  • djdelorie
  • djdelorie
14 Dec 2025 21:52
Replied by djdelorie on topic Clearpath HLFB amp.joint.delay
Category: HAL
Here are my full configs, since I didn't know which "part of the file" you meant.
  • Fastfred
  • Fastfred
14 Dec 2025 21:47
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Category: HAL
Would you mind sharing that part of the file ?
  • djdelorie
  • djdelorie
14 Dec 2025 21:19 - 14 Dec 2025 23:07
VOLATILE_HOME not unhoming on fault was created by djdelorie
Category: Basic Configuration
I set VOLATILE_HOME for each joint in my config, and I know it works because if I push the OFF button in the GUI, all the axes become unhomed.  However, if a servo fault comes in, that also shuts the machine OFF but in that case the axes remain homed.  If I ON-OFF via the gui after a fault, it unhomes. This is neither what I expected nor what is documented(1). How do I get the axes to unhome on a servo fault? (the fault comes in via joint.N.amp-fault-in)
(1) "If this setting is true, this joint becomes unhomed whenever the machine transitions into the OFF state. "
Edit: I'm using version 2.9
  • djdelorie
  • djdelorie
14 Dec 2025 21:11
Category: HAL
I spent some time working on my machine's fault handling, and in the end all I had to add to get it to do what I wanted (stop machine on fault) is to add these (in addition to the configs I posted earlier):
  net x-fault      => joint.0.amp-fault-in
for each joint.  I also set VOLATILE_HOME for each joint in the *.ini but it didn't do exactly what I wanted.
Given that I use joint.N.amp-enable-out (aka x-enable, set in MACHINE.hal automatically) to enable the clearpaths, as soon as a fault comes in, it posts a warning and shuts the machine off, which disables the clearpaths, which clears the fault.
  • vibram
  • vibram
14 Dec 2025 21:07
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
My ESC TEST VALUE reading is fine...
i tried a lot of things but dont know why i cant get the eeprom correctly set up. Maybe its something with the board I dont know
  • Fastfred
  • Fastfred
14 Dec 2025 20:23
Category: HAL
I tried changing the naming, but had to use different name because was already assigned to pin.I get joint fault as soon as i try to enable I did try changing delay thinking that was it but no luck.  Unless I still having a naming issue with the pins unfortunately I still don't understand this part yet.
File Name: custom_2025-12-14.hal
File Size:1 KB
  • endian
  • endian's Avatar
14 Dec 2025 19:58
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
Did anybody get it to run with Rods guide??
E.
  • Hakan
  • Hakan
14 Dec 2025 19:35
Category: EtherCAT
I think they all describe steps to bring data in and out of the drive, steps that are missing in the lcec case. SOEM mentions fragmentation/defragmentation. Not more complex than that. I haven't found out if the hardware I have can be used for a prototype.
I'll keep searching.
  • Muzzer
  • Muzzer
14 Dec 2025 19:20 - 14 Dec 2025 21:12
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Thanks for the reply. I've been busy with roofing, plumbing, parquet flooring etc but managed to sneak out to the workshop finally.
I've managed to get the spin boxes to appear in an otherwise blank macro screen, which is some form of progress. This was by removing the "notouch=1 -U norun=0 -u" switches from the EMBED_TAB_COMMAND line.
However, the gmoccapy screen is now bigger than the primary display once gladevcp starts up. That doesn't seem to prevent anything new from working otherwise. Presumably I need to correct the screen resolution, possibly by installing better video drivers? It used to fit the screen.
EDIT: the native resolution of the Hanspree HT225 is 1920x1080, same as the second display. No end of playing with display seems to prevent the GUI spilling over beyond the extents of the display(s), other than commenting out the EMBED_TAB line.
My path statement looks like this but perhaps I need to read up on linux path syntax:SUBROUTINE_PATH = ~/nc_files:~/lathe_macros:~/subroutines:~/python
...where those subfolders are in the folder where the INI file is held.
EDIT: I now see I should use the dot character rather than tilde in linux to denote a relative path. I will try that...
Beyond that, when I run linuxcnc from the command prompt, it reveals a royal mess. Clearly gladevcp isn't happy (see attached log file).
I tried installing python-rsvg but it didn't like that:
murray@LinuxCNC:~$ sudo apt-get install python-rsvg
[sudo] password for murray:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package python-rsvg
There are a few things going on here, to say the least - could you suggest what I focus on in the first instance?
File Name: oof.txt
File Size:38 KB
  • PCW
  • PCW's Avatar
14 Dec 2025 15:49 - 14 Dec 2025 15:59
Replied by PCW on topic Issues with simple input on 7i76eu
Category: Driver Boards
The 7I76EU inputs have a threshold of 60% of VFIELD when going positive and 40% of VFIELD when going negative.
This means with 24V VFIELD, a voltage below 9.6V is read as low and a voltage above 14.4V is read as high.
This  is called hysteresis, and is deliberate behaviour for noise immunity. With a 10 K pullup you end up just in the middle
of this input threshold range, You need a stiffer pullup resistor (say 2.2K) so that you have a valid input to the 7I76EU.
  • liutas4x4
  • liutas4x4
14 Dec 2025 14:02
Adding second spindle control to pyVCP: is it complicated?
Category: pyVCP
Thank you. I'll learn. And ask there if don't catch something.
  • Sandro
  • Sandro
14 Dec 2025 11:36 - 14 Dec 2025 11:38
Replied by Sandro on topic Axis deflecting while jogging in G54
Category: QtPyVCP
Thank you very much MaHa!
This worked. Initially with (debug,#5230) I got -0.012195. After G10 L2 P1 R0 it was reset to 0. Perfect. So there was a rotation active? Maybe a leftover from when I probed rotation of a workpiece?
  • Hakan
  • Hakan
14 Dec 2025 10:54
Category: EtherCAT
PDI = that parallel communication mode? Noone uses it. Everyone uses SPI.
The last few lines in the xml file should look similar to this. The first "80" means spi, then there
is polarity and other settings.
        <Eeprom>
          <ByteSize>2048</ByteSize>
          <ConfigData>80060344640000</ConfigData>
        </Eeprom>
Read out the eeprom from the board and verify that is says "80" in the first byte.
I have had my fair share of problems with SPI so I think you again should verify that you can get past the ESC_init() function.
Use the debugger and verify that you read 0x87654321 from LAN9252 on line 445 in the figure
You may need to power cycle the LAN9252, it only reads eeprom after power down.
  • BoMadsen
  • BoMadsen
14 Dec 2025 09:25
Replied by BoMadsen on topic Issues with simple input on 7i76eu
I am pretty sure that you are correct, at least in the part about the inputs being reversed between the two boards.
But it is my understanding that this is why the pull-up resistor is needed, so that the input at idle is 12v and then when activated goes to 0. So to get the correct logic in linuxcnc I use the xxx-not input signal.
But I don't understand why the hal state doesn't change after the first trigger, even though I can see the voltage change on the input pin.
  • vibram
  • vibram
14 Dec 2025 09:16
Category: EtherCAT
I managed to get spi working but I might have an issue with the eeprom. Apparently I'm stuck in PDI mode and lan9252 is not communicating through spi
Displaying 9946 - 9960 out of 11519 results.
Time to create page: 0.312 seconds
