  • JT
  • JT's Avatar
31 Aug 2025 11:30
Replied by JT on topic installing an older version
Category: Installing LinuxCNC
My Hardinge CHNC is still running Ubuntu 10 with EMC 2.7 with no issues at all. I doubt that Debian 12 would even install on that pc but if it ain't broke don't fix it is my motto.
JT
  • thomaseg
  • thomaseg
31 Aug 2025 10:29
Probe Basic tool touch off gives "Probe tripped during non-probe move"
Category: QtPyVCP
I did try your suggestion, but the result was the same :-( However, after trying to understand the subroutine line-by-line i found something:
https:/github.com/kcjengr/probe_basic/blob/04900f1f6bec0c6ec3e3130adb82514e7f007b8b/configs/probe_basic/subroutines/tool_touch_off.ngc#L49
Doesn't this assume that my "probe home" is at Z0? on my machine "probe home" is at Z450... i tried changing it to Z450 and it seemed to solve the problem...
So, i think the REAL issue is that my Z-axis works "up-side down" compared to other machines(Z0 at table, Z450 at top). I didn't think that would matter, but seeing that Z0 is hardcoded here, i think this will cause other problems for me in the future, so i think i'll change it...
  • johns00056
  • johns00056
31 Aug 2025 10:18
Replied by johns00056 on topic installing an older version
You can just try loading the existing configuration files onto the Bookworm setup. It ought to just work (I spent a lot of effort on the automatic conversion scripts)
Thanks for the help.
The script to automatically re configure configuration files did not work.
missing [KINS]KINEMATICS=
          [KINS]JOINTS=
From looking at an example , it looks like I will have to change the ini file joints and axes.
It also looks like I will have to add loadrt [KINS]KINEMATICS to the HAL file.
  • johns00056
  • johns00056
31 Aug 2025 10:03
You have to disable "secure boot: and UEFI in BIOS for it to work, UEFI is usually disabled by choosing Legacy mode in BIOS for boot devices/order.
I tried this but  the new computer will still not boot from the thumb drive.
The old computer will boot from the thumb drive.
The new motherboard does not have have CSM (compatibility support module) when using the integrated graphics on the processor .
The internet says something about if I add a graphics card that supports VBIOS display, I might be able to gain CSM functionality.
  • GDTH
  • GDTH's Avatar
31 Aug 2025 09:57 - 16 Sep 2025 17:19
Solved: Bitfile needed for 6i25 + 7i77 + Chinese BoB
Category: Driver Boards
Hello Everyone,
I’m looking for a bitfile for my 6i25 setup with a 7i77 (P3) and a Chinese breakout board (P2).
The breakout board will only be used for stepper control.Does anyone already have a suitable bitfile available, or would be willing to help create one? I’m not yet familiar with making custom bitfiles myself and wouldn’t know where to start, so any help would be greatly appreciated.Thanks in advance!
  • juergen-home
  • juergen-home
31 Aug 2025 06:59 - 31 Aug 2025 08:38
Replied by juergen-home on topic Connect Mesa 6i25 HDR26 with 7I52S HDR50
So the cable is done and the connection seems to work.
  • sunmoon
  • sunmoon
31 Aug 2025 06:04
Feasibility of Replacing Electronic Gearbox with LinuxCNC on RZ300E Gear Grinder
Hi everyone,I'm exploring the possibility of retrofitting an older Reishauer RZ300E gear grinding machine by replacing its existing electronic gearbox with a LinuxCNC-based solution. I’d appreciate your thoughts on whether this is technically feasible—especially for someone with limited experience using LinuxCNC.Additionally, I came across this article on continuous generation grinding  and video(
) that outlines some of the machine’s principles. Could a setup like this be simulated and validated in LinuxCNC before committing to hardware implementation?Any guidance, suggestions, or shared experiences would be greatly appreciated!Thanks in advance.
  • unknown
  • unknown
31 Aug 2025 05:58 - 31 Aug 2025 06:01
2.9.4 iso Bookworm RTAI AMD64 step config issue
I think it's hardcoded into stepconf, otherwise it would have to parse through known editors, there are many and someone would complain (vim & emacs I'm looking at you.)
Alot like geany so that was the editor chosen (same for the arm64 images).
Python3 has been the norm for a while now. I think the gcode generators are 8 years or so old.
There is a lot of python 2 stuff around that just hasn't been update for python 3.
You could install python2 and try that for the gcode generator.
  • vicstransam
  • vicstransam
31 Aug 2025 03:01
Replied by vicstransam on topic Simple G-Code Generator
Category: CAD CAM
Yes, you are correct. The way the python script creates the gcode in this particular script is by using trigonometry to find the coordinates and writing to sys.stdout. I did find a preamble and postamble in the py file and I found the postamble was correct with an M2 so I think it has something to do with the way it sends the code to Axis.
  • Paul01
  • Paul01's Avatar
31 Aug 2025 01:19 - 31 Aug 2025 01:23
Replied by Paul01 on topic Multi Axis Slow Feedrate
Thanks Tommy. I had tried G93 Inverse Time, but didn't see any difference to G94 Programmed Feed.
I went back and did a bit more testing (with G93 and G94). The only thing I've found to work (for both G93 and G94) is to up the velocity and acceleration speeds to unachievable levels, or lengthen the small line segments that make up the toolpath. However, this will result in a more inaccurate part. And I still can't get close to the required feedrate while keeping the short lines to a decent length.
  • xunil
  • xunil
31 Aug 2025 00:15
Replied by xunil on topic halui.mdi-command-NN pins not showing up
Category: HAL
Thanks for the heads up! I don't think that would affect whether the mdi-command-NN pins would show up or not; even if don't load the PyVCP panel, I still don't see the pins exposed by halui.
  • vicstransam
  • vicstransam
30 Aug 2025 23:51
Fresh install and then run stepconfig and noticed that if I try to edit a loaded gcode file in Axis, it does nothing. So I take a look at my .ini file and it points to Gedit but that isn't in Debian 12. It uses Geany. I installed Gedit since it is what I'm used to. I could change it to Geany but I like Gedit better for gcode.
 I just thought it strange that stepconfig would use a non-existent editor.
 Python 3 also makes the simple gcode generators not work anymore and I haven't figured out how to get Native Cam to install.
30 Aug 2025 23:32
Replied by tommylight on topic Multi Axis Slow Feedrate
See if this helps, although pretty old.
30 Aug 2025 23:30
Replied by tommylight on topic Simple G-Code Generator
Category: CAD CAM
"No percent sign or M2"
Means there is no % at the start and end of the gcode file, or M2 at the end.
See if those can be added as a header and/Or footer, or maybe as post processor?
All this is a stab in the dark from what i know using Inkscape where both above options work fine for LinuxCNC.
  • vicstransam
  • vicstransam
30 Aug 2025 23:26
Category: CAD CAM
I had to use "2to3" to try and convert them to Python3 and was able to get the GUI's to work on Bezel and a few others and then I filled out the the dimensions and hit "Write to Axis" but it always errored with "No percent sign or M2" and discarded the gcode file. I couldn't get them to write to the clipboard either. I couldn't get "Engrave" or "Bolt pattern" to run without "indentions or tab" errors.
Displaying 13576 - 13590 out of 13760 results.
Time to create page: 5.019 seconds
