  • Martin.L
  • Martin.L
06 Sep 2025 12:18
Replied by Martin.L on topic Stepperonline A6-1000EC driver
Category: EtherCAT
replace x with your servo/spindle index
net s-vel-cmd <= spindle.0.speed-out
net s-vel-cmd => cia402.x.velocity-cmd
You will need csp mode 0 :
setp cia402.5.csp-mode 0
setp cia402.5.pos-scale 1
  • Aciera
  • Aciera's Avatar
06 Sep 2025 11:15
Replied by Aciera on topic The Parameters
The Parameters
Not a lot to go on. Where are you assigning a value to what parameter, where are you trying to access it and what happens when you do?
Usually best to give a short example of what you are trying to do and describe what is not working as expected.
  • Martin.L
  • Martin.L
06 Sep 2025 10:34 - 06 Sep 2025 12:10
Replied by Martin.L on topic M100 on subroutine hangs
Category: HAL
I have tryed both, unfortunately #!/usr/bin/env bash makes no difference. Also halcmd show signal s-index-zero-for-ATC stays false. I also tryed to call M100 from a remapped M19 but it's totally ignored, meanwhile the same sintax for similar commands like M10 or M21 works fine.
UPDATE: somehow in toolchange.ngc M1xx doesn't work, just hang the M6Tx called BUT I noticed it works inside the subroutines called by toolchange.ngc, like M10 (remapped) so I temporarly solved.  What it could be the cause?
  • rebelx
  • rebelx
06 Sep 2025 09:39 - 07 Sep 2025 09:24
Replied by rebelx on topic LinuxCNC on Intel Clear Linux
Category: Installing LinuxCNC
Hi NTULINUX,
I finally had the chance to try out your Gentoo-based LinuxCNC distro on my N100 system — thanks for putting it together!
At first, I was a bit surprised (and honestly a little disappointed) because the initial latency results were significantly worse compared to my Debian 13 / KDE setup. I even posted my findings yesterday to share what I saw. However, after digging a bit deeper today, I discovered that when I installed your Gentoo distro onto a new NVMe drive, the BIOS settings had somehow been reset to defaults. That definitely explained the poor initial performance!
Once I re-applied the correct BIOS settings, the latency results improved considerably. While it's still not quite as good as what I get with my Debian 13 setup, it's much closer now. This seems to reinforce just how well LinuxCNC performs on Debian 13 — especially considering that my Debian system has full driver support, including for sound, whereas your Gentoo distro doesn’t include those drivers by default. When I disable the sound drivers on Debian, I get even lower latency, though honestly the out-of-the-box performance is already excellent, so no need to disable them.
I also noticed one strange behavior on Gentoo: although the Latency Histogram window is otherwise responsive, the graph and Elapsed Time sometimes appear to freeze and stop updating. Pressing the Reset button restarts the process, which confirms that the application itself isn't hanging — just the display updates seem to stop intermittently.
Below are the latency graphs for both systems after running for 30 minutes under the same conditions:
  • 5x glxgears
  • Heavy internet browsing with YouTube videos playing
  • System stress via:
    $ stress-ng --cpu 4 --iomix 2 --vm 1 --vm-bytes 1G --timeout 2000s --metrics-brief
    Thanks again for your work on the Gentoo distro — curious to hear your thoughts!
  • rebelx
  • rebelx
06 Sep 2025 09:32 - 06 Sep 2025 09:42
<duplicate message; deleted>
  • unknown
  • unknown
06 Sep 2025 09:17
SOLVED - VNC Server problem on Raspberry Pi 5 4GB - LinuxCNC official image
Best bet is to google for the various internet resources for setting up vnc.
You may have some luck searching the forums, but it wasn't a package I thought needed, still don't, for running a CNC machine. I'm not a fan of running a CNC setup remotely.
If you just need to run an editor or even Linuxcnc remotely it can be via SSH.
  • Hakan
  • Hakan
06 Sep 2025 08:51
Replied by Hakan on topic orient spindle with ethercat EL5101
Category: EtherCAT
When I think of it, it may not work very well with FF1 in this situation.
I guess orient just gives a position, without any ramping up and down.
Not like a motion profile with acceleration up and down.
My new bet is to set all FFs to zero and slowly increase P.
  • ziggi
  • ziggi's Avatar
06 Sep 2025 08:10
Troubles to get started with SD240 Retrofit
Category: Turning
I´m using a Mesa 7i33 for the encoders and pwms. The encoders are Fanuc, so there is very little info to get on the specs of the encoders. All I know is they are TTL and 2000i/rev
All I have additionally is the schematics of the control where the encoder connection can be seen:
As it shows inverted channels I think they are differential types
And yes, the 7i33 is jumperd to TTL (Jumpers DOWN)
  • JackRay
  • JackRay
06 Sep 2025 07:49
The Parameters was created by JackRay
The Parameters
Hello, I am writing G-code files with parameters O<measure> call [#1] [#2] ... and I cannot access certain variables in LinuxCNC 2.9.4 (e.g., <#_tool_diameter>). I need to read this data in my tool table in order to develop my program. Can anyone help me?Thank you.
  • Sandro
  • Sandro
06 Sep 2025 07:32
Probe Basic tool touch off gives "Probe tripped during non-probe move"
Category: QtPyVCP
I am sometimes facing the same error just when the probe is tripped during the slow probe move. But I don't fully understand how this is related to the probe home?
  • Sandro
  • Sandro
06 Sep 2025 07:25
Replied by Sandro on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Check my comment on page 9 for a csv config.
  • amanker
  • amanker
06 Sep 2025 06:45
  • emresensoy
  • emresensoy
06 Sep 2025 06:01
I downloaded the official image from here; www.linuxcnc.org/iso/rpi-5-debian-bookwo...25-01-27-0140.img.xz
Everything is ok, linuxcnc and ethercat master is working,
I am trying to connect via VNC from remote, when I connected to 192.168.1.122:1 via VNC's password, its connecting but there is only blank gray screen,
I installed tightvncserver also, its same,
What should I do?
  • amanker
  • amanker
06 Sep 2025 05:49
When machine comes out of estop it gives error "Remora FATAL ERROR [JASON Config]: Config file open failed (status=0xA2)".
  • Moutomation
  • Moutomation
06 Sep 2025 05:08
Replied by Moutomation on topic Speed in jog use
Speed in jog use
Thank you very much for your help.
Displaying 13276 - 13290 out of 13748 results.
Time to create page: 1.727 seconds
