  • Thllll
  • Thllll
02 Jan 2026 09:01
Replied by Thllll on topic Probe Error causes Jog lockout
Category: QtPyVCP
I am unable to reproduce the error on the sim because I needed to trigger the probe while it was going to home or the starting location to start probing. This would cause a G38.2 error then the lockout would start. I ran a debug and returned a [Error] from a specific routine. I should have grabbed a screenshot.. I noticed a difference in the sim subroutines folder vs the subroutines folder I got from the github. I replaced all the files and lockout is no longer accruing
  • PCW
  • PCW's Avatar
02 Jan 2026 09:00
Replied by PCW on topic 7i97t Mesaflash Problem
What Mesa fuse? There are PTCs to protect the 5V encoder wiring, if these trip, you have a wiring error.
  • Thllll
  • Thllll
02 Jan 2026 08:18
Replied by Thllll on topic Auto Tool Probe - not callable
Category: Qtvcp
All correct, see attached screenshots
  • my1987toyota
  • my1987toyota's Avatar
02 Jan 2026 07:11
Replied by my1987toyota on topic Fusion 360 Win 10 EOL
Category: CAD CAM
Thanks for the clarification spumco. I had thought for sure Fusion 360 had said something as to not working
on windows 10 machines as of 1-1-2026, but since it is still for the moment working on my Win10 stuff.
I must have been mistaken. I will have to look back to see how to do Win11 LTSC. And yes for me
I am still stuck having to use windows for certain things at work. UGH
  • grandixximo
  • grandixximo's Avatar
02 Jan 2026 07:10 - 02 Jan 2026 07:13
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I moved them
sim
axis
axis_mm_scurve
instead of the main folder.
andypugh just sent me the Tormach 9 axis code, I will be looking at that closely...
  • MaHa
  • MaHa
02 Jan 2026 07:07
Replied by MaHa on topic Plotter and subroutine depth
Category: Flex GUI
After further investigating, it seems when queue buster, M66 E0 L0  or G38.n is used, makes the preview disappear and sub call level is 1
Most of my routines are used for years, and when there were problems with LOG, and DO / WHILE loop and others, queue buster always helped.
I modified a probing routine for diameter inside, just moving with G1. #<queue_bust> can be set to 0 or 1 , to see the problem
the file example.ngc is used to call example_sub.ngc
File Name: example.ngc
File Size:1 KB
File Name: example_sub.ngc
File Size:1 KB
  • Robin123
  • Robin123
02 Jan 2026 06:13
Replied by Robin123 on topic 7i97t Mesaflash Problem
I haven't wired them up yet, but the fuse issue also happened when the power amplifiers were connected.
02 Jan 2026 06:10
Replied by tommylight on topic 7i97t Mesaflash Problem
I would venture a guess at wrong wiring, so first check if analog grounds are wired correctly, from your explanation this seems to be the reason.
  • Robin123
  • Robin123
02 Jan 2026 05:57
The lower LED is slightly dim. I adjusted the voltage; it was 4.6V, now it's 5.1V. When I move the axis, the fuse trips immediately, but the wire only deforms slightly more. Is 1A too low, or is the Mesa fuse defective?
  • Sandro
  • Sandro
02 Jan 2026 05:55
Replied by Sandro on topic Axis deflecting while jogging in G54
Category: QtPyVCP
If I remember correctly, I've checked this back then and the the column R showed 0.0000 for G54 and other offsets. Clearing and saving the offsets did not help. Only G10 L2 P1 R0 resolved the issue. But since then, everything works fine. I will let you know, in case it happens again.
  • Sandro
  • Sandro
02 Jan 2026 05:48 - 02 Jan 2026 05:49
Replied by Sandro on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
Here is a version, which creates a surfacemap.yml so the parameters persist throughout sessions. The variables like probe fast feed rate are still independent from the standard PB probing parameters. Maybe this can be aligned in a future version of this interface.
  • JanCNC
  • JanCNC
02 Jan 2026 05:05 - 02 Jan 2026 05:07
Servos drives directly start turning was created by JanCNC
Hello everyone!
I am struggling with the implementation of my servo drives. I set up the pncconf wizard and did some adjustments, checked the Output Offset and scaled the Encoder. Now I want to start the machine an make some PID tuning, but if i toggle the Machine Power Button the Servos directly starts to turn. After a few secs i got an following error (make sens) and the Servos stops.
What is wrong in my config? Is this an Servo Controller Problem or an Mesa Setup Problem? What should i do next?
I am using the Linux CNC (2.9.4), a MESA 7I92TM connected via Ethernet and a 7i77 at Port P2 for the Servo Drive Control. My Servo Drives (Yaskawa SGDV-7R6A01A) run with +-10V and Encoder Signal to the Linux CNC.
Attached you can find some pictures and files of my config.
Thanks a lot and all the best wishes from Germany
JanCNC
  • endian
  • endian's Avatar
02 Jan 2026 03:56
Replied by endian on topic LinuxCNC S-Curve Accelerations
active setup is faar miles in front of everything... it is very interesting stuff
please reupdate repo /configs with scurve_example.hal and .ini files config for easy setup for other users as it was 1.1.2026 for testing ...
  • grandixximo
02 Jan 2026 01:51
Most of my testing was on 5 axis, need some help with the performance on a cloud of points, but it is not half bad in my testing, I compared with a commercial 6 axis robot on same point cloud, and well maybe we are half the way there, which is not too bad IMO
Displaying 9241 - 9255 out of 11475 results.
Time to create page: 0.683 seconds
