  • Hakan
  • Hakan
31 Oct 2025 17:48
Machine plasma torch IPTM-80 and ohmic sensor
Category: Plasmac
Here is how I did it.
forum.linuxcnc.org/show-your-stuff/56269...sensing-with-iptm-60
TLDR; Disconnect the ground lead in the plasma torch cable. Measure voltage between material ground and torch tip.
  • lev
  • lev
31 Oct 2025 17:28
Category: Plasmac
Hi all
i bought a cheap plasma  Herocut Cut55i and i have machine plasma torch IPTM-80 like this
i try to do ohmic Hypersensing with a MESA THCAD-10 on my cnc table
Can you explain how physicali connect ohmic sensor?
Can i do ohmic ring something like that to the copper shield
or it is impossible on this type of torch and all that remains is floating switch?
thank you
  • Gogonfa
  • Gogonfa
31 Oct 2025 17:02
Replied by Gogonfa on topic Umbau der Steuerung auf LinuxCNC + EtherCAT
Category: Deutsch
Hallo Zusammen,
Ich les mal mit, will von einer Eding CNC760 auf Ethercat und LinuxCNC umsteigen….
Ich will in Zukunft 1KW Delta Servos und eine 11KW Delta M300 FU verwenden, alles mit t
Ethercat Schnittstelle. Den Buskoppler hab ich heute bestellt ebenso ein paar DI und DO Karten….
31 Oct 2025 16:54
Replied by tommylight on topic Joint 2 on limit switch error -> Z Axis
Category: Basic Configuration
-1mm might not be enough to move off of the switch so try -2 or -3.
If it still does not work, try 2 or 3.
Also, hoome sequence should be 0 for Z axis so it moves up before other joins/axis start homing.
  • PCW
  • PCW's Avatar
31 Oct 2025 16:13
Replied by PCW on topic USB activity causes network error
Category: Plasmac
 You can check the irqmask ( and grub setup) with this script
File Name: checkmask_...0-31.txt
File Size:1 KB
usage
first
chmod + checkmask,txt
then
./checkmask.txt  [ethernet_device_name]
You can pin  the Ethernet IRQ to the last processor with this script
File Name: pinirq_2025-10-31.txt
File Size:1 KB
usage
first
chmod + pinirq,txt
then
sudo ./pinirq.txt  [ethernet_device_name]
To disable irq coalescing temporarily for testing:
sudo ethtool -C [ethernet_device_name]  rx-usecs 0
To permanently disable IRQ coalescing, you setup the RT ethernet interface in the interfaces file, something like:
auto eth0
iface eth0 inet static
address 10.10.10.1
hardware−irq−coalesce−rx−usecs 0
  • DerKlotz
  • DerKlotz
31 Oct 2025 14:09
Replied by DerKlotz on topic Joint 2 on limit switch error -> Z Axis
Any Idea why my Z Axis won´t home anymore? I changed the negative travel distance. But before i noticed that i can´t change some values anymore -> see attached file
  • DerKlotz
  • DerKlotz
31 Oct 2025 13:43
  • DerKlotz
  • DerKlotz
31 Oct 2025 13:17
31 Oct 2025 13:10
Replied by tommylight on topic USB activity causes network error
Category: Plasmac
Yes, but only for the network Mesa is attached to.
  • mariusl
  • mariusl's Avatar
31 Oct 2025 13:03
Replied by mariusl on topic USB activity causes network error
Category: Plasmac
It is the included one yes. So you say I must select the option of "Use this connection ..."
  • Philip Lydin
  • Philip Lydin
31 Oct 2025 12:58
Replied by Philip Lydin on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Has anyone used the io pins on the drives as io pins in linuxcnc?
31 Oct 2025 12:22
Category: Plasmac
Tommy I usually make use of nmtui or the network manager
Is that the included Network Manager ?
If yes, then make sure the below is selected:
31 Oct 2025 12:18
Final home position from 0 to -3
  • rodw
  • rodw's Avatar
31 Oct 2025 12:17
Replied by rodw on topic Joint 2 on limit switch error -> Z Axis
please share your hal and ini files
  • DerKlotz
  • DerKlotz
31 Oct 2025 12:10
Joint 2 on limit switch error -> Z Axis was created by DerKlotz
i get the "Joint 2 on limit switch error". I have a Mesa 7i76e and you can find my configuration for Joint 2 attached.
I tried several things but still with no success.
Please help
Displaying 11746 - 11760 out of 12803 results.
Time to create page: 1.339 seconds
