LinuxCNC S-Curve Accelerations
- grandixximo
- Thank you received: 406
02 Jan 2026 07:51 #340869
by grandixximo
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
Most of my testing was on 5 axis, need some help with the performance on a cloud of points, but it is not half bad in my testing, I compared with a commercial 6 axis robot on same point cloud, and well maybe we are half the way there, which is not too bad IMO
The following user(s) said Thank You: endian, zmrdko
- endian
- Thank you received: 134
02 Jan 2026 09:56 #340871
by endian
Replied by endian on topic LinuxCNC S-Curve Accelerations
active setup is faar miles in front of everything... it is very interesting stuff
please reupdate repo /configs with scurve_example.hal and .ini files config for easy setup for other users as it was 1.1.2026 for testing ...
The following user(s) said Thank You: zmrdko
- grandixximo
02 Jan 2026 13:10 - 02 Jan 2026 13:13 #340880
by grandixximo
I moved them
sim
axis
axis_mm_scurve
instead of the main folder.
andypugh just sent me the Tormach 9 axis code, I will be looking at that closely...
sim
axis
axis_mm_scurve
Last edit: 02 Jan 2026 13:13 by grandixximo.
The following user(s) said Thank You: pommen, endian, tiagounderground, zmrdko, Unlogic
- endian
04 Jan 2026 21:05 #340987
by endian
testing in full stream ... its runs at 2ms cycle with profibus master without significant problems ... hardware beckhoff C6930-0060 with native driver at 3.4ghz
video -
video -
The following user(s) said Thank You: grandixximo, tiagounderground, Unlogic
- grandixximo
05 Jan 2026 02:25 - 05 Jan 2026 06:51 #340991
by grandixximo
Thank you so much for the independent testing, really appreciate it.
On another note, for who is not following the PR posts, Andy Pugh and the other devs decided to merge as soon as they can into master branch, so that it can get more wide testing, and probably be part of the 2.10 release, also I will leave here the same thing I posted in the PR on GitHub:
By the way there is also a PLANNER_TYPE = 2 which I have not documented at all, I intended to remove it, but have not come around to do the cleaning yet, that could be cleaned, or the community could be doing some further testing.
The main practical difference is in how they handle cornering velocities during blends, type 1 is more cautious, while type 2 balances smoothness with speed, in my testing type 1 wins out in most scenarios.
Last edit: 05 Jan 2026 06:51 by grandixximo.
The following user(s) said Thank You: Unlogic
- Thank you received: 4151
05 Jan 2026 06:34 #340995
Replied by rodw on topic LinuxCNC S-Curve Accelerations
A couple of us played briefly today on Trixie and we built some debs to share with a few friends.
In the sim, I would like to see
HOME_SEQUENCE=1 for all joints
This will enable the home all button to save some time when playing. No need to home each joint.
I'm just having trouble with a corrupt APT system on my Linuxcnc PC and I am getting latency errors on my office PC so I could not see much but I did briefly see some nice curved graphs in halscope.
I think if it was committed, there would be a stream of testers to find any remaining bugs...
- grandixximo
05 Jan 2026 06:50 - 05 Jan 2026 09:44 #340996
by grandixximo
I saw it the first time I opened it. Couldn't bother myself to fix the sequence on a Sunday afternoon lol
I will fix it for y'all tonight.
Edit:
Done, pushed to github, the ini configuration is better suited for quick testing, you don't even need to home it ([TASK] NO_FORCE_HOMING = 1), but if you do is just one click, and you got infinite limits to load your wildest g-codes.
Edit:
Last edit: 05 Jan 2026 09:44 by grandixximo.
The following user(s) said Thank You: rodw, endian
- endian
05 Jan 2026 12:29 #341005
by endian
is homing at joint.0.index_enable avaible?
I can not home my profibus sstuff it looks like index_enable is still down ..
I have had to uuse the NO_FORCE_HOMING = 1
thanks
thanks
- grandixximo
05 Jan 2026 12:46 - 05 Jan 2026 14:12 #341006
by grandixximo
HOME with index should be available, nothing about homing should have changed other than the homing movements being now jerk controlled, but I'll double check on my end, you still have to enable
HOME_USE_INDEX = YES
In the ini file for each joint you want to home using index
Edit:
Yeah, triple checked, homing index should work as expected, just has to be set proper, mind that machine movements will be effected by the s-curve even while homing, if you do not want that, you can link all joint.N.homing pins with or2, then to a mux2, and then to the ini.traj_planner_type pin in hal, so when you home you can have planner 0, otherwise planner 1, I originally had an INI flag to disable s-curve while homing, if you guys think is necessary I'll add it back, but I ended up not liking the machine shaking up only when homing, I want it always to be smooth now, I'd rather readjust the homing vel to compensate for the longer but smoother movements.
Edit:
Last edit: 05 Jan 2026 14:12 by grandixximo.
The following user(s) said Thank You: jschulze, endian
- endian
05 Jan 2026 19:35 - 05 Jan 2026 20:17 #341020
by endian
yes exactly ... if all axis homed then ini.traj_planner_type == 1 else 0 ... its important for external drivers over buses maily...
2nd day of testing at hardware is away... motion is way smoother and followinf error ar beginning at ending of movement is away too
thanks
thanks
loadrt and2 count=2
loadrt mux2 count=1
loadrt conv_float_s32 count=1
addf and2.0 servo-thread
addf and2.1 servo-thread
addf mux2.0 servo-thread
addf conv-float-s32.0 servo-thread
addf lcec.write-all servo-thread
net homed-0 joint.0.homed and2.0.in0
net homed-1 joint.1.homed and2.0.in1
net homed-01 and2.0.out and2.1.in0
net homed-2 joint.2.homed and2.1.in1
setp mux2.0.in0 0
setp mux2.0.in1 1
net homedAll and2.1.out mux2.0.sel
net fPlannerSwitch mux2.0.out conv-float-s32.0.in
net diPlannerSwitch conv-float-s32.0.out ini.traj_planner_type
Last edit: 05 Jan 2026 20:17 by endian. Reason: .hal edit
Time to create page: 1.235 seconds
