  • clayton2ndtry
  • clayton2ndtry
09 Nov 2025 16:19
wifi adapters was created by clayton2ndtry
wifi adapters
Because I am using an antique desktop (Dell Optiplex 960) and WiFi, I am stranded at linuxCNC 2.7.15.  I have struggled to get decent network speed.  Only some USB WiFi adapters work native to 2.7.15.  (Trying to install drivers for adapters with other chipsets was more effort than it was worth.)  The SMC EZ Connect works, but it is only 802.11g and because there is a range and refrigerator in line of WiFi to router, I was limited to about 16 Mbps.
I decided to take a walk on the wild side and bought a BrosTrend Linux USB WiFi Adapter AC1200 for Ubuntu Kali Mint Debian Kubuntu Mate Zorin PureOS Raspberry Pi Windows etc. Linux Compatible WiFi Adapter Wireless Dual Band 5GHz 867Mbps + 2.4GHz 300Mbps.  Once I followed the instructions at linux.brostrend.com/ I was able to install the drivers for what is apparently the AC1L family and now I get 240 Mbps. Customer support was necessary to figure out which driver family was required during driver installation.   Curiously, plugging the adapter into the front USB ports gave me many times the rate as rear USB ports.
  • Masiwood123
  • Masiwood123's Avatar
09 Nov 2025 15:19
Replied by Masiwood123 on topic beta bulleri for retrofit?
Category: CNC Machines
I found encoder signals and attached z encoder linuxcnc reads nice with encoder scale -400, ballscrew is 5mm per revolution and encoders are 500 lines. now I have to connect the others and find a way to enable the drivers because they are all in the box, not each one individually.
09 Nov 2025 12:22
Replied by tommylight on topic Replacement for RPI5
Sorry, forgot the link, added on the first post.
  • axemas
  • axemas's Avatar
09 Nov 2025 12:09 - 10 Nov 2025 14:17
  • zoeper
  • zoeper
09 Nov 2025 11:54
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
I also have the wiring diagram and pinouts for the two ribbon cable connectors from the control to the electrical cabinet.
  • zoeper
  • zoeper
09 Nov 2025 11:46
This is the original sales brochure for the machine.
  • Masiwood123
09 Nov 2025 11:34
I updated the firmware for 7i96s+7i77, I had to make a basic configuration on 7i92+7i77, then changed to ini 7i96s, does this work ok, the first thing I want is to attach encoders, however in hal it says 0 pwm generators if I change them to 6 I can't start linuxcnc.
  • rodw
  • rodw's Avatar
09 Nov 2025 10:57
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
Yes, trixie uses python3.13. I guess it would be fine in bookworm with 3.11.
It turned out the tool_db issue was just a setting in xyz.ini. The tool program is in /usr/bin.
I have played around a bit and yes it looks very very nice.
The material handling looks awesome.
So I'll turn it into a real machine, for my plasma cutter.
Yes, I helped Joco get this working on real hardware when he did the first development. and it is very good. Built like a touch screen gui should be!
  • rodw
  • rodw's Avatar
09 Nov 2025 10:52
USB pendant stops working after using macros
Category: Qtvcp
There is a halui pin halui.mode.manual  that can do this and halui.mode.teleop will enable jogging. I have used these with pendants.
  • zoeper
  • zoeper
09 Nov 2025 10:24
Avon 3000 Mill retrofit was created by zoeper
Hi All, I want to tackle a project that I started about 6 years ago and never got round to.
Mi Avon Mill with Anilam GXM contro        l served me well until one day it did'nt. First the one servo driver failed. The machine uses Baldor (i think) DC servo motors with tacho and encoder feedback. I replaced the drive and the machine was running OK. At some point I re-soldered some of the Anilam control cards, as the machine was acting unpredictably and I suspected dry joints. I decided it was no longer useable when the Z-axis had a runaway and crashed a tool into my manual tool setter. (coming to think of it, this could also have been an encoder problem)
I bought a Mesa 5i25 Superport and a Mesa 7i77D card for it, but that is where I got stuck.
I now started up an old Dell Core 2 Duo machine with 4GB ram and a 240GB SSD for the retrofit, and installed LinuxCNC 2.9.4
My plan is to first get the Dell and Mesa cards running on the bench, Maybe toggle a output and read a handwheel or switch. Then do the transplant and get things working from there. If possible, I want to use the existing electrics cabinet and just connect to the two ribbon cables connecting the Anilam with the electrical cabinet. I will start with the existing drives, and upgrade to AC drives and motors when budget allows.
Comments and suggestions welcome
  • archie82
  • archie82
09 Nov 2025 09:47
Replied by archie82 on topic NVEM V5 LINUXCNC REMORA FIRMWARE[SOLVED]
Hi DarkPhoinix,
Could you please describe the steps you have used to successfully flash remora as i'm having issues connecting to target using j-link.
Many thanks
archie
  • onceloved
  • onceloved's Avatar
09 Nov 2025 08:41
Replied by onceloved on topic Replacement for RPI5
Pics or it didn't happen
  • zz912
  • zz912's Avatar
09 Nov 2025 08:21 - 09 Nov 2025 08:32
GTK little probe screen was created by zz912
Category: Gmoccapy
I am working on modification of Probe Screen by Serguei Glavatski (c) 2015
This modification moved the icons from one window to containers with switchable vertical tabs.
I have a control panel made on the machine.
Unfortunately, I have a display with a low resolution.
So I have to save space on the screen. That's why I used switchable vertical tabs.
At the moment, the Gmoccapy screen is huge, because there is a bug:
github.com/LinuxCNC/linuxcnc/issues/3611
What do you think about GTK little probe?
I'm using an old version for modification, if you're interested in the current version, check here:
- vers.ge/en/blog/useful-articles/probe-screen-v28
- github.com/verser-git/probe_screen_v2.9
  • AgentWD40
  • AgentWD40's Avatar
09 Nov 2025 07:19
Replied by AgentWD40 on topic Replacement for RPI5
Did you have a video or a link you meant to post? What are we talking about?
  • unknown
  • unknown
09 Nov 2025 04:17
Replied by unknown on topic Replacement for RPI5
And I know we have very differing opinions on the RPi5.
Maybe it's time for an old skool Flame War ;)
Displaying 11326 - 11340 out of 12771 results.
Time to create page: 1.455 seconds
