  • dfarnainekl
  • dfarnainekl
13 Dec 2025 23:48
Can't get EL4001 to work - all other devices work
Category: EtherCAT
Hello,
I added an EL4001 analog output terminal to a system with a few other Beckhoff terminals, which is otherwise fully working.
Like the other terminals, the EL4001 shows up with "ethercat slaves" and this as well as its status LED shows it's in the OP state.
I added it to the ethercat-config.xml like the other nodes:<slave idx="4" type="EL4001" name="spindleSpeed"/>
I also tried setting it up manually like here .
Unfortunately, I can't get any output voltage out of it (other than zero) using the pins as documented  (I set the pins using halcmd and verified with Halscope). As mentioned, all other Ethercat devices (mostly Beckhoff) work without issues. I also tried changing the order of the Beckhoff terminals, but that didn't help (as expected).
Does anyone have any idea what could be the issue here, or what I can do to further debug this?
  • Masiwood123
  • Masiwood123's Avatar
13 Dec 2025 23:42
freelancer needed to create a routine for ATC tool change (rackchange)
WOW now it works without errors, thank you very much, I'm very happy... please leave an email, I would like to do something for the favor!
youtube.com/shorts/J1DJ8W4_v6Y?si=e8J3gdIzHKPtXllS
  • Fastfred
  • Fastfred
13 Dec 2025 22:49
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Category: HAL
OK I corrected the .hal file and pins are reversed like you said but unfortunately still same issue no pop up in GUI no indication something wrong. I can move the axis linuxcnc thinks everything is OK.
  • MaHa
  • MaHa
13 Dec 2025 22:46
There is this bracket ']' to remove:
line 27
#<y_gap_o> = #<_ini[tool_slot_delta]y_gap>]
line 72
#<y_gap_i> = #<_ini[tool_slot_delta]y_gap>]
  • spumco
  • spumco
13 Dec 2025 22:23 - 13 Dec 2025 22:27
Replied by spumco on topic Clearpath HLFB amp.joint.delay
Category: HAL
Good, thanks for verifying the servos are programmed appropriately.
Right now, your HLFB pins are HIGH (conducting) when the servos are enabled and OK.  Since you have the inputs connected to your amp-fault-in pins like:
# HLFB is true when enabled *and* following
net joint.z.amp-fault-in hm2_7i96s.0.inm.00.input-07
net joint.y2.amp-fault-in hm2_7i96s.0.inm.00.input-08
net joint.y.amp-fault-in hm2_7i96s.0.inm.00.input-09
net joint.x.amp-fault-in hm2_7i96s.0.inm.00.input-10
LCNC thinks there is a fault when the servos are saying everything is OK.  Here's the LCNC manual section (motion):
joint.N.amp-fault-in IN BIT should be driven TRUE if an external fault is detected with the amplifier for this joint.
Try changing the HLFB input pins to 'not' like so:
net joint.z.amp-fault-in  hm2_7i96s.0.inm.00.input-07-not
net joint.y2.amp-fault-in  hm2_7i96s.0.inm.00.input-08-not
net joint.y.amp-fault-in  hm2_7i96s.0.inm.00.input-09-not
net joint.x.amp-fault-in  hm2_7i96s.0.inm.00.input-10-not
At that point, the joint.N.amp-fault-in pins should be HIGH when the servos are not enabled, and go LOW when they are enabled and OK.
Once you're at that point, you can test by pulling the encoder cable off the motors and see if it causes the amp-fault-in to go high (hopefully).
If you still need a delay we can work on that next.
  • MaHa
  • MaHa
13 Dec 2025 22:23
I think the problem is, not using uppercase letter. This should work:
Y_GAP = -206
13 Dec 2025 22:20
Replied by tommylight on topic Clearpath HLFB amp.joint.delay
Category: HAL
There is no perceptible rotor cogging when you spin them by hand.
Nice to know, thank you for taking the time to explain that.
  • MaHa
  • MaHa
13 Dec 2025 21:49
Did you add this to the .ini file, the  line with y_gap ?
[TOOL_SLOT_DELTA]
X = 0
Y = -111
Z = 0
y_gap = -206
  • Masiwood123
13 Dec 2025 21:29
now the first three slots work as usual, if I select the fourth one when returning the tool to one of the first three I get this error
  • Sandro
  • Sandro
13 Dec 2025 20:14 - 13 Dec 2025 20:16
Axis deflecting while jogging in G54 was created by Sandro
Category: QtPyVCP
Hello everyone,
I’m experiencing some odd behavior when jogging in the G54 coordinate system. When I jog from X0 Y0 to X100 Y0, the Y-axis deflects slightly, as if a small rotation or compensation is being applied. The final reported position is X100 Y0.084. The Z-axis is not affected. A similar issue occurs in the opposite direction: when I jog along the Y-axis, the X-axis also deflects. However, if I issue an MDI command to move to X100, the Y-axis remains unchanged, which is the expected behavior. When I switch to G55 or G56, everything works as intended—there is no coupling or linkage between the X and Y axes. I’ve attached a screenshot showing the issue: first I moved from X0 to X100 using an MDI command, then manually jogged back. You can clearly see the Y-axis deflection during the jog. I have already cleared all work coordinate systems, but the problem persists specifically with G54.
Any help would be greatly appreciated.
Greetings,
Sandro
  • Fastfred
  • Fastfred
13 Dec 2025 19:49
  • Fastfred
  • Fastfred
13 Dec 2025 19:27
Category: HAL
File Name: custom_2025-12-13.hal
File Size:1 KB
  • Fastfred
  • Fastfred
13 Dec 2025 19:24
Category: HAL
I did setup the MSP software, And I just confirmed the pins again.
Displaying 8146 - 8160 out of 14061 results.
Time to create page: 0.917 seconds
