  • PCW
  • PCW's Avatar
15 Sep 2025 22:58 - 15 Sep 2025 23:15
Replied by PCW on topic 7i97T -> 7i74 -> two 7i84U (no link)
Category: Driver Boards
I think I may have found the issue:
There's a bad 7i97t_7i74d.bit firmware file around
If your file is dated 2023, it's bad
The current one, fetch-able from Mesa's  web store works.
(dated May 2025)
15 Sep 2025 20:32
Replied by tommylight on topic G81 Spindle Reversal Between Each Hole
Should we change the tittle to G83 ?
  • WKS-3D
  • WKS-3D's Avatar
15 Sep 2025 19:41
Replied by WKS-3D on topic Glasmaßstab EIA-422 an Mesa 7i85 (S)
Category: Deutsch
@PCW
I actually only talked about one problem, or rather, for me it was only one problem, namely that no setting leads to the index signal being recognized or responded to.
I tried changing the jumper settings to TTL signal to see if that would trigger a response, but unfortunately that wasn't the case.
For example, I went through all possible combinations from 000 to 111 to see if anything changed:
setp    hm2_7i92.0.encoder.00.index-invert 0
setp    hm2_7i92.0.encoder.00.index-mask 0
setp    hm2_7i92.0.encoder.00.index-mask-invert 0
No difference was noticeable with either the RS-422 or the TTL signal.
@tommylight
That's right, I'm not logged in as root; I just checked again, but you shouldn't do that under Linux anyway. Anyone working on the machine could destroy the entire system. Besides, everything is running smoothly except for the problem with the index, and it's not due to permissions.
I don't use a parallel port; a 7i92t + 7i76 + 7i85 is built in.
However, I have since discovered that there are often problems with the DC11 GMS and the index signal; it is either very weak or not output at all.
I probably have two such units. But since I don't want to waste any more time on this problem, I'll leave it alone and work with it as it is now.
Thank you very much for your support, and I'm glad this forum exists.
Greetings
Olli
  • Darium
  • Darium
15 Sep 2025 18:40
Replied by Darium on topic G81 Spindle Reversal Between Each Hole
@langdons
The bird nest is quite a issue,sometimes it catchs on the workpiece causing a spike on spindle load, it can even break small diameter drill. I dont think add magnet should helps since the swarf was tighten on to the drill when pulled.
Are you sure about steel wool? Mine are sharp af, got numerous cuts just to pull it out with a plier.
Standing infront of the machine for hours just to remove chips defeats the purpose of a CNC machine.i tried manually adding M4 wait for 3s then M3 it works like a charm, but also when camming a hundred holes, that shit gets old real quick.
There is no locknut in the spindle so spinning it backward shouldn't be a problem. I'mma add braking resistor to the drive so that should be fine too.
@unknow
Remaping is way way over my head and messing around with it can crash my machine (I broken a spindle shaft once, it was a sad month). I may take a look on subroutine.
i drilled some decent steel, and the chip break nicely, just that I have shit steel. Good steel is too far to get and not every part required one.
@tommylight & Aciera
It's a typo on the tittle, I always use peck drill
  • N3pu
  • N3pu
15 Sep 2025 17:13 - 15 Sep 2025 17:34
Probescreen versa v1 Problem with XYZ Auto-Zero Gmoccapy LinuxCNC 2.9.1
Hey Guys,
I´ve bought a probe for my mill and installed the versa probescreen v1 in gmoccapy. I´ve used this source (forum.linuxcnc.org/48-gladevcp/46467-pro...-v1-for-python3-gtk3) because I´m using LinuxCNC 2.9.1. I don´t want to use v2 cause I have a lot of things programmed for the toolchange in my .hal file I don´t want to change. I just like to probe xyz and auto zero.
After probing the probe is not at the corner of x and y and the zero point is offsettet.
Similar issue for probing in Z direction. Zero is not set at the surface.
Is there a missunderstanding of function or is it wrong?
I´ve uploaded a video of the issue. Maybe you´ll see something
Edit: Updated Video (cause of wrong video cut)
  • LinuxCrashOut
  • LinuxCrashOut's Avatar
15 Sep 2025 17:11
HAL help needed for MPG wheel jogging and machine enabling logic
Category: HAL
Okay, thanks, I will try it out and keep you updated :)
I will post the full config when I am done :D
  • jmp97
  • jmp97
15 Sep 2025 17:08
Replied by jmp97 on topic 5-axis CNC recommendation
The second image shows seven tabs playing YouTube videos.
I will use the laptop solely and exclusively for the CNC. I will not run anything else at the same time.
Is my laptop suitable? It is a small CNC. I use a feed rate of 1,000 mm/min, and I will use the 5 motors/axes to machine a thin plastic plate (little effort). I will machine molds on 3 axes.
15 Sep 2025 16:36 - 15 Sep 2025 16:37
Replied by tommylight on topic 5-axis CNC recommendation
First picture is OK, the second is not, so:
forum.linuxcnc.org/18-computer/40285-bios-settings-pictures
Se what you can disable there, test, if the result is still bad, try this but try this at your own risk as it requires messing with kernel parameters and might leave you with a non bootable system, not terrible if you are still inn the testing phase as you can reinstall in about 5 to 15 minutes depending on the PC/USB/HDD/SDD/NVME speed.
15 Sep 2025 16:15 - 15 Sep 2025 16:16
Replied by tommylight on topic Glasmaßstab EIA-422 an Mesa 7i85 (S)
Category: Deutsch
Your picture here
forum.linuxcnc.org/42-deutsch/56803-glas...85-s?start=10#334968
shows several warnings about permissions, it is not just index, so if you are running as root user, switch over or reinstall as LinuxCNC will vigorously refuse to run properly as root, as will most of the Linux "user space" software.
Also, are you using a parallel port? Why does it say that in the error report?
  • jmp97
  • jmp97
15 Sep 2025 16:11
  • PCW
  • PCW's Avatar
15 Sep 2025 15:20
Replied by PCW on topic Glasmaßstab EIA-422 an Mesa 7i85 (S)
Category: Deutsch
When, you say  "unfortunately the result is the same" , it would be helpful if you
specified the actual results as there have been at least three separate issues discussed here.
  • WKS-3D
  • WKS-3D's Avatar
15 Sep 2025 15:04 - 15 Sep 2025 15:07
Category: Deutsch
What's going on with this site? It takes forever to load, or it's not even accessible. I've been trying to reply here for 35 minutes.
@tommylight
All other changes are executed, so why should it be any different with the index signal? Yes, it should be executed as ROOT user.
@PCW
 I also set the jumpers to TTL and tried it out, but unfortunately the result is the same.
Here are the HAL and INI:
File Name: probe_basi...15-2.ini
File Size:5 KB
File Name: hera_probe...15-2.hal
File Size:13 KB
15 Sep 2025 14:20
Please upload the pictures here on the forum, not on 3'rd party websites.
Thank you.
15 Sep 2025 14:16
Category: Deutsch
Just to be sure, are you running as user ROOT ?
Displaying 12901 - 12915 out of 13742 results.
Time to create page: 0.802 seconds
