  • besriworld
  • besriworld
22 Aug 2026 17:11
Replied by besriworld on topic Mori Seiki MV-Junior Retrofit
Category: Milling Machines
A little progress.
After installing the transformer, I'm wondering again whether its power rating is sufficient for three 1.5 kW servo motors.
The transformer is rated at 4.7 kVA, 415 V to 220 V, 3-phase.
What do you guys think? Is 4.7 kVA enough for three 1.5 kW servo motors?
  • meister
  • meister
22 Aug 2026 16:54
Why not post the correct links here again? You could also add a bit of information about your Carrot board.
@all: With some projects, people complain when someone builds and sells hardware for them. You don’t need to worry about that here – it’s an open-source project, and I have no financial interest in it; it’s just a hobby. On the contrary, I’m actually really pleased when someone else offers others the chance to get ready-made hardware. I’d be delighted if there were even more of these available – and ideally in a way that means you can order them here in Germany too (AliExpress?!?) :)
OK, there’s just one thing I do expect: if you end up becoming millionaires because of this, you can treat me to a meal ;P
Best wishes, Olli
  • PCW
  • PCW's Avatar
22 Aug 2026 16:19 - 22 Aug 2026 16:20
Replied by PCW on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
5V    --> 5V
DIR-  --> CW-
STEP- --> CLK-
  • muddiver
  • muddiver
22 Aug 2026 15:59 - 22 Aug 2026 16:01
Help needed for conversion of old ( and loved ) Mach3 MPG
Category: Basic Configuration
Hi Aciera, nice to meet you!
My Problem is: My USB-MPG sends weird keys, Alt /M , Alt / - , Alt / % , Alt / # , Alt/= , F10 , F11.
Alt / % sends Alt + Shift + 5 , which makes it "interesting" to grab...
F10 and F11 opens the menu and toggles between fullscreen and windowmode.
So, at first i have to somehow keep these keys from interacting with the UI of Linuxcnc, ONLY interacting with hal_input.
I tried
[code]loadusr -W hal_input -G Code Mercenaries KeyWarrior Combo O Commander
i tried
loadusr -W hal_input -A Code Mercenaries KeyWarrior Combo O Commander
none of these stops interacting with my ui..
What i did so far, i grabbed the USB-name, and vendor and productkey of my USB-Davice.
I wrote a UDEV rule which worked after a bit of confusion.
i loaded the device in the halfile ( of the sim so far ) and i could see most of my keys turn yellow in the halshow.
So my first attempt ( asking the AI, which was not my best option when i think about it now ) was to remap the keys with keyd.
I wrote a default.conf to remap the keys. What happened?
The keys which send F10 and F11 do no longer affect ma ui! No toggling window to fullscreen.
But i struggled at importing the "virtual keyd keyboard" into LinuxCNC.
loadusr -W hal_input virtual keyd keyboard
doesNOT work, "no such device"
I would like to use " , but these don't work for me, i do not know why ( see above )
One of my Problems:
I cannot load the keyboard via "name",
loadusr -W hal_input "Code Mercenaries KeyWarrior Combo O Commander"
does NOT work..
loadusr -W hal_input Code Mercenaries KeyWarrior Combo O Commander
works! As far as i know, i should use " whenever i have blanks in a filename / path / device.
I do not really understand why..
Thanks for any help in advance!
Honestly, i tried with AI-support, but this only calmed my mood because our jobs are safe for a looong time, so crappy answers..
Greets, Tom
  • Aciera
  • Aciera's Avatar
22 Aug 2026 15:18
Do you have the hal_input component working and the pins created?
Maybe show us what you have got and then tell us what is not working. Otherwise we're just guessing.
  • muddiver
  • muddiver
22 Aug 2026 14:53
Hi folks,
i tried remapping the keys on my usb-MPG with keyd, but i struggle importing them into the hal.
Is there a prefered way of remapping keys for linuxcnc and do you have a link to a turorial or a manual?
