  • trisa25
  • trisa25
03 Sep 2025 18:35
Replied by trisa25 on topic DMG DMU 50 Retroftiing(?) help
Category: CNC Machines
More pictures.
  • trisa25
  • trisa25
03 Sep 2025 18:31
I have a simmilar 15k rpm Kessler spindle on a DMC 100 V.
I have attached the datasheet pictures.
  • Creative25
  • Creative25
03 Sep 2025 18:03 - 03 Sep 2025 18:07
Replied by Creative25 on topic Firing the torch on the fly.
Category: Plasmac
Thanks for your quick reply.
Unfortunately the slots I need are open lines.
So no lead ins.
What I tried is using the puddle jump at Pearce hight. No pierce delay but a puddle delay. It seems to work well. But you don’t really have much control over plunge rate.
Is there a better way of doing this?
How do I fire the torch while the gantry is moving?
03 Sep 2025 17:48
Replied by tommylight on topic Firing the torch on the fly.
Category: Plasmac
You need "lead in" for plasma cutting, you have that option in the included wizards for stuff you draw in LinuxCNC, and you will need a CAM software for other stuff to add those, probably SheetCAM.
BTW, you can start the torch while moving, but that will leave uncut sections on thin material and not cut at all on thicker material, but it will ruin the nozzle really quickly.
  • Artur_1617
  • Artur_1617's Avatar
03 Sep 2025 17:14
Replied by Artur_1617 on topic Mpg stop working
Mpg stop working
Category: AXIS
I must make changes to in jogscale..
Working setup
#Jog Pendant
loadrt mux4 count=1
loadrt ilowpass
setp ilowpass.0.scale 100
setp ilowpass.0.gain 0.01
addf mux4.0 servo-thread
addf ilowpass.0 servo-thread
net x-jog-select joint.0.jog-enable axis.x.jog-enable <= hm2_5i25.0.7i77.0.0.input-10
net y-jog-select joint.1.jog-enable axis.y.jog-enable <= hm2_5i25.0.7i77.0.0.input-11
net z-jog-select joint.2.jog-enable axis.z.jog-enable <= hm2_5i25.0.7i77.0.0.input-12
net a-jog-select joint.3.jog-enable axis.a.jog-enable <= hm2_5i25.0.7i77.0.0.input-13
net x10 hm2_5i25.0.7i77.0.0.input-14 => mux4.0.sel0
net x100 hm2_5i25.0.7i77.0.0.input-15 => mux4.0.sel1
setp mux4.0.in0 .0000025
setp mux4.0.in1 .000025
setp mux4.0.in2 .00025
setp mux4.0.in3 .0
net jogscale mux4.0.out => joint.0.jog-scale axis.x.jog-scale
net jogscale => joint.1.jog-scale axis.y.jog-scale
net jogscale => joint.2.jog-scale axis.z.jog-scale
net jogscale => joint.3.jog-scale axis.a.jog-scale
net mpg-out hm2_5i25.0.encoder.05.rawcounts => ilowpass.0.in
net jogcounts ilowpass.0.out => joint.0.jog-counts axis.x.jog-counts
net jogcounts => joint.1.jog-counts axis.y.jog-counts
net jogcounts => joint.2.jog-counts axis.z.jog-counts
net jogcounts => joint.3.jog-counts axis.a.jog-counts
  • Creative25
  • Creative25
03 Sep 2025 16:55
Firing the torch on the fly. was created by Creative25
Category: Plasmac
I am experimenting with cutting straight lines for a screen.
Problem is this. On start and end of a line there is a hole that is bigger than the rest of the line.
So I figured out how to edit a cut file by hand so it does stop the torch while the torch moves. So I get a perfect ending on the line I cut.
Question is there a way I can get the torch to probe the metal, then accelerate to cutting speed for say 10 mm then turn the torch on at pierce height.
And pierce while the torch is moving. Start point of cutting is not crucial but cut width at the beginning of the cut should be as close to the rest of the cut as possible.
  • PCW
  • PCW's Avatar
03 Sep 2025 16:47
Install works but the password entered will not work to log on. Please Help
Category: Installing LinuxCNC
Yes, Debian deserves some kind of prize for the dumbest login screen possible.
  • PCW
  • PCW's Avatar
03 Sep 2025 16:41
Replied by PCW on topic Mpg stop working
Mpg stop working
Category: AXIS
In addition to the jog enables, you need to do a similar change with the mpg count pins
that is, for example both joint.0.jog-counts axis.x.jog-counts must connect to the mpg count.
  • Artur_1617
03 Sep 2025 15:41
Mpg stop working
Category: AXIS
I made changes but still not working after homing.
  • John15
  • John15
03 Sep 2025 15:07
Thank's for your replies. It's the login screen thats not clear!
As you say it wants the user name in the top of the two rows but there is no indication that that is what it needs.
All sorted now
Thanks again
  • andypugh
  • andypugh's Avatar
03 Sep 2025 14:59
Replied by andypugh on topic Mpg stop working
Mpg stop working
Category: AXIS
Yes.
Just add the axes too
... etc ...
  • andypugh
  • andypugh's Avatar
03 Sep 2025 14:52
Replied by andypugh on topic Program cnc linux
Program cnc linux
Category: Milling Machines
I tried to up load a jpg file but it kept saying didn't load.
You need to "attach" the file with the "attachments" button then "include" it into the post.
  • andypugh
  • andypugh's Avatar
03 Sep 2025 14:49
Replied by andypugh on topic Y axis A slave help request
Have you tried just importing the Mach3 configuration? That is an option.
("import mach file" on the first page)
That still might not properly configure a gantry, as I am not sure if LinuxCNC can tell the difference between a Y2 or a true A when parsing the Mach file.
Rather than configure it as an "A" configure it as a "Tandem Y" in the drop-downs.
  • Artur_1617
03 Sep 2025 14:42
Mpg stop working
Category: AXIS
Yes Mpg working before homing.
I think must to change this
net x-jog-select joint.0.jog-enable <= hm2_5i25.0.7i77.0.0.input-10
net y-jog-select joint.1.jog-enable <= hm2_5i25.0.7i77.0.0.input-11
net z-jog-select joint.2.jog-enable <= hm2_5i25.0.7i77.0.0.input-12
net a-jog-select joint.3.jog-enable <= hm2_5i25.0.7i77.0.0.input-13
Displaying 13441 - 13455 out of 13750 results.
Time to create page: 0.570 seconds
