  • unknown
  • unknown
04 Sep 2025 22:07
(Solved) Races through first cycle upon first start up. Fine afterwards.
Category: Basic Configuration
Just read your post prior to mine.
Your still to provide the information I ask for to diagnose your situation.
See sometimes as issue can arise that none have seen before, there was a recent one regarding MDI pins. Until one user had used a particular setup it had never occurred. Fortunately the user supplied the information particular to their usage and the code was quickly fixed and merged into the code base.
If that user had of reacted as you did nothing would have been resolved.
Now old Tommy has a great deal of experience deploying Linuxcnc based equipment as a commercial endeavour, so he is no Johnny come lately. PCW is the Mesa presence on the forum, very helpful, very knowledgeable and quick to respond to users requests for custom firmware. Very respected, will even endeavour to help when the mesa firmware is being deployed on non Mesa Spartan 6 platforms. Also has been generous enough to supply schematics to his products when asked.
So I would my two esteemed colleagues conduct themselves in a manner that has earned them the utmost of respect.
So I think it would be a good time for you the reassess your comments, look through the forum and read the replies they have given other users. Then it would be an idea to offer an apology cool down and supply the information requested so this issue can be resolved .
So what version of Linuxcnc are you using, what is the underlying OS, are you able to attach the config files ? Also what hardware is being used to control the machine, is it parallel port based, Mesa based or some other hardware based step direction system ?
Diagnosis requires the collection of information and that is the reason for request.
  • unknown
  • unknown
04 Sep 2025 21:47
I thought I was being quite helpful, like my esteemed colleagues I was confused about MEM.
Playing the victim, the use of the phrase "folks", the mini lecture on the use of the word again, whilst missing the comma you used to add emphasis as noted in the mini lecture and finally quoting google as to drive home the point that those that queried the whole MEM thing were plebs makes me wonder if the OP has had any oil, dirt or grease ever touch their hands.
But then again I'm a paranoid bastard that trusts no one.
  • TheTinkeringMechanic1
04 Sep 2025 21:43 - 04 Sep 2025 21:44
I come from an industrial background, this is our only linuxcnc controlled machine. If I use a description that is common in other machines we use daily and you don't, then ask. I'd be more than happy to explain what I mean and happy to learn the "correct" description used by linux users. If you don't want to ask. Heck, Google it. It's free.
No. Instead I get this snark comment from you:
"Despite reading almost every post on this forum, i have no idea what that means."
Guess what, that's not a question. But I explained what MEM mode was anyways. Again, google is free.
Another person here felt it necessary be insulting as though I don't know what system I'm using... Sorry, I don't know your "linuxcnc" lingo.
THIS is how you people conduct yourselves here and act appalled by my response?
Then you said "Again, does the machine move at G0 speeds or just the gcode preview on LinuxCNC screen?"
This was explained CLEARLY in the first text:
"And it'll race through the g code like the entire program was full of G0 commands. If I had a part in the machine it would have crashed.  It's like it ignored every G1 command."
No where in the post did I even mention "preview" of any kind. No Idea where you got that. I said if a part was in it that it would have crashed. Know what that means? That means the machine was moving....  I can't make it any clearer. I can't understand it for you.
Now if you'll excuse me, I have an issue to figure out.
  • RikoBR
  • RikoBR
04 Sep 2025 21:33
Replied by RikoBR on topic Y axis A slave help request
I tried importing .XML file but did not go thru and tried tandem y from drop menu according to pins but stepper will not move. Maybe I am doing something wrong along the way I will keep looking for it, do you know if running the live Linux from usb diver would have any restrictions? I bought this machine and computer is old my latency is about 55k so not sure how well LinuxCNC will work. I did a few upgrades on the machine itself I guess the next step is pc and OS and then decide if I stay with mach3 or LinuxCNC
Thanks for the help
  • PCW
  • PCW's Avatar
04 Sep 2025 20:50
Replied by PCW on topic Connecting my 7i96s to the VFD
Category: Driver Boards
Yes if the PWM scale is set for 2000, any PWM value greater than or equal to
2000 would result in a 10V output
  • scotta
  • scotta's Avatar
04 Sep 2025 20:43
Which firmware are you using? The SKR3 is only supported in the latest Remora-core development repo.
