  • Route 66 Scott
  • Route 66 Scott
14 Nov 2025 16:20
LinuxCNC + Mesa 7i92TF + Gecko G540. Docs are useless. Help, Please!
Category: PnCConf Wizard
Thank you for the link.
I set up the software limits and homes. I assumed the hardware limits wouldn’t be necessary to get it running.
What I don’t understand at this point is how I get the gantry, which is currently at the midway point of the machine, 24” from the desired home location, jogged to the home location, in this software, so I *can* home it. I don’t see how wiring in the physical switches allows me to do that.
Hopefully the docs will get me there. Thanks.
  • Route 66 Scott
  • Route 66 Scott
14 Nov 2025 16:06
Thanks. I’ll order the switches.
Having a blast is not my goal here. I need a working tool.
To be clear, when I set up the limit switches the software will treat the two Y motors as one? Currently they are being treated as separate axes, which makes it impossible to move the gantry to a home position.
  • Masiwood123
  • Masiwood123's Avatar
14 Nov 2025 15:25
MesaCT 7i96s + 7i77 was created by Masiwood123
MesaCT 7i96s + 7i77
Category: Configuration Tools
hello, since there is no default configuration for 7i96s+7i77 in pnccfg, I'm trying to use mesact, but I get an error, I can't enter values ​​in the specified fields at all. thanks
  • abs32
  • abs32
14 Nov 2025 15:03
Replied by abs32 on topic scurve trajectory planner
Colleagues, does this apply for version 2.8.4?
  • vibram
  • vibram
14 Nov 2025 14:33
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
Yes this is my goal, everything on a same board.
IC-NV part is not easy but one from PEdpex is working so I should use the same.
There is not much chip that can do this as good as IC-NV so I might stick to this one.
And STM32F4 works good for encoders so it should be a good match.
I will try to start from your E7000 then thank you
  • kmeld
  • kmeld
14 Nov 2025 14:14
Installing samba was created by kmeld
Installing samba
I want to install samba, but apt install samba gives "Package 'samba' has no installation candidate", I did apt update but it didn't help. I checked repositories and there is only linuxcnc.org. Should I have also Debian repositories or not? How to install samba?
Also do I need: "download.opensuse.org/repositories/science:/EtherLab/Debian_12/"? What is it for? It gives an error on apt update:
"Get:1 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease [1,575 B]
Err:1 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease
  The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project <science:EtherLab@build.opensuse.org>
Hit:2 repository.qtpyvcp.com/apt develop InRelease
Hit:3 www.linuxcnc.org bookworm InRelease
Reading package lists... Done
W: GPG error: download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease: The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
E: The repository 'download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details."
  • Hakan
  • Hakan
14 Nov 2025 13:27
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
I found Pedpex's work, awesome.
Maybe that is what you have in mind, but I would put his circuitry on the same board as ethercat
to have it neatly packaged.
One thought I got is if one can skip the quadrature part in some way. Are there sin cos chips
that can deliver a value over spi or i2c for example?
The built-in quadrature encoder in stm32f4 can read with at least 3 MHz so maybe not a big problem.
I have code to extend numbers over the 16-bit and 32-bit boundary.
Code for encoder counting is in E3000 project.
Best to base HW on E7000 project, clear out pins and I2C and add encoder inputs.
  • vibram
  • vibram
14 Nov 2025 12:56
AX58100
Category: EtherCAT
IC-NV are here for the conversion, not easy to setup but Pedpex, a member from the forum did the stuff.
My goal is to merge his project to yours basically.
I will prepare all the work environment and when the schematic will be done or almost I will open a thread. Maybe i should start with a prototype PCB from you as I already get a pcb from pedpex and when everything is running, I do the merge
  • Jensner
  • Jensner
14 Nov 2025 12:09
"error finishing read" with Mesa 7i92T on fresh install
Category: Driver Boards
I Installed the
r8168-dkms Package and till now the error hasn`t appeared again...
WIll have a look at it.
Best regards
Jens
  • Jensner
  • Jensner
14 Nov 2025 10:53
Here is a screenshot from the Latency Test of the old configuration. Only for the Kernel-Infos.
The latency was horrible at this time (without irq-optimisation at this time)
  • Hakan
  • Hakan
14 Nov 2025 10:47 - 14 Nov 2025 11:22
AX58100
Category: EtherCAT
I don't know much about cos sin. The whole processor is available for you to do all sorts of processing.
The ethercat part is the easy one I would say.
Every cycle you calculate a new encoder value, set a pdo variable and the soes library does the rest.
Edit. But I checked quickly. So you need to take in two analogue signals and calculate the phase angle.
Absolutely doable, could be a nice application.
Start a project thread and I'll give you a hand with the ethercat stuff.
Edit 2. The ADCs on STM32F4 are only 12-bit, you may need 16-bit ADC for this. Another processor?
External 16-bit ADC unit?
Edit 3. IC-NV instead of ADCs of course.
  • Jensner
  • Jensner
14 Nov 2025 10:43 - 14 Nov 2025 10:59
I also did a fresh installation on a DELL Optiplex 3060 Micro PC (RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller)
Everything incl. IRQ-Optimizing (Latency) works fine, but i also run into this error "Error finishing read" with my MESA 7i96s.
--- 10.10.10.10 ping statistics --- 46085 packets transmitted, 46085 received, 0% packet loss, time 46101ms rtt min/avg/max/mdev = 0.050/0.062/[color=#e74c3c]3.014[/color]/0.039 ms
In my old installation (at this PC) i run the 3.6.0 rt11 Kernel and did not have this problems, so i think, last time i updated it for the same reason. Sadly i don`t know how to do this update again.
Is there an easy way only updating the kernel?
(Sorry but I`m not in the Linux-Space, so its a little hard for me)
Thanks a lot
Jens
  • viacolvento
  • viacolvento
14 Nov 2025 10:39
Funzioni pausa e resume con pulsanti esterni.
Category: HAL
Buongiorno, sono un nuovo iscritto di appena 78 anni, appassionato di elettronica e meccanica.
Ho bisogno di inserire le funzioni Pausa e Resume per poter fermare gli assi x e y mentre l'asse z si trova in un certo punto, e riprendere il loro movimento quando l'asse z raggiunge il punto successivo (tutto controllato da fotoaccoppiatori). so che è possibile, ma purtroppo la mia competenza nel linguaggio di Linuxcnc è limitata.
Grazie.
  • billykid
  • billykid's Avatar
14 Nov 2025 09:13 - 14 Nov 2025 09:47
Replied by billykid on topic ECAM 5 POST Processors
Category: Post Processors
I use ecam, as soon as I can I'll send you mine, it works well.
  • vibram
  • vibram
14 Nov 2025 08:27
AX58100
Category: EtherCAT
Hello,
Thank you for your reply
Ideally, I would like to integrate the project from PedPex which is a COS SIN converter (with IC-NV chip) for heidenhain glass scale directly as an ethercat module. It would receive COS SIN signal, convert it to quadrature, read by the STM32 then sent to Ethercat.
But this is a little bit out of my league knowledge wise, even if you did most of the job regarding ethercat and Pedpex most of the job regarding COS SIN conversion
Displaying 11131 - 11145 out of 12724 results.
Time to create page: 0.463 seconds
