  • Esaber
  • Esaber
09 Jul 2025 08:13
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
Category: Plasma & Laser
So both motors are triggered and do move (jolt) when I enable the machine in linuxcnc. Looks like a central command goes to both motors to move. Powering the esab machine without linuxcnc is fine. No movement. Will check the voltage and report back.
  • pippin88
  • pippin88
09 Jul 2025 07:55
Replied by pippin88 on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
Overrides are just set via physical up and down buttons, or via GUI in my setup.
New machine will sue encoders to have physical knob.
If easiest, a pop up warning that overrides are set, and buttons to cancel program, or proceed, would be very useful.
  • kjlty
  • kjlty
09 Jul 2025 07:27
Replied by kjlty on topic Flex GUI 1.2.2 Released
Category: Flex GUI
"I would greatly appreciate it if you could replace QPlainTextEdit with QsciScintilla."
  • HansU
  • HansU's Avatar
09 Jul 2025 07:26
Replied by HansU on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
"Reset to 100%" would not work if you are using analog signals for the overrides.
So it will be only options for proceed and abort.
  • lonnox
  • lonnox's Avatar
09 Jul 2025 06:31
7i77 lost connection while encoder counts (PREEMPT-RT)
Category: Driver Boards
Dude, your machines look awesome by the way!
there is only one RAM module in the PC, but i tried to swap it with a module from another PC. Both module have different speeds, sizes and manufactors. The same is for a second graphics card i tried.
But again without luck.
Wish i had another Ryzen CPU for testing but i haven't.
  • AirRacer
  • AirRacer
09 Jul 2025 06:30 - 09 Jul 2025 15:12
Replied by AirRacer on topic Mesa Configuration Tool
Category: Configuration Tools
I’ve just discovered that the Mesa Configuration Tool (at least the version available prior to 8/19/2024) does not configure the manual tool change section correctly.  I recently discovered this when my file did not stop at the M6 command and continued on to the next set of code.  I was able to look at a .hal file set up with pncconfig and copy the manual tool change section from there and now everything works correctly (I get the manual tool change pop up window when the M6 command is encountered). This is a Mill setup that uses the AXIS GUI.
Here are the two configurations:
Pncconfig version that works:
#  ---manual tool change signals---
net tool-change-request    <= iocontrol.0.tool-change
net tool-change-confirmed  => iocontrol.0.tool-changed
net tool-number            <= iocontrol.0.tool-prep-number
#  ---Use external manual tool change dialog---
net tool-change-request    =>  hal_manualtoolchange.change
net tool-change-confirmed  <=  hal_manualtoolchange.changed
net tool-number            =>  hal_manualtoolchange.number
#  ---ignore tool prepare requests---
net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared
Mesa Configuration Tool version that doesn’t invoke the manual tool change pop-up or pause the code at M6:
#  Manual Tool Change Dialog
# create signals for tool loading loopback
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net tool-change-loop iocontrol.0.tool-change => iocontrol.0.tool-changed
 Regards,
Skylor
  • meister
  • meister
09 Jul 2025 05:44
Replied by meister on topic Xilinx Zynq 7010 fpga crypto windfall boards
Interface between ARM-Core and FPGA-Part works, using AXI.
next step: udp2axi program for the ARM-Core
  • PCW
  • PCW's Avatar
09 Jul 2025 03:25
Best HAL function 2 contol bits for S32 in, 1 of 4 out?
Category: HAL
I would think that could be done with 2 mux2 components
(1 for X and 1 for Z) that select between anglejog outputs
when anglejog is enabled and direct MPG counts when
anglejog is not selected.
  • weedsmoker
  • weedsmoker's Avatar
09 Jul 2025 02:32
keeping two axes synchronized while defining the feedrate of only one
I didn't know about g93 you're right that's definitely the way to go
  • slowpoke
  • slowpoke
09 Jul 2025 00:25
Category: HAL
Normally the MPG encoder count goes to all Axis jog count pins,
so no routing of the counts is needed.
This is required so that LinuxCNC can track the current MPG count
and only apply changes to the enabled axis.
The problem is that when using anglejog for emulated compound movement (X+Z), the MPG ticks get processed by anglejog and then analogjog outputs the sin and cos values that are to be fed to; axis.x.jog-counts, and axis.z.jog-counts, however in HAL,  axis.x.jog-counts, and axis.z.jog-counts are already being driven by the raw (non sin and cos values) from the MPG for non compound/anglejog use.
axis.x.jog-counts, and axis.z.jog-counts, can't be driven by both the MPG and anglejog
net encoder-counts  <= hm2_7i96s.0.inm.00.enc1-count
net encoder-counts => axis.x.jog-counts
net encoder-counts => axis.z.jog-counts
net encoder-counts => anglejog.counts-in
net angle_x <= anglejog.coscounts
###net angle_x => axis.x.jog-counts  can't do this!!!
net angle_z <= anglejog.sincounts
###net angle_z => axis.z.jog-counts  can't do this!!!
  • PCW
  • PCW's Avatar
08 Jul 2025 22:50
Replied by PCW on topic Esab Ultrarex UXD-P2000 Upgrade Project
I guess the next step would be to make sure that the analog output path is OK.
A quick check would be to make sure that the analog output voltage of the 7I77
is near 0V when LinuxCNC is not running.
  • PCW
  • PCW's Avatar
08 Jul 2025 22:11
Category: HAL
  • unknown
  • unknown
  • unknown
  • unknown
08 Jul 2025 22:08
Replied by unknown on topic Bios error during lcnc start
I think the card needs to be installed during the installation.
That way, its kernel module will be loaded during boot-up.
You're wrong, so very very wrong.
08 Jul 2025 22:06
OK, that only leaves the memory modules, so if there are two, try yanking one out and testing, then the other one and test again.
Explanation for some of my replies:
I use a lot of Ryzen PC's, including this one i am typing on:
forum.linuxcnc.org/show-your-stuff/55173...thers-company#331546
And the rest on that topic, one thing i found out the hard way is that PCI-E issues will sometimes show as memory errors on Linux boot and DMESG, and easy to reproduce by using different GEN devices, mostly graphic cards, especially if using riser cable for it.
Displaying 14446 - 14460 out of 14632 results.
Time to create page: 1.333 seconds
