  • PCW
  • PCW's Avatar
10 Jan 2026 10:18
Replied by PCW on topic LinuxCNC S-Curve Accelerations
I still get acceleration violations but the magnitude seems less
ini values:
File Name: ini_2026-01-10.txt
File Size:5 KB
  • PCW
  • PCW's Avatar
10 Jan 2026 09:46
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
Category: Driver Boards
MB2HAL would need the USB----> RS-485 adapter
hm2-modbus would use PKTUART firmware on the 7I80
For the 7I84 and hm2-modbus you would need a TTL --> RS-485
(for Modbus) and a TTL --> RS-422 adapter (for the 7I84)
These adapters are really just a single driver chip on a small PCB
  • grandixximo
  • grandixximo's Avatar
10 Jan 2026 09:17
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
Both need to be taken into consideration, calculation speed and joints movements, will try to cap to max
  • freemoore
  • freemoore
10 Jan 2026 09:17
I'm looking to check that this combination is viable, and if so for the relevant firmware: 7i80HD-16 or 25, 7i48, 7i42TA, 7i84, and pktUART for MB2HAL.
7i48 is for 5x analogue +/-10v servo amps and 1x analogue VFD.
I need quite a lot of 24V I/O, some of which can be non-realtime, some of which will need to be realtime. Intending to use the cheap Geroosaty  Modbus 16i/16o boards for the non-realtime and the 7i84 for realtime; maybe a relay board via the
Is it possible to use some pins on the 7i42TA as a smart serial port for the 7i84, and some as a A+/B- (single ended) for MB2HAL?
If not I can probably get away with level converters 5V-24V on the 7i42TA and the USB RS485 converter for the modbus stuff, but not having to buy additional boards would be great at this point - already have the above mesa boards on hand.
Many thanks,
Andy
  • ruediger123
  • ruediger123
10 Jan 2026 09:07 - 10 Jan 2026 09:13
Replied by ruediger123 on topic LinuxCNC S-Curve Accelerations
@grandixximo
when I initiate the jerk, you should stick to that.
Does interpolation refer to the movement of the axes or the speed of the calculation?
If the movement of the axes is meant, I can specify a higher jerk.
If I have a stiff machine, I can apply a high jerk and the axles will move smoothly (no overshooting or anything like that). With a soft machine, I have to set a small jerk, otherwise the axles will move erratically (overshooting or anything like that).
Acceleration also plays a role, of course.
If the jerk is maintained, I can adjust the axles properly.
For example, a small jerk and high acceleration.
If the jerk is not maintained, I have to specify a lower acceleration so that the axles run smoothly.
10 Jan 2026 07:57
Replied by tommylight on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
... I can't currently view them.
+1
  • amanker
  • amanker
10 Jan 2026 07:26 - 10 Jan 2026 08:28
eating a std module
Remora PRU - Programmable Realtime Unit
 Mbed-OS6
 Remora-spi Driver
## Entering SETUP state
1. Reading json configuration file
OK
Opening "/fs/config.txt"... OK
Json config file lenght = 3836
Closing "/fs/config.txt"...
