  • snowgoer540
  • snowgoer540's Avatar
28 Sep 2026 19:05
Z axis torch initially going up instead of down when clicking cycle start
Category: Plasmac
If you want, you can post a backup of your config here, and I'll take a look at.
Your Z axis limit switch is at the top of travel right?
28 Sep 2026 17:13
Looking urgently for a german / european Linux CNC consulting help.
Category: User Exchange
Moved to "user exchange".
I am in Europe and i can speak German, but i am of no use for probing, i still did not build a proper mill. I can figure out everything for sure, but the time it would take is probably much longer than someone with experience.
Also, i never charge for helping here or whatever is initiated from here.
28 Sep 2026 17:09
Retrofitting a 3-axis VMC with DC servos - guidance needed
Category: Driver Boards
From what I've measured, the issue seems to be on the encoder side.
Shielded cable, shielding grounded on the Mesa side.
According to the diagrams, the analog signal for the axis is connected to the machine's frame/ground.
Analog cable has 2 wires plus shielding, shield must be grounded on the Mesa side, and one of those 2 wires is the analog ground.
Is it better to isolate the analog ground from the system ground? Under what conditions is it strictly necessary to tie both grounds together?
There is no exact reference for it, see above, use a DVM to measure between analog and machine ground both in AC and DC mode > if any of those read more than a Volt or two = do not connect. If that is all correct but still does not work, you can try grounding the analog ground to machine ground through a 1K resistor for a single line, test with only a single line/analog drive/connection to mesa.
As a general rule, use a very good power supply for the Mesa as the encoders are powered from it.
  • rodw
  • rodw's Avatar
28 Sep 2026 15:50
Replied by rodw on topic Is there any idiots guide to GUIs?
Debian 13.7 was only released earlier this month (on 12 September) so its quite possible at this early stage that something Debian did with versions that broke LinuxCNC. Instead of complaining to all and sundry, why not raise an issue on GitHub so the devs can look at it? They are probably not aware of the issue.
  • RMJ fabrication
  • RMJ fabrication
28 Sep 2026 14:59
Category: Plasmac
Ok so I got it fixed by finding some settings in my notes that worked. So basically I entered these settings to the Z axis.
Now the torch still goes up initially but it doesnt hit the limit and it cuts just fine.
Im not entirely sure how these changes fixed my machine.
  • HansU
  • HansU's Avatar
28 Sep 2026 14:19
GladeVCP panel fails to launch intermittently
Category: GladeVCP
You could post your crosshair_panel.glade and crosshair_panel.hal then we will have a chance to help you ;-)
  • hermann1976
  • hermann1976's Avatar
28 Sep 2026 12:48
NativeCAM Problems with Program Start after transfer to Control
Category: NativeCAM
Hello everyone,
I have installed the latest version of NativeCAM under the Gmoccapy user interface of LinuxCNC. So far it works, but every time after transferring a new program to the control, I always have to press the start button twice to launch the program.
The first time I press it, the milling spindle starts briefly, stops immediately, and then I receive several error messages:
  • invalid parameters in linear command
  • linear move on line 38 would exceed positive limit of axis/joint 2
  • linear move on line 38 would exceed positive limit of axis/joint Z
After that, I can restart the program again and again without any problems, until I transfer a new program (or the same one again) to the control.
What could be the cause of this error?
Thank you very much in advance for your help.
  • Henk72
  • Henk72
28 Sep 2026 12:22
Connect external potmeters to rapid- and feedrate override sliders in QTDragon
Category: Qtvcp
Thanks again for setting me on the right track again, this is really appreciated. In my case I only included 2 potmeters on the console: one for rapid traverse override and one for feedrate override. I copied this from a DMU 50 console which we have at work...
Using HALshow and setting halui.rapid-override.direct-value to True (1) and then setting halui.rapid-override.counts to a manual value (I discovered that a value of 10 corresponds to 100%) works well together with QTDragon_HD. With that I mean that it will probably provide me with the functionality I need. I already wrote some HAL lines using the lincurve component to ensure that the output of the potmeters correspond to the tickmarks (it is not a linear scale...).  By setting up the right net statements I should be able to connect these and have QTDragon follow this setting on the display. Same for halui.feed-override.direct-value and ..counts.