  • Milkof
  • Milkof
04 Sep 2025 20:40
Replied by Milkof on topic Connecting my 7i96s to the VFD
I set the parameter to 3.
I'm starting to suspect that if I set values ​​above S2000, the VFD was running at maximum.
Tomorrow I'll make the corrections to the INI file and try.
Thanks and have a good evening.
Milko
  • scotta
  • scotta's Avatar
04 Sep 2025 20:40
Replied by scotta on topic Remora DMA Code in other Builds?
I did have a version for the F4 in development, but it turned out the F4's are not fast enough to do the step calculations to fill the DMA buffer. The STMs don't have a GPIO toggle bit like the RT1052 so the full step pattern had to be filled into the buffer, not just the rising and falling edges.
  • PCW
  • PCW's Avatar
04 Sep 2025 20:35
I would look carefully at page 20 especially the settings for P07.08
  • Milkof
  • Milkof
04 Sep 2025 20:13
I looked for a way to reset the VFD at the link below, but I couldn't find it. Thank you so much for your help.
Milko
share.google/KEIbyk4YFMFFaMgyR
  • JT
  • JT's Avatar
04 Sep 2025 20:09
Replied by JT on topic Flex Gui I/O Widgets
Category: Flex GUI
After another update one error solved, and next error occured. I modified ini settings, moved css entry  and dro_font_size to [flexgui], but my ui and the examples are not starting:
  File "/usr/bin/flexgui", line 341, in <module>
    window = flexgui()
  File "/usr/bin/flexgui", line 245, in __init__
    startup.setup_plot(self)
  File "/usr/lib/python3/dist-packages/libflexgui/startup.py", line 2169, in setup_plot
    dro_font = self.inifile.find('FLEXGUI', 'DRO_FONT_SIZE') or '12'
NameError: name 'self' is not defined
Sorry about the copy and paste error, I've fixed that. And thanks for posting the complete error it makes it easy to fix.
JT
  • JT
  • JT's Avatar
04 Sep 2025 20:05
N100DC was created by JT
N100DC
I've been testing an AsRock N100DC for a bit now with Mesa Ethernet cards and the latency is really good and no read errors after a few days connected to a 7i96s. The latency is good enough for software stepping. It has a serial port on the back so if you're using GS2 component over modbus you're golden. Just be careful that you select the correct case, the first one I got was too short to fit the mother board in.
JT
  • PCW
  • PCW's Avatar
04 Sep 2025 20:04 - 04 Sep 2025 20:05
If 24000 RPM is the maximum spindle RPM at 10V, then in the .ini file:
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 24000.0
OUTPUT_SCALE = 24000
OUTPUT_MIN_LIMIT = -24000
OUTPUT_MAX_LIMIT = 24000
Do you have a link to the VFD manual?
  • Milkof
  • Milkof
04 Sep 2025 19:59
Hi, above the picture.
with s1000m3 5 volts
with s2000m3 10 volts.
Why is s2000 already at maximum? How do I ratio 2000 to 24000 rpm?
So it seems to work?
So the problem seems to be in the VFD?
Milko
  • jackj120
  • jackj120
04 Sep 2025 19:50 - 04 Sep 2025 19:57
Replied by jackj120 on topic Mecanumeric MF2040 LI retrofit (Pantograph)
Category: Milling Machines
It's been a while since the last post .  So i've mounted all the machine and today i've done the first work with it , but there is a problem it's mirrored (like the second photo) . So searching online and talking with chatgpt i saw that someone change the sign of the  step_scale and so I did , but than i've problem with the limits . And i have to change them and adapt but i did not figured out yet how to do that properly , so any advice for that is well accepted. Other thing, i've to leave the normal axis gui and change that with one mine personalized because i need custom buttons (and it's more cool) .Can someone give me some advice?
Displaying 13366 - 13380 out of 13750 results.
Time to create page: 0.709 seconds