2. Setting up DMA and threads
Initialising SPI1 slave
Initialising DMA for SPI
3. Parsing json configuration file
Config deserialisation - Deserialization succeeded
4. Config threads
Creating thread 40000
Creating thread 1000
Creating thread 57600
5. Loading modules
Servo thread object
Reset pin
Make Reset Pin at pin PC_15
Creating a std module
Creating Pin @
  port = GPIOC
  pin = 15
Base thread object
X - Joint 0 step generator
Creating Pin @
  port = GPIOF
  pin = 14
Creating Pin @
  port = GPIOF
 pin = 13
Creating Pin @
  port = GPIOF
  pin = 12
Base thread object
Y - Joint 1 step generator
Creating Pin @
  port = GPIOF
  pin = 15
Creating Pin @
  port = GPIOG
  pin = 0
Creating Pin @
  port = GPIOG
  pin = 1
Base thread object
Z - Joint 2 step generator
Creating Pin @
  port = GPIOG
  pin = 5
Creating Pin @
  port = GPIOF
  pin = 11
Creating Pin @
  port = GPIOG
  pin = 3
Base thread object
E0 - Joint 3 step generator
Creating Pin @
  port = GPIOA
  pin = 0
Creating Pin @
  port = GPIOG
  pin = 4
Creating Pin @
  port = GPIOC
  pin = 1
Base thread object
E1 - Joint 4 step generator
Creating Pin @
  port = GPIOG
  pin = 2
Creating Pin @
  port = GPIOF
  pin = 9
Creating Pin @
  port = GPIOF
  pin = 10
Servo thread object
X min
Make Digital Input at pin PG_6
  Setting pin as No Pull
Creating Pin @
  port = GPIOG
  pin = 6
Servo thread object
X max
Make Digital Input at pin PG_9
Creating Pin @
  port = GPIOG
  pin = 9
Servo thread object
Y min
Make Digital Input at pin PG_10
Creating Pin @
  port = GPIOG
  pin = 10
Servo thread object
Y max
Make Digital Input at pin PG_11
Creating Pin @
  port = GPIOG
  pin = 11
Servo thread object
Z min
Make Digital Input at pin PG_12
Creating Pin @
  port = GPIOG
  pin = 12
Servo thread object
Z max
Make Digital Input at pin PG_13
Creating Pin @
  port = GPIOG
  pin = 13
Servo thread object
Probe
Make Digital Input at pin PC_5
Creating Pin @
  port = GPIOC
  pin = 5
Servo thread object
Estop pin
Make eStop at pin PE_11
Creating Pin @
  port = GPIOE
  pin = 11
Servo thread object
Make Blink at pin PA_8
Creating Pin @
  port = GPIOA
  pin = 8
Servo thread object
Spindle PWM 0
Make PWM at pin PB_0
Creating Hardware PWM at pin PB_0
Creating Pin @
  port = GPIOB
  pin = 0
## Entering START state
Starting the BASE thread
Registering interrupt for interrupt number = 24
    power on Timer 9
Starting the SERVO thread
Registering interrupt for interrupt number = 25
    power on Timer 10
## Entering IDLE state
Here is output on UART from remora firmware
Edit: Launched linuxcnc on terminal, getting "bad spi payload"
(Bad SPI payload = 32393a38)
  • grandixximo
10 Jan 2026 06:29 - 10 Jan 2026 06:31
@ruediger123
at the moment jerk-cmd are debug pins, they are not to be used for machine control, because the current calculations try and do best we can to calculate and blend quickly in realtime, there are knowm spikes in the jerk-cmd, please look at vel-cmd and acc-cmd everything looks very good to me there, there are no violations there, if we were to respect jerk cmd strictly the interpolation would not be able to run as fast as it does, but we could look at making a stricter mode viable as an alternative, or possibly the default if that's what the community needs.
  • grandixximo
10 Jan 2026 05:44
@PCW
try with
setp ini.traj_max_jerk 3000
and
setp ini.traj_default_jerk 3000
I do not get acc violation with these values, can you confirm?
  • meister
  • meister
10 Jan 2026 05:01
this tool is embedded into the AXIS gui:
Menu -> Machine -> Calibration
  • Dave3891
  • Dave3891
10 Jan 2026 00:18
Thanks! That was the problem.
I also set the P value back to 250 and FF1 to 0 and max output to 300.
The other settings were causing a following error, but now everything is working great and milling round circles now.
What is the program you were using to change the joint values in the video? Looks like you can change them without restarting linuxcnc?
  • amanker
  • amanker
09 Jan 2026 23:19
I didn't tested by launching from terminal. But I tried with skr3 board which was tested working and octopus pro with newer(tmc5160) and regular remora both have same problem.
09 Jan 2026 19:42
Replied by tommylight on topic LinuxCNC S-Curve Accelerations
He did but you probably did not get a notification as he edited the existing post.
  • grandixximo
09 Jan 2026 19:34
Share the gcode please, and we will take a look next week
Displaying 8896 - 8910 out of 11476 results.
Time to create page: 1.862 seconds
