)
  4. or I set up the part reference point
  5. that defines the WCS XYZ
  6. This allows the postprocessor to generate toolpaths.
  7. Using the postprocessor to output G-code
  8. I load whatever CNC program (right now linux CNC QT Dragon)
  9. I home the machine (if necessary)
  10. This sets G53
  11. Then I either do this:
  12.  A) I insert Tool 1, measure tool 1 at the tool lenght sensor. G43 H1 mit Z20 z.b. . Then I take my tool length sensor, place it on top of the material. I am zeroing Z-height (G54 Z = new coordinate - tool length sensor dimension)) and i place the machine head roughly where i want to cut
  13. B) I take a 3D probe, probe the stock or piece or reference that i need. I align the WCS to it. (if the probe needs calibration, i probe the table or a defined height of a pin right next to the tool length measure.) This sets G54 XYZ. Then I insert Tool 1 and measure tool length on my tool length sensor. G43 H1....
  14. Run
  15. Tool change
  16. Measure T2 G43 H2 is stored
  17. continue and repeat
BUT it seems that in our setup of linux this process does not work at all. I am getting homing error and out of probe errors the moment i am doing the basic qt dragon features for probing and sensing.
  • Avion
  • Avion
29 Sep 2026 15:51
Sorry my edit was left in draft mode and did not got posted.
No no actually its good. I think I am looking into two avenues. Either i fix it myself but completely redo the setup or i find help and am happy, very happy, to provide some financing for next cnc project to someone. I need the machine basically and the bodged retrofit or rather not completed retrofit is killing hours.
If you or anyone would be open to jump on a video call or something. I think most of you here would probably spot the issue instantly.
29 Sep 2026 15:40
darm, the mods have moved the topic to the dark corner of the forum
I did that as noted above:
Moved to "user exchange".
If you think it would help, i can move it to QtVCP section, but we tend to keep anything involving payment here.
29 Sep 2026 15:36
  • Avion
  • Avion
29 Sep 2026 14:55 - 29 Sep 2026 15:48
darm, the mods have moved the topic to the dark corner of the forum ...
Just kidding. @tommylight, would you be open for a call?
I am diving int the cnc setup again and need to fix the processes. I am getting errors constantly wheras it should be a normal operation.
I will post a detailled process question later today
  • PedPEx
  • PedPEx
29 Sep 2026 14:33 - 29 Sep 2026 14:35
Retrofitting an old industrial CNC mill with EtherCAT components - MAHO MH400E
Category: EtherCAT
Hello folks :D
Very good news: The MAHO mill retrofit has entered the finishing state.
LinuxCNC can now read all inputs, sensors, thermal-switches, ... and also control everything, from the gearbox-motors, the VFD with the spindle motor, the Indramat DC motor driver and all the other components.
Features working at the moment:
- Working DC axis motors (PID not tuned)
- Reading the Heidenhain LS403 glass scales directly with modified EL5021 terminals
- Working gearbox and VFD (EL7332 controlling gearbox motors, Danfoss FC302 controlling original spindle motor)
- Working toolclamp-mechanism (with added button)
- Safety related inputs handled with TwinSafe Safety Hardware (EK1914 and EL1918)
- BusCheck monitors EtherCAT bus config (SafetyPLC CRC now too)
- Faulthandler gives operator detailed info, warning and alarm messages (message conditions need to be cleaned up)
The best feature probably is the continuously adjustable spindle speed. When a speed between 8 and 4400 RPM is requested, the best suited gear of the gearbox is selected (and will be used for all further requested speeds until a M5 command is sent) and the last speed adjustments are done by setting the spindle motor speed accordingly. That way it should be possible to cut threads with rigid tapping in theory up to 260 Nm in the lowest gear. A video of the three LinuxCNC spindle related components (fc302VFD, gearbox and spindle_master) working together  is over on YouTube .
Beckhoff has their own way of implementing a zero logic for their encoder terminals - for the Z(ero)/reference impulse. There is now also a component, which ties this index zero logic into the LinuxCNC homing logic. The component should work with all Beckhoff encoder input terminals and boxes - it was only tested with an EL5021 terminal. All components and the whole machine config can also be found over on github .
There are still quite some things that need to be done, like tuning the PID controllers, designing and building the new monitor-arm and so on... But we are getting there :D
Displaying 676 - 690 out of 11361 results.
Time to create page: 0.403 seconds