@cmorley: Luckily I didn't include a jog override pot on my console, as I now understand from you that this would not work in a similar manner. I did already buy a pendant (XHC with cable type) and maybe I will run into issues once I try to get that connected. For now I first want to get the spindle and servo's running :-).
Thank you all for helping me further.
  • tuxcnc
  • tuxcnc
28 Sep 2026 09:36
Replied by tuxcnc on topic Is there any idiots guide to GUIs?
Sounds like numbpy is the wrong version.
More specifically, it looks like someone did some good work in the 2.9 branch (Qtdragon works with the new numpy 2.2.4), but didn't port it to the 2.10 branch...
  • cmorley
  • cmorley
28 Sep 2026 07:52
Replied by cmorley on topic Is there any idiots guide to GUIs?
As you said qtdragon being python doesn't compile anything.
It preprocess somethings into to bytecode.
But now we can investigate, thank you.
So you didn't home the machine while trying to decide if the screen is 'useful' ?
and there was extra information in the list that you didn't like?
Oh and the colors -colors were bad.
And that was worth going on the forum and ranting about how bad the software is?
Sounds like you didn't give it much of a chance.
Shake my head.
I'll try to replicate the numbpy problem.
  • jschulze
  • jschulze
28 Sep 2026 07:41
Replied by jschulze on topic Stepping down as Administrator/Moderator
Category: Forum
Thanks for all your work over the years!  I'd never have been able to finish up my latest build without your help and contributions.
  • tuxcnc
  • tuxcnc
28 Sep 2026 07:33
Compiling problems aren't usually QtDragons fault - you didn't  mention what system you are compiling in so no one could help or evaluate the problem.
I'm sorry Qtdragon didn't suit you out of the box, but there is quite alot you could change.
For instance based on your pic, you could turn on the machine and home it, then the colors change from disabled to enabled and look like this:
First, about compilation issues.
My system is Debian 13.7 and the LinuxCNC sources are from the Git repository, main branch, i.e. version 2.10.
There is some misunderstanding here, because when LinuxCNC is compiled, the Python scripts are not compiled, but only copied to the right place. This means that if the scripts author screws up, it's his fault, because compilation itself doesn't change anything.
So we have the following flower:
This is what happens after compiling LinuxCNC yourself.
However, there are two live images that I ran.
1. linuxcnc_2.9.10-amd64.hybrid.iso
2. linuxcnc_2.10.pre1-amd64.hybrid.iso
Qtdragon starts in both, but neither suits my system.
In linuxcnc_2.9.10-amd64.hybrid.iso there is numpy 2.2.4 but LinuxCNC is 2.9.
In linuxcnc_2.10.pre1-amd64.hybrid.iso there is LinuxCNC 2.10, but Debian 12 with numpy 1.24.2.
Someone's sources have obviously gone wrong...
As for these "gray on grey" numbers, I wrote that I ran Qtdragon for the first time in my life and just took a look. I opened the tab called "offsets", so I thought there were offsets there and it didn't occur to me that it would only work after homing, because offsets have nothing to do with homing the machine.
Well, now I noticed that someone stuffed a machine position into the offsets, for unknown reason, because they can be seen much more conveniently in the window below. I started to wonder what else the authors of Qtdragon would surprise me with, but I think I'm less and less curious about it.
  • Holzwurm56
  • Holzwurm56
28 Sep 2026 06:40
Replied by Holzwurm56 on topic Pncconf and external controls?
Category: PnCConf Wizard
Thanks.
  • Holzwurm56
  • Holzwurm56
28 Sep 2026 06:39
Replied by Holzwurm56 on topic Looking for a super small Linux-Version?
Category: Installing LinuxCNC
Hello,
I’ve installed the DebianNetInstall.iso without a desktop environment, and then installed the real-time kernel, LCNC, Openbox, and a very simple file manager via the terminal. It seems to be working—very low jitter.
Hans
  • trackwhack
  • trackwhack
28 Sep 2026 06:03
Replied by trackwhack on topic Perpetual License CAM
Category: Show Your Stuff
"Vielen Dank für die lieben Worte! Ich hoffe, es wird dir nützlicher sein als FreeCAD."
KR,
George
Displaying 706 - 720 out of 11360 results.
Time to create page: 0.318 seconds
