  • andypugh
  • andypugh's Avatar
04 Sep 2025 16:43
Replied by andypugh on topic Axis_Comp having no effect[SOLVED]
If the comp table is backwards then the interpolator function will only ever read the first value, so you will get a fixed offset, and no apparent compensation.
  • andypugh
  • andypugh's Avatar
04 Sep 2025 16:40
Replied by andypugh on topic Troubles to get started with SD240 Retrofit
Category: Turning
Your HAL looks correct.
When you say "in the oszy" do you mean in the HAL oscilloscope , or on a physical one?
In the HAL oscilloscope try scoping both the index-enable signal and the hm2_7i80.0.encoder.00.input-index pin.
If index-enable is high then it should go low when the (short) input-index pulse is seen.
The index-enable pin should go high as soon as the home switch trips.
  • Milkof
  • Milkof
04 Sep 2025 16:32 - 04 Sep 2025 16:42
Replied by Milkof on topic Connecting my 7i96s to the VFD
Category: Driver Boards
  Hello,
between pins 22 and 23 I find 10V
between pins 22 and 24 also 10V
I don't see any change if I lower the speed
if I stop the spindle
between 22 and 23 0V
22 and 24 10V
Thank you
Miilko
  • andypugh
  • andypugh's Avatar
04 Sep 2025 16:29
Replied by andypugh on topic Gig Skillcut 60
Gig Skillcut 60
I think it was an attempt to link to this thread.
forum.linuxcnc.org/plasma-laser/41893-ci...ng-to-cnc-use#202415
And now that we know that it is CigWeld CutSkill, not Gig SkillCut we might have more idea what is being discussed.
  • PCW
  • PCW's Avatar
04 Sep 2025 16:18
Replied by PCW on topic Connecting my 7i96s to the VFD
As setup, if you have 10V on Spindle+ (7I96S TB3.24) and you run s1000M3
in MDI, you should get +5V measured from Spindle-Out  (7I96 STB3.23)
to Spindle- (7I96S TB3.22)
(you do have to home the machine before MDI will work)
I would verify this before worrying about the VFD setup
  • andypugh
  • andypugh's Avatar
04 Sep 2025 16:14
Replied by andypugh on topic Lathe "pecking" on X?
Category: G&M Codes
No, there is no built-in version of this, but I have seen demonstrations of it on Youtube.
However, it should be relatively easy to configure with LinuxCNC using external offsets.
An example of using this is in this video:
The trick is to calculate the required offset based on a non-integer factor of the spindle rotational position.
How many lobes per rev you would need is something that might need some consideration, and might depend on the working diameter.
The closest HAL component to what you need is probably "relief,comp" here:
github.com/andypugh/HalComps/tree/main
  • Hakan
  • Hakan
04 Sep 2025 16:07
Replied by Hakan on topic orient spindle with ethercat EL5101
Category: EtherCAT
Try a small value for FF1 so it starts to rotate. Then add P so it stops.
  • Milkof
  • Milkof
04 Sep 2025 16:06 - 04 Sep 2025 16:21
Ciao e grazie per il tuo aiuto.
In teoria, ho impostato i parametri del VFD come segue:
P00.01 1
P00.08 3
Ho trovato questi valori online, ma a quanto pare non sono sufficienti.
Quali altri controlli potrei fare? La velocità sembra essere impostata su un valore e non riconoscere i comandi  in MDI.
Durante il test, sembra essere impostato sulla velocità massima.
In effetti, trovo 9,9 volt tra GND e pin 10V.
Grazie
Milko
  • PCW
  • PCW's Avatar
04 Sep 2025 15:48
I don't see anything obvious wrong in the hal/ini files.
What is the actual issue with the spindle speed?
You might need to measure the 7I96S Spindle+ and Spindle output vs Spindle-
at various spindle speeds to track down the issue.
It might also be a VFD setup issue. (if the voltages are correct but the VFD does not respond)
  • JT
  • JT's Avatar
04 Sep 2025 15:38 - 04 Sep 2025 15:38
Replied by JT on topic Flex Gui I/O Widgets
Category: Flex GUI
Today, after updates, i am not able to start any flexgui ui .  Error: No module named 'psutil'
The module psutil was removed 5 days ago.
Can you post the complete error?
How did you update?
JT
  • Milkof
  • Milkof
04 Sep 2025 15:10 - 04 Sep 2025 15:21
Ciao, trovi i due file allegati. Grazie per l'assistenza. Milko
File Name: CNC_1.hal
File Size:11 KB
File Name: CNC_1.ini
File Size:5 KB
  • TheTinkeringMechanic1
04 Sep 2025 14:24 - 04 Sep 2025 14:26
(Solved) Races through first cycle upon first start up. Fine afterwards.
Category: Basic Configuration
When a sentence starts with "Again," it functions as a conjunctive adverb, requiring a comma immediately after it to separate it from the rest of the sentence. This usage is grammatically correct and can effectively add emphasis to repetition, the return to a previous point, or a second example.
Google -> "In CNC, MEM mode, or Memory mode (sometimes called Auto mode), is the operating mode where the controller executes a complete G-code program stored in its internal MEMORY, allowing the machine to perform automated machining cycles for production."
After being piled on by a pack of folks, that can only be described as: Deliberately obtuse.
I think I'm just going to the smart thing and just never mind.
You all have a nice day. Take care now. Bye-bye then.
04 Sep 2025 14:12
"In CNC, MEM mode, or Memory mode (sometimes called Auto mode), is the operating mode where the controller executes a complete G-code program stored in its internal memory, allowing the machine to perform automated machining cycles for production."
  • unknown
  • unknown
04 Sep 2025 14:08
Perfect computer to use with Ethercat in industrial use? Please help
First things I would look into would be the ability to turn any power saving options off. You want the absolute minimum to ideally no power saving. Being able to turn any "secure boot" options off can be an advantage in some instances.
To tell the truth I've been using an Odroid H3 plus in an enclosure for years in a very hot garage during Aussie summers and had zero issues with any heat.
If possible stay away from Realtek chips for ethernet, they can work but require extra effort.
Tommylight has put many many machines into use, industrial settings, and has excellent results using ex corporate machines, usually i5/i7 based machines.
The funny thing is "latest and up to date" doesn't always mean best. Honestly tried and true is about as close you will get to perfect, if anything like that actually exists.
I apologise if this doesn't answer your query directly and on the face of it sounds pretty generic but these are the sorts of things I would investigate prior to purchasing an item similar to what you have linked to.
  • emresensoy
  • emresensoy
04 Sep 2025 13:27 - 04 Sep 2025 16:32
Displaying 13396 - 13410 out of 13750 results.
Time to create page: 0.903 seconds