Thanks in advance,
Greets Tom
  • Holzwurm56
  • Holzwurm56
22 Aug 2026 14:53
Replied by Holzwurm56 on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
Hallo,
noch eine Frage zur Sicherheit. An der 7I96 habe ich 5V , Dir0+ , Dir0- ., Step0+ , Step0- , Gnd.
Am Stepperdriver habe ich Ena- , CW- , Clk- , 5V . Ena würde ich nicht beschalten, braucht man nicht unbedingt.
Ich würde jetzt 5V mit 5V , Dir0- mit CW- und Step0- mit Clk- verbinden.
Haltet ihr das für richtig?
MfG
Hans
  • Tim Bee
  • Tim Bee
22 Aug 2026 14:36
Dear meister:
I’d like to correct some information. While browsing through the old posts, I noticed that on page 100 you shared a product link. However, that is actually not my product link, I only sell my products on Taobao. Based on today’s exchange rate, the price is approximately USD 29.61.I only had a small batch made by JLC for my own DIY projects, so there’s no real cost advantage.
Tim
  • MarkoPolo
  • MarkoPolo
22 Aug 2026 12:30
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
I did a few more tests, and with a short Gcode file of ~1500 lines, it works fine, disabling the spindle on the first try. If the file is already ~2000 lines long, there's a problem. This value may vary on different machines, but you can try shortening or extending the number of lines. The beginning and end of the file remain the same. Try test.ngc.
  • GFC
  • GFC
22 Aug 2026 09:58
Replied by GFC on topic THC doesent work when G code is running
Category: Plasmac
Does anyone know a full list of requirements for thc activation so I can check them one by one?
  • cmorley
  • cmorley
22 Aug 2026 04:55
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
The voice can be helpful with testing HAL stuff. Qtvcp has a test_led component that can speak on hal pin state changes.
Maybe the problem is a race condition that doesn't effect me. I'll get looking.
I wonder if adding a m5 to the abort script would help?
21 Aug 2026 23:44
Replied by tommylight on topic Error in tool_offsetview.py
Category: Qtvcp
Just did a test on 2.10 sim that was probably compiled a year ago, besides not letting me run any gcode complaining ... ne, SCREAMING at me "abort something or another 3" , but it did turn the spindle on once and did require stop twice to turn off.
P.S.
No idea who thought adding sound/voice to cnc machine controller was smart, although it would be hilarious if it did scream some profanities when making mistakes, but since i always have music playing in the shops (loudly), it might give a heart attack to anyone else in the shop. :)
  • MarkoPolo
  • MarkoPolo
21 Aug 2026 19:49
Category: Qtvcp
If no one else is having this problem, then it's clearly just me. There's no point in pursuing this further.
That's strange, though, because I downloaded the entire program from Git, compiled it, and the same problem persists. Older master builds don't have this problem.
With a freshly compiled program, I open one of the default qtdragon configurations, open some gcode, run it, press stop, and the program stops, but the spindle doesn't turn off. I have to press stop again to turn the spindle off.
  • Salrodri
  • Salrodri
21 Aug 2026 16:29
Replied by Salrodri on topic Gmoccapy Macros
Gmoccapy Macros
Category: Gmoccapy
After running a few tests, it appears that, in my case, the problem was caused by a missing software package. Installing gir1.2-rsvg-2.0 fixed the issue for me.
It is also worth mentioning that I installed Glade and configured it to use GTK 3.16 and WebKit2GTK 2.28.
For reference, I am running LinuxCNC 2.9.8 RMD on a Raspberry Pi 5.
Hopefully, this helps anyone experiencing a similar issue.
  • PCW
  • PCW's Avatar
21 Aug 2026 14:09
Retrofitting a 3-axis VMC with DC servos - guidance needed
Category: Driver Boards
If you use 7i97t_7i74d.bin firmware,  sserial channel 0 is on the 7I97T and
sserial channels 1..7 are on the 7I74.  (Physical channel 0 is skipped on the 7I74)
Displaying 1381 - 1395 out of 12530 results.
Time to create page: 0.358 seconds
